Old 02-16-2021, 11:38 AM   #29
abyssFT86
Drives: 2020 BRZ Limited
Looking to grab a set of 17 x 9" +35 for my 2020 BRZ w/ Performance Package. Sounds like I would definitely want / need camber adjustment per another post as well as chatting to Apex folks on the phone who were super helpful.
Is that better achieved using top hats / camber bolts, or at this point should I just upgrade to coilovers (which seem to have built in camber plates at the top?). I imagine overall handling and adjustability would be better with the coilover setup.
abyssFT86 is offline   Reply With Quote
Old 02-17-2021, 01:44 PM   #30
APEX Race Parts
FT86Club Official Vendor
APEX Race Parts's Avatar
Drives: Launch-Year Whiteout FR-S
Please keep in mind that we recommended the 17x9 ET35 because of your Performance Package struts. If you do go to a coilover setup, the 17x9 ET42 wheels will be a direct fit and will require less camber as they will sit 7mm further away from the fender.
Thanks,
-Tom
Phone: 925.245.0773 | experts@apexwheels.com | Website | Instagram | Facebook | Blog
APEX Race Parts is offline   Reply With Quote
The Following User Says Thank You to APEX Race Parts For This Useful Post:
abyssFT86 (02-17-2021)
Old 02-19-2021, 08:32 PM   #31
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Originally Posted by abyssFT86 View Post
Looking to grab a set of 17 x 9" +35 for my 2020 BRZ w/ Performance Package. ...
I'd like to clarify that if you do anticipate ever having more than 2º of camber in the front, you might prefer to get et35 wheels now.
I have et37 9" wide wheels with 245 tires and -3º of camber now, and the fronts are substantially tucked in (negative poke). I do rub at full lock, e.g. when spinning out at AutoX. Et42's will be tucked in by some 5 mm more, and will be that much closer to the chassis. Similarly in the rear, I wouldn't go any higher than et40.
"Will require less camber" sounds like an anti-goal for someone who is considering "should I get coilovers so I can adjust my camber?"
timurrrr is offline   Reply With Quote
The Following User Says Thank You to timurrrr For This Useful Post:
APEX Race Parts (03-03-2021)
Old 02-20-2021, 09:30 AM   #32
abyssFT86
I guess I should clarify goals a bit here:
Goal 1. I want to set up my car to handle as best as it can for road racing and optimize for control and good lap times (Laguna Seca primarily, as well as Sonoma, Thunderhill, etc).
Goal 2. I want to avoid rubbing in any situation (fender or inside).
Given those two goals is the right setup:
1. Keep performance package, Get EC-7R 17x9" +35
2. Swap to coilovers, Get EC-7R 17x9" +42
3. Swap to coilovers, Get EC-7R 17x9" +35
4. Something else entirely? Part of me is still debating grabbing a 17x8 wheel for ease of fitment but suspect the loss of the additional inch would negatively impact goal 1.
I probably should have started this discussion off with the fact that I am open to swapping away from the PP and buying coilovers especially if it improves outcomes for my two goals above. My budget on this project is not huge but I don't mind spending especially on wheels/tires/suspension given the car's intended use (track/fun).
Old 02-20-2021, 09:44 AM   #33
jflogerzi
jflogerzi's Avatar
There is nothing wrong with running 17x8 and keeping your current PP setup. There are several options to get camber without getting coils. Peddler top hats plus camber bolts is a good combo. 17x8 can run up to 245s but 235s are a better fit. Now of you want to experiment with something larger than 245s you should just go option 3 now
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post:
abyssFT86 (04-21-2021)
Old 02-22-2021, 03:44 AM   #34
timurrrr
timurrrr's Avatar
Drives: 2022 GR86
Do you plan to run with 86Drive Challenge?
Have you considered intentionally limiting yourself to the Stock class for now? Or at least the Street class?
"As best as it can" will probably require higher grip tires, but that might be counter-productive for a beginner (I don't know your experience level).
Their Street class is very competitive and my experience with them has been very positive.
Don't know about other tires, but GT Radial SX2 245/40R17 will rub at least in one place no matter what you do. It's not too big of a deal.
But if you want to minimize that I'd recommend et35 over et42, and plenty of camber in the front (again, -3º and even more front camber will only add grip).
Old 08-05-2021, 10:05 AM   #35
abyssFT86
Thanks @timurrrr and @APEX Race Parts. I got the 17x9 +35's and couldn't be happier. The +35 offset looks great with no spacers required (do need adjustable rear LCAs or camber bolts). Running about -3.0 in the front and -2.0 in the rear.
Particularly love the clean look as well as color options (the gold in particular stood out to me and looks fantastic). For a track car I really like the 17's, the size looks great and not too small. Wouldn't hesitate to go 18's either if saving the few extra ounces is not a concern. Folks at Apex were super knowledgeable and helpful.
The Following 5 Users Say Thank You to abyssFT86 For This Useful Post:
Busybee (09-20-2021), Cephas (08-05-2021), jflogerzi (08-05-2021), Racecomp Engineering (08-05-2021), timurrrr (08-05-2021)
Old 08-05-2021, 10:26 AM   #36
jflogerzi
jflogerzi's Avatar
Looks good! Gold and wrb never a bad combo
Old 08-05-2021, 11:32 AM   #37
APEX Race Parts
Those look amazing on your car!! Thanks for posting! If you're ever interested, we would love to add your pics to our Flickr page for forum/social media postings and to help future customers get a better idea of appearance before ordering. The best email to send them to is expert@apexraceparts.com. Thanks for running APEX wheels!
-Ian
Old 08-05-2021, 02:29 PM   #38
abyssFT86
-Ian
Will do! I'll grab some photos with a better camera sometime when the car is clean and send them along :-)
The Following User Says Thank You to abyssFT86 For This Useful Post:
APEX Race Parts (08-05-2021)
Old 08-05-2021, 02:51 PM   #39
APEX Race Parts
Sounds like a plan! Be sure to include your IG or social media accounts if you'd like us to credit you when we post the images. Thanks again for the purchase!
-Tom
Old 02-11-2022, 05:50 PM   #40
APEX Race Parts
We've got a lot of 17" and 18" Forged EC-7R wheels in stock and ready to roll for the 2022 track season. Check out the aggressive 18x9.5" setup below with 265 tires
18" EC-7R in Brushed Clear
Wheels: EC-7R 18x9.5" ET40 in Brushed Clear
Tires: Nexen N Fera SUR4G 265/35-18
Suspension: AST w/ camber plates
Alignment: -2.7º front, rear is maxed out with stock components
- Ryan
SuperTom (02-12-2022)
Old 04-11-2022, 01:06 PM   #41
Yoshoobaroo
TRACKBREAD
Yoshoobaroo's Avatar
Any updates on 2022 fitments?
Old 04-11-2022, 02:12 PM   #42
Code Monkey
Drives: Subaru BRZ
2022 + Radi-CAL BBK?
Code Monkey is offline   Reply With Quote
► APEX | Flow Formed Lightweight 5x100 86/BRZ Wheels - Built to Perform APEX Race Parts Wheels and Tires 51 03-22-2023 11:45 AM
► APEX | 17” & 18” Forged EC-7R Wheel Group Buy APEX Race Parts Wheels and Tires 24 04-19-2021 08:00 PM
► APEX | NorCal 86/BRZ Needed For Photoshoot With Our All-New Forged EC-7R Wheels APEX Race Parts Northern California 3 07-06-2020 04:05 PM
► Styluz Wheels ► 17x7 18x7.5 5x100 ► In Stock ► Free Shipping FM Wheels Wheels and Tires 2 08-01-2013 05:18 PM
