02-18-2020, 05:48 PM | #365 |
Drives: 13 White MT FR-S
After I send it and it didn’t break it’s good
02-19-2020, 01:22 PM | #366 | |
Drives: C5 Corvette, '17 Toyota 86, Jeep XJ
My drilling was 2 brackets that hold up the fenders higher, The Radiator T is mainly for attachment points with the radiator, headlights and hood lock |
02-19-2020, 01:25 PM | #367 | |
Any issues with the hood latch only using the Top 2 bolts? |
02-19-2020, 01:38 PM | #368 |
well my issue is with the header I run you have to remove the t brace to take the header on and off, so after getting frustrated with it I just decided to lose it. I really can't see there being that big of an issue, and if there is I will cross that bridge if it happens.
The Following User Says Thank You to ML For This Useful Post: | SuperTom (02-19-2020) |
02-19-2020, 04:33 PM | #369 |
Drives: Scion FR-S 10 Series
I was wondering if any one had a precise weight on the oem flywheel and clutch assembly? I tried searching and didn't find anything. Thanks!
The Following User Says Thank You to Jdmjunkie For This Useful Post: | SuperTom (02-26-2020) |
07-24-2020, 11:03 AM | #370 |
Late to the thread but have been on the same weight savings train Anyone have the weight of the wiper motor, arms & hardware by chance?
07-24-2020, 11:15 AM | #371 |
about 7 lbs
The Following User Says Thank You to ML For This Useful Post: | Berserker (07-24-2020) |
08-27-2020, 02:54 PM | #372 |
JHerbert Racing
Drives: 2013 Scion FRS
I had a chance to drive a innovative supercharged FRS around a track I am very familiar with. (1000+ laps). The SC FRS had the full interior and had not gone to any length to reduce weight. My car is a fully gutted track car weighing 2625 with me and a quarter tank with a catless header and tune. The performance difference was dead even except I can drive further into the corner with my car. I would go as far as saying my car would win a drag race between the two.
Just thought it was fun and you guys would appreciate it. Keep on removing every pound. It is worth it.
The Following 7 Users Say Thank You to Takumi788 For This Useful Post: | Code Monkey (08-27-2020), ML (08-27-2020), new2subaru (08-27-2020), Ohio Enthusiast (08-27-2020), Pat (08-27-2020), Simmons (01-05-2022), SuperTom (08-30-2020) |
08-30-2020, 12:32 AM | #373 |
Drives: '15 BRZ RA
I have a BRZ which is a weekend fun car. The total weight savings is in the range of 184 lbs without removing the interior. Including other mods like a tune and changed final drive ratio the difference is very noticeable. I am considering buying now a BRZ as a daily commuter. Do I plan to do the same? Answer is No. Too much inconvenience. I'll keep everything stock. So, it depends the case and usage.
10-07-2020, 09:05 PM | #374 |
I might get some shit for this one but...two pieces of metal, one on each side under the rear quarter glass have been cut out with a spot weld bit. I can't find my scale but I'd say probably about 2-3 lbs. I would not recommend doing this without a cage. But I'm looking for more small pieces like this to cut out. The higher the better.
12-07-2020, 11:04 PM | #375 |
got a number of things off the car recently pictures upon request
ABS = 84oz abs bracket 17.5oz abs circuit 20.5oz abs motor 46oz brake master cylinder with res 21oz brake booster 86oz clutch master cyl + lines + slave 38.5oz glove box frame 25oz clutch + brake pedal assyembly 139.5oz various bag of wires and tape from cleaning cut interior wiring harness 30.5oz
01-14-2021, 07:12 AM | #376 | |
Drives: ADM Toyota 86 GT
Sent from my CPH1979 using Tapatalk |
The Following 2 Users Say Thank You to Snake For This Useful Post: | ML (01-14-2021), StraightOuttaCanadaEh (01-14-2021) |
02-28-2022, 10:01 AM | #378 |
Drives: 22 BRZ limited
Some sort of imageshack issue, replacing his pictures.
Tags |
diet, heavy, light, reduction, weight |
Similar Threads | ||||
So what is the official weight? | brillo | Scion FR-S / Toyota 86 GT86 General Forum | 76 | 05-03-2020 05:11 PM |
Official Weight Reduction Thread - Sort of... | merlin2111 | Off-Topic Lounge [WARNING: NO POLITICS] | 77 | 10-07-2012 05:09 PM |
2012 Geneva - Toyota GT86 in Black, Blue, White, Orange. Official weight & 0-60 Shown | Hachiroku | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 124 | 05-28-2012 12:20 PM |
Official JDM BRZ weight and MPG | ayau | BRZ First-Gen (2012+) -- General Topics | 50 | 02-08-2012 02:04 AM |
Official MMA Thread | zigzagz94 | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 12-15-2009 10:59 PM |
