#29 |
Australian and Proud !!!!
Drives: 2012 Toyota 86 GTS Aero Kit
How much does that rear brace weigh?
BONKRS for life
#30 |
Drives: Sterling BRZ Ltd
I haven't weighted the brace but its probably 9-10lbs. Ive been playing with the end plates to find that balance between lightweight and strength.
Everything is made from stainless so not as light as AL but it was its pros and cons I've definitely thought about doing a machined AL piece but thats for another time.
The Following User Says Thank You to mrk1 For This Useful Post: | mfbmike (10-20-2013) |
#31 |
Drives: 2013 FR-S whiteout
Very impressive fabrication.
#32 |
Drives: FRS
For the rear trunk brace; are those lower mounting bolts OEM? Or did you have to drill them in the chassis?
#33 | |
Drives: 2013 Subaru BRZ
OP, as others have said, I am VERY interested in the rear brace. Would probably buy the front also if you do a package deal. |
#35 |
I try my best to make all my ideas/parts use factory bolt holes and not require drilling of cutting. Kind of learned my lesson on that in the past.
When the time comes I will have a chat with the powers that be about maybe being a vendor here. As of right now I am building a website for my work shop so that's priority.
#36 |
Drives: 2013 FRS, 2008 R32
Funny you mention that. The brace I posted above required drilling into the chassis. Needless to say, took some testicular fortitude. lol.
Measure twice, drill once. |
#37 |
Drives: 2JZ FRS
I need that rear brace!
#38 |
turbo manifold materials on order, FI needs a bigger exhaust so I started with a 3" front pipe
#39 |
Drives: 2013 MT FS FR-S / 07 GT500
Sweet work man! I want that rear brace too!
Stage 1 V2 .57trim Turbo Kit, ACT HD6P Clutch w/Streetlite Flywheel, Greddy EVO3
391whp/295tq 13psi 96 pump 335whp/260tq 10psi 93 pump |
#40 |
Drives: 13 BRZ
#41 |
Local fabricator, eh? Good to know.
Current: 2005 Porsche 911 Carrera S 6MT Previous: 2 BRZ's, 997 C2S, C5 RS6, C4 S6, B8 S4, GDB STi, S30 240Z, FC3S RX-7 TII, AW11/SW20 MR2, E30 318is/325i, etc. |
#42 |
AMR Performance: How to remove the factory bumper (walk-through images inside) | AMR | Engine, Exhaust, Transmission | 9 | 04-10-2013 07:45 PM |
86 Modelista walk around and GT Limited | SoCal_86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-24-2012 11:53 AM |
