10-19-2021, 02:33 PM | #575 |
VIR Full - 2:07.88
Kyle H. - #89 STX
The Following 2 Users Say Thank You to M0nk3y For This Useful Post: | Code Monkey (10-19-2021), waterpanda (06-29-2022) |
11-05-2021, 01:42 PM | #576 |
Track: Gingerman
Car: 14 BRZ Mods: 17x8 Konig Flowforms with 225/45R17 BFGoodrich G-FORCE COMP 2 A/S PLUS all season tires. Hawk HP+ Sport/Track pads with Stoptech 600F brake fluid. NVIDIA cat back, high flow 2nd cat and overpipe. Camber bolts. -2deg camber in front, -1 in rear. |
The Following 2 Users Say Thank You to kodasaurus For This Useful Post: | downshiftxlr8 (11-16-2021), Stonehorsw (11-14-2021) |
11-10-2021, 10:30 AM | #577 |
Drives: 2020 86 Hakone
Streets of Willow 1:28.504 (Transponder Time)
Still learning all the tracks out here really loved the repaved surface. https://www.youtube.com/watch?v=G4k3C6xkvW8 |
11-14-2021, 03:06 AM | #578 | |
Drives: 2022 GR86 (was 2013 BRZ)
Hey, I was there too! (In the blue BRZ). Nice to meet you, and I hope you make it a 86Cup event soon.
The Following User Says Thank You to treedodger For This Useful Post: | downshiftxlr8 (11-16-2021) |
11-14-2021, 03:38 PM | #579 |
Barred
Drives: My18 wrxsti My19 brzts
^^^ L&R G`s seem reversed?
Wait until my Flex capacitor hits 88
The Following User Says Thank You to gen3v8 For This Useful Post: | treedodger (11-14-2021) |
11-14-2021, 10:26 PM | #580 |
11-20-2021, 06:11 PM | #581 |
Looking for some feedback. I think the car has a bit more but any help would be great. Yes I know I need to work on my hand placement
2:05.7 Buttonwillow 13CW Car Specs in Sig. Tires have 4 events on them. E85 was only at 45-50% for this run.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | downshiftxlr8 (11-20-2021) |
11-20-2021, 07:17 PM | #582 | |
This is the exact time I'm aiming for next weekend! I like how you setup bus stop. |
The Following User Says Thank You to downshiftxlr8 For This Useful Post: | jflogerzi (11-20-2021) |
11-21-2021, 10:25 PM | #583 | |
Depending on how much risk you want take, it looks like you could get a little closer to the limit in the corners. The best way to get more comfortable with larger slip angles in to spend some time on the skidpad/drift course/Fastsideways.com/ learning to get the car into oversteer on corner entrance and exit. You can also do this on some of the safer corners on track, but it just takes longer. You need to practice skid recovery until it's automatic. These car control skills will make you safer, and faster. Of course, hand placement will also help you find center, after a big oversteer event! Getting ride-a-longs with faster drivers is also helpful to see what they do differently. You should joint the rest of the 86's at Thunderhill East on Dec 11th w/ SpeedSF.com Have fun.
11-22-2021, 12:44 PM | #584 | |
02-01-2022, 11:58 AM | #585 |
At the track
Drives: '14 FRS - Former e92 M3
Made it to COTA this past weekend. Really makes me want to add power to the car, but for NA tuned this feels pretty solid.
Track: COTA Car: 2014 FRS Mods: Lots to list, most in my signature, full STX autocross setup plus a Zebulon TT5 spec wing and set of scrub Yokohama A005 slicks. Time: 2:36.04 There's more time out there using 2nd gear in a couple more places, but not something I'm super comfortable with yet. 2nd time bringing the car to COTA so always have more things to do/learn.
#ladydriven Nasa TT4 FRS // JRZ RS Pro // Karcepts Sway Bars // K24 Swap (in Progress) // AP Endurance BBK // Cobalt Friction brake pads // Safeplace Auto
03-12-2022, 12:42 PM | #586 |
Drives: Ford Fiesta ST, 2022 Subaru BRZ
Track: Motorsport Ranch Cresson
Car: 2022 Subaru BRZ Mods: Ferodo DS1.11 pads and Vorshlag camber plates currently at -2 degrees, otherwise stock with a couple track days on the Michelins already. Notes: This was actually my second fastest lap, I got a 1.31.4 a little bit earlier that day. Still plenty of room for improvement, if I can get a little more brave using less brake in especially the faster corners, amongst some other things I think I can squeeze in a low 1:30 or high 1:29. |
The Following User Says Thank You to Rcode For This Useful Post: | nissanfanatic (01-07-2023) |
04-18-2022, 12:03 AM | #587 |
Drives: 22 GR86
first time at Mid Ohio using the GR86. I've done Mid-O once with an STi about 12 years ago and with my Camaro SS1LE last year. Was really fun once the rain went away and the track dried up! The automatic definitely hurts this car on the track but MUCH better once I got comfortable putting it into manual mode and knowing which gears were appropriate at certain speeds/corners (it still blocked me a lot because i don't think it likes to downshift into a high rev?).
Pilot Sport Cup 2 tires Gloc R12 pads and RBF 600 fluid Best time ~1:52 best guess flipping through my videos.. Next: Garmin Catalyst! (I had a mic on my license plate frame but i think it actually sounded better without the external mic and just picking up audio from the cabin.) |
04-20-2022, 11:57 PM | #588 | |
Similar Threads | ||||
Track Brake Pad Discussion Thread | CSG David | Tracking / Autocross / HPDE / Drifting | 420 | 02-06-2023 08:55 PM |
S2000 vs BRZ at the track: track oriented discussion | CSG Mike | Tracking / Autocross / HPDE / Drifting | 33 | 01-13-2013 06:54 PM |
Mike's track videos. | CSG Mike | Tracking / Autocross / HPDE / Drifting | 2 | 08-16-2012 04:00 AM |
Scion Canada FR-S Track Day Videos! | DjDATZ | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 22 | 08-13-2012 11:51 PM |
Track/Racing Discussion | Allch Chcar | Tracking / Autocross / HPDE / Drifting | 9 | 05-26-2012 04:39 PM |
