Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
01-02-2021, 02:36 PM | #15 |
It could also be for ease of removal with an exhaust that runs down the center-line of said sway bar. I have a Perrin exhaust and getting the rear sway bar “hooks” around the mounting brackets can be a real PITA sometimes. You get one hook on and the other hook just barely can’t fit around it’s bracket. You try to the raise both hooks at the same time but the exhaust gets in the way forcing you to only raise one side of the bar at a time.
Center GRMN exhaust: |
The Following 2 Users Say Thank You to norcalpb For This Useful Post: | JIM THEO (01-02-2021), PulsarBeeerz (01-03-2021) |
01-03-2021, 03:36 AM | #16 |
I don't think it's center exhaust related either, the GR model has center exhaust but standard bar.
Definetely I'd not say it's obstruction related. |
01-03-2021, 12:05 PM | #17 |
01-03-2021, 09:52 PM | #18 |
Seņor Member
Are you sure that isn't a pic of a front sway bar used by accident?
1974 TA22 Celica
2013 86 GT |
01-04-2021, 01:01 AM | #19 | |
https://toyotagazooracing.com/pages/grmn/86/sp/#concept No, the photo is correct, the part number is specific to GRMN... |
01-04-2021, 04:46 AM | #20 |
Drives: BRZ 2018
The two curves in the middle of the long straight part of the yellow OEM bar gives increased torsional rigidity compared with a same diameter straight bar.
Besides the GR one was introduced before the >MY17 thicker OEM bar so probably it's designed and produced by Toyota, not Subaru. By the way the exhaust manifold of the GRMN car compared with the upgraded CS-R3 race car manifold (afaik produced by Rogue Motorsport quite similar with ACE350) is quite different design: https://racing.tgr-europe.com/wp-con...ge_2017_02.pdf (page 6) GRMN: |
The Following User Says Thank You to JIM THEO For This Useful Post: | Thefalls (01-04-2021) |
01-04-2021, 11:52 AM | #21 | |
Drives: Crapcan
01-04-2021, 08:35 PM | #22 |
Seņor Member
If it is to suit the rally car it may well be designed to allow greater suspension articulation.
1974 TA22 Celica
2013 86 GT |
01-08-2021, 02:02 AM | #23 | |
The Dictater
Drives: '13 Red Scion FRS
Anyway, I don't know why the bends are more pronounced on one vs the other except if they wanted to give greater clearance to something either for heat dissipation or physical interference issues. Maybe one is easier to manufacture? Maybe they were actually less concerned with something like ground clearance or something on the GR vs the TRD. |
The Following User Says Thank You to Spuds For This Useful Post: | NoHaveMSG (01-08-2021) |
01-08-2021, 02:03 AM | #24 |
The Dictater
01-08-2021, 04:40 AM | #25 |
Barred
Drives: My18 wrxsti My19 brzts
That is, as you say, different articulation
Wait until my Flex capacitor hits 88
10-17-2021, 01:23 AM | #27 | |
Drives: '15 BRZ RA
Another thing to point out is that a few ideas that were tested in the GRMN car have passed to the new GR86 car. Sad thing is that they couldn't pass the revised FA20 engine with the output of 219 PS (19 PS more) at 7,300 rpm and 217 Nm (12 Nm more) at 5,200 rpm. Problem was that Subaru couldn't make such a well balanced engine and they didn't want to revise their engine production process. So for Subaru the easier route was just to increase the engine displacement, although the rest of the world was downsizing their engines. |
10-17-2021, 01:49 AM | #28 |
Looks like a front bar to me. People upload the wrong picture to the part sites all the time.
Edit: actually the bends don't match up at all, I doubt that bar is even for an 86. Critical mount points aren't changed willy nilly on production cars. |
Similar Threads | ||||
Springs shape | gpvecchi | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 15 | 11-05-2020 07:32 PM |
{NY} BRZ SPC LCA's used 3KMI in great shape $OLD | BRZ!@# | Brakes, Suspension, Chassis | 1 | 06-26-2018 07:01 PM |
Fender vent shape | Gunman | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 05-04-2016 04:29 PM |
Headlight shape | cslntuee | Cosmetic Modification (Interior/Exterior/Lighting) | 5 | 02-28-2013 04:44 AM |
