Old 05-28-2024, 08:23 AM   #295
autoracer86
autoracer86's Avatar
Drives: Toyota GT86
Originally Posted by EdBoy View Post
another question, has anyone installed these with the whiteline subframe bushings? gonna tackle them sometime this week when i have time
I have the superpro subframe bushings but they were installed a while back.
If you plan to do everything at once my suggestion would be to do the bushings first and installed the mod when it's time to install the subframe bolt.
Take your time as you will need to lower the subframe a bit. If I recall correctly you should only need to loosen 1 bolt at a time. I had loads of notes and read a lot of tips and tricks before doing the install lol
autoracer86 is offline   Reply With Quote
Old 05-29-2024, 02:37 AM   #296
gpvecchi
gpvecchi's Avatar
Do you know if it's compatible with the TRD member brace set?
gpvecchi is offline   Reply With Quote
Old 05-30-2024, 04:27 AM   #297
autoracer86
Drives: Toyota GT86
It looks like the rear brace bolts directly to the subframe bolt. Same as the MCA mod. Did the trd brace kit use a longer bolt ?
I guess it could work with the right combo of bolts and washers/spacers but without better pictures it's hard to say.
Old 05-30-2024, 05:23 AM   #298
gpvecchi
gpvecchi's Avatar
Yes, the brace set has a longer bolt. Furthermore, the thickness of the MCA bracket lowers the attach point, so I'm not sure the TRD brace will sit in the right place.
The Following User Says Thank You to gpvecchi For This Useful Post:
autoracer86 (05-30-2024)
Old 05-30-2024, 05:54 AM   #299
gen3v8
30 minute maintenance
gen3v8's Avatar
Drives: My18 wrxsti
Yes a bit of a fiddle but they installed and have been good.
gen3v8 is offline   Reply With Quote
Old 06-01-2024, 03:34 AM   #300
EdBoy
Driver
EdBoy's Avatar
Drives: 16 Subaru BRZ
good to know, i'll fiddle with it since its been there for 7 years.
BRZ Build Thread
See you space cowboy...
EdBoy is offline   Reply With Quote
Old 06-04-2024, 05:05 PM   #301
RToyo86
RToyo86's Avatar
Drives: 17 Asphalt 86
Went to swap pads and wheels and noticed the hand brake cable is a touching/rubbing on the bracket that bolts to the trailing arm.
Anyone else experiencing this or have a solution? Was considering bending it but want to get opinions first.
Old 06-04-2024, 05:08 PM   #302
Sevs753
Sevs753's Avatar
Drives: BRZ, Canyon
The instructions that came with the traction mod for me said to just remove that bracket. They dont believe it is necessary due to how stiff the cable is.
Sevs753 is offline   Reply With Quote
The Following 2 Users Say Thank You to Sevs753 For This Useful Post:
norcalpb (06-05-2024), RToyo86 (06-04-2024)
Old 06-04-2024, 05:40 PM   #303
autoracer86
Drives: Toyota GT86
Yeah due to the change in height it’s going to touch. It’s a pretty thick cover over the cable so I just left it. Removing it or bending it is probably the only real option
Old 06-05-2024, 07:02 AM   #304
DocWalt
DocWalt's Avatar
Drives: '22 BRZ
I bent mine. It will touch my 17x10s without it
DocWalt is online now   Reply With Quote
Old 06-05-2024, 11:20 AM   #305
RToyo86
RToyo86's Avatar
Pulled them off while getting RS4s mounted on stock wheels. I'll keep an eye on it when I swap back to my 17x9s
Old 06-05-2024, 07:53 PM   #306
whataboutbob
AutoX-10/10ths every run
Mine have been gone since I ran 295 A7s at one point.
Build thread:Here
Old 06-09-2024, 03:56 AM   #307
EdBoy
Driver
EdBoy's Avatar
question, how'd you guys get the trailing arm bolts centered. i couldn't center the bolt no matter what i tried to get it done earlier. i read its a tight fit with the whiteline subframe bushings already installed but dang this is working my brain
BRZ Build Thread
Old 06-09-2024, 04:47 PM   #308
autoracer86
Drives: Toyota GT86
I had the front loosely installed then pulled back on the rear suspension assembly to get it close then used a screwdriver to get it the rest of the way.
I didn’t find it too troublesome if I’m honest maybe 2 mins a side. Hope you can get it going!
Search this Thread:
Advanced Search
Needed opinions: Does debadging "Subaru" and "BRZ" cheapen the car? davidchoi Cosmetic Modification (Interior/Exterior/Lighting) 49 11-22-2014 10:17 PM
"Clicking" or "knocking" caused by rear seat pull down lever. husker741 Issues | Warranty | Recalls / TSB 6 11-27-2013 02:30 PM
"My Dealer told me {insert dumb idea}" (was "Toyota/Subary Partnership Cancelled?") levifig BRZ First-Gen (2012+) — General Topics 48 08-09-2013 06:34 PM
Factory suspension "sticktion" andrew20195 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 1 04-02-2013 02:49 PM
"Official" Suspension/Brake Thread NYC BRZ Suspension | Chassis | Brakes -- Sponsored by 949 Racing 27 06-27-2012 09:14 PM
