Old 09-28-2020, 06:08 AM   #701
Bunny
Originally Posted by WolfWings View Post
205/65R16 is a size I'm seriously considering, having run 205/55R16 for the first 2 years and change of my own Toyabaru. No rubbing issues at that size I take it? I love the look TBH.
We haven’t had any issues with them. It has completely changed the feel of the car. All for the better. We just try not to take too sharp of turns when it can be helped.
Bunny is offline   Reply With Quote
Old 09-28-2020, 09:17 AM   #702
WolfWings
WolfWings's Avatar
Drives: 2018 Subaru BRZ Premium, Blue
Yeah I wish our cars could QUITE fit 215/65R16's but yeah that looks marvelous.
WolfWings is offline   Reply With Quote
Old 10-20-2020, 09:32 AM   #703
koukiboss
Drives: 15' FRS
Love breaking out my 2.5RS wheels for winter
koukiboss is offline   Reply With Quote
The Following 5 Users Say Thank You to koukiboss For This Useful Post:
FLIPDADY (11-01-2020), NLSP (10-20-2020), SuperTom (10-24-2020), Wally86 (10-20-2020), why? (10-22-2020)
Old 11-01-2020, 01:20 AM   #704
blackstripe77
Can finally post to this thread - I don't plan on keeping this setup but I'm really liking how this looks. Some iPhone pics from when I had them installed.
blackstripe77 is offline   Reply With Quote
The Following 5 Users Say Thank You to blackstripe77 For This Useful Post:
bcj (11-01-2020), FLIPDADY (11-04-2020), grumpysnapper (11-01-2020), NLSP (11-02-2020), venturaII (11-13-2020)
Old 11-01-2020, 08:11 AM   #705
grumpysnapper
grumpysnapper's Avatar
Looks fantastic!
grumpysnapper is offline   Reply With Quote
The Following User Says Thank You to grumpysnapper For This Useful Post:
venturaII (11-04-2020)
Old 11-04-2020, 02:54 AM   #706
blackstripe77
Sorry - realized I failed to list the specs!
These are stock GB5 Legacy GTB wheels in 16x6.5+55 with 25mm spacers. 205/55R16 Bridgestone RE003s are mounted.
I'm really digging this look, but am not looking forward to having to clean brake dust out of those spokes. The conservative fitment is also exactly what I was looking for, but I'm not too keen on running 25mm spacers long term. S Will see how it goes. If I love my next set up this much then hopefully these will find a new home.
Old 11-04-2020, 10:56 AM   #707
venturaII
Only users lose drugs.
venturaII's Avatar
Drives: All the time
So that's effectively a 16-6.5 +30ET. Very nice fitment, and a perfect size for the 205/55. If you eventually move up to a 225/50, a 7" rim is all you need.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
venturaII is offline   Reply With Quote
The Following User Says Thank You to venturaII For This Useful Post:
blackstripe77 (11-05-2020)
Old 11-05-2020, 06:32 PM   #708
ymshulman
Drives: '17 BRZ
Since you're all running 16's on your cars, maybe you can advise me on something?
I've been looking to get a set of 205/55/r16 for the winter - and budget-wise, am looking at used wheels.
Found someone selling pretty new winter tires 215/55/r16. He's not sure about the width, though. They did come off of a Subaru, but not a BRZ.
Would such wheels for sure fit with thinner 205 tires, a few seasons down the line?
I've been searching online, but I'm pretty new to everything about wheels.
ymshulman is offline   Reply With Quote
Old 11-05-2020, 06:43 PM   #709
FLIPDADY
FLIPDADY's Avatar
Drives: 2015 Subaru BRZ Sport Tech
I'm running Impreza STi Version 6 wheels on my BRZ 16x6.5 wrapped in winter rubber 225/55R16. They originally came stock with 205/50R16.
The 205/55R16 should fit no problem on those wheels.
Do you have pics of the wheels?
Sent from my LM-G900 using Tapatalk
FLIPDADY is offline   Reply With Quote
The Following User Says Thank You to FLIPDADY For This Useful Post:
ymshulman (11-05-2020)
Old 11-05-2020, 06:49 PM   #710
anticubus
Drives: 2017 Toyota 86
205/55R16 and 215/55R16 should fit on them just fine. Both section widths tend to have a max rim width of 7.5", and a 205 will fit well on the lower end of a 215's rim width range (~6", that's fuel economy sizing territory these days).
Since I like throwing my hunches out there, my bet is the rims are 6.5" width since that's a common OEM sizing. IIRC the stock 16" BRZ rims (International markets only) are 6.5" wide and shared with a bunch of their other lower-spec models.
anticubus is offline   Reply With Quote
The Following User Says Thank You to anticubus For This Useful Post:
Old 11-05-2020, 06:50 PM   #711
NLSP
NLSP's Avatar
Drives: 2014 Ultramarine FR-S
215/55/16 have a wheel width range of 6" to 7.5".
205/55/16 have a wheel width range of 5.5" to 7.5".
So based on that, you should be fine. Most 16" wheels with a 5x100 bolt pattern usually have a width of 6.5" or 7".
The size of the wheel might be stamped on the inside of the wheel if they can check.
NLSP is offline   Reply With Quote
The Following User Says Thank You to NLSP For This Useful Post:
Old 11-05-2020, 07:10 PM   #712
ymshulman
Drives: '17 BRZ
Thanks for all of your replies! I'm attaching a photo - they aren't stock Subaru wheels, they were just on one before (so I know the 5x100 pattern is accurate). He says they're "ASA JH3 Revolution" wheels.
Old 11-05-2020, 07:12 PM   #713
FLIPDADY
FLIPDADY's Avatar
A few years ago I ran the same style ASA wheels from a Legacy but in 17"
Old 11-05-2020, 07:27 PM   #714
NLSP
NLSP's Avatar
If they can flip a wheel over and look at any engravings on the back of the spokes, most wheels should have the size and offset stamped.
Wheel Directory: Styluz S006 18x7.5 +40 Pavel Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 23 01-22-2014 04:16 PM
FS [SYD] 16 inch GT wheels and tires! luv85 Australia Classifieds 3 11-04-2012 06:15 AM
Help! Two 10 inch vs One 10 (or 12) inch cyntage Electronics | Audio | NAV | Infotainment 7 09-27-2012 11:20 PM
I need 19 inch wheels today! benqld7 AUSTRALIA 16 08-07-2012 08:33 AM
16 inch wheels for the base model!!! Blokatos Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 12-07-2011 11:17 AM
