09-15-2015, 10:14 AM | #267 |
Site Moderator
Drives: Stuff
Warranty so OEM.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
09-15-2015, 10:21 AM | #268 |
Drives: 2013 frs whiteout
I just replaced mine a week ago and went to the track on last friday with no trouble, I bought it online and replaced it myself because I also just put in a flex fuel system and tune so I didnt bother going to the dealership for warranty. It was a pretty easy job to do using info from this thread. thanks to all who have posted before.
09-15-2015, 08:41 PM | #269 | |
09-15-2015, 10:28 PM | #270 |
Is there a better revision of the stock part, or am I going to be looking at replacements again if/when another OEM fails?
I'm only getting the CEL intermittently, but it seems to be triggered pretty easily on a track now. I had it once before, went away and never came back. Now I'm ~9k km's out of warranty and it seems more persistent. I'm due for plugs anyway, so it's gotta come apart to get them out. I'd like to avoid buying a full set of Okada's if possible, but if the OEM ones will continue to fail I'd also rather avoid doing this on a regular bassis.
09-16-2015, 12:21 AM | #271 | |
09-17-2015, 07:40 AM | #272 |
CIOCCA SUBARU shipping was only a few days I got it from this thread somewhere
09-17-2015, 11:51 AM | #273 | |
The code is clearing itself after a couple drive cycles on the street, so I'm probably going to leave it alone until the spring. It comes back by the end of my warm up lap every track session though. It's not logging any hard misfires, and I can't really feel anything different. It feels a bit down on power, but I'm overdue for plugs so that could be a contributing factor too.
09-18-2015, 09:22 AM | #274 |
Drifter-Wannabe
I've been having misfires under load on my car (with full blown turbo) for months now, assumed it was from a wonky tune. Got a completely different tune from a completely different company, and I'm still misfiring under load. Put that together with the fact that I've been getting P0351 occasionally at WOT, and I think I've finally figured out what the issue is -_-
It's strange though, I see tons of people here complaining about the code, but no one talking about negative symptoms as a result of it. Could it just be that mine has gotten really bad over time, or could it be something else in addition to the coil pack that's causing my issue (spark plug perhaps?) Cars suck. |
09-19-2015, 12:58 AM | #275 |
Drives: Ultramarine FR-S 6MT
I have Ignition Coil B code. It popped up a couple of times while WOT, and has gone away, however today it popped up again. I cleared it with my phone app and went WOT again, and the car just wouldnt go, i feel like i have maybe 130hp. Im at 93,000 miles and have a very aggressive tune (28 degrees). Ive always had a little backfire under load at low rpms occasionally. Also the car sounds quiter and oddly even a little better. However there is DEF something wrong and i have yet to get it looked at. I will update when i know exactly whats going on. Im no longer under warranty so it may be spendy .
09-21-2015, 10:14 PM | #276 | |
Drives: bmw
stock plugs for me. swaintech ceramic coated header, 2 foil covered packs, e85, track kicked off cyl 1 today. cyl 1 previously replaced end of may. cyl 3 replaced beginning of august. cyl 1 has only ever known the life of e85, a coated header, and foil on it's head... if it's heat related, apparently this isn't enough...
PointMeBy - auto enthusiast / 86 / car blog - https://www.pointmeby.com
IGoByPlane - travel/credit/auto experience blog - https://www.igobyplane.com |
09-23-2015, 09:03 AM | #277 |
Drives: 2013 SWP BRZ
OK So I've replaced the spark plug in Cylinder #2 which has been giving me issues (ignition coil code and misfire code), so far so good - 2 days on track at Barber and no CEL.
2013 SWP BRZ Build Thread: http://www.ft86club.com/forums/showthread.php?t=38781 |
09-28-2015, 03:12 PM | #278 |
09-29-2015, 12:09 AM | #279 |
Drives: BRZ Ltd WRB, MT6; '91 M5; '89 911
Remote Placement?
Since the problem seems to be heat related, what if the coil packs could be mounted remotely, away from the exhaust heat?
Feasible? |
09-29-2015, 11:58 AM | #280 |
Drives: bmw
how long does it take you to trash a coilpack in the past? seems to take me over 10 track days (intermediate)
Similar Threads | ||||
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset | GC GTS Aero Kit | Australia Classifieds | 16 | 03-22-2013 05:49 AM |
Which Markets have "GT86" and "Toyota" badges on trunk? | Tanuki | Scion FR-S / Toyota 86 GT86 General Forum | 20 | 02-10-2013 05:23 PM |
Anyone else try running "square" tires on "staggered" wheels? | hamlet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 21 | 12-19-2012 12:59 PM |
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
Shutting off your "key-in-with-door-open" beeper -- it's very easy | avusblue | Cosmetic Modification (Interior/Exterior/Lighting) | 2 | 08-13-2012 05:29 PM |
