Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
#15 |
Drives: 2K19 GT86
#16 | |
Drives: Crapcan
Try calling exhaust shops in your area and asking if they know anyone that does it. Some of the commercial coating companies in my area do offer it, but it is not readily apparent that they do. Sent from my iPhone using Tapatalk
The Following User Says Thank You to NoHaveMSG For This Useful Post: | czellers (01-13-2021) |
#17 | |
Drives: 2K19 GT86
Hahaha I may, but i'll be honest.. thats already sounding expensive.. Prob charge me more than the header is worth. |
#18 |
Drives: Then-1977 Celica GT Now-2017 860SE
#19 |
Drives: 86 GT
#20 |
The Following User Says Thank You to gpvecchi For This Useful Post: | Compelica (01-14-2021) |
#21 | |
The GRMN 86 also came with decently sized hood vents so the heat from the header is mitigated quite a bit. GRMN is like STi, they don't have to play by all the production rules with super low volume vehicles.. |
The Following User Says Thank You to PulsarBeeerz For This Useful Post: | czellers (01-14-2021) |
#22 |
IG: Rouge_FRSyg
Drives: 2012 FRS
One option is to make a sort of heat shield using something like Design Engineering Form-A-Shield.
Unlike heat wraps, it still allows the pipes to "breathe" and not trap any oil, grease, or liquids that can damage the pipes while managing engine bay heat. Moreover, you can use the excess sheet to wrap the other pipes like front & mid pipes that contribute to cabin heat and event the muffler/resonator that traps the heat even more. Wrapping these pipes also absorb the pipe's natural vibrations therefore affecting the tone of exhaust. On my 2019 TRD SE exhaust for example, it muffled the mid & high notes leaving behind a bassy hum & also reduced cabin noise. I've tried using high-temp spray ceramic coating for headers before I installed the FT86 UEL & even coated it several times. However, the heat was still significant.
Modding for daily fun & efficiency: FT86UEL, aFe Takeda intake, OFT Stg2, Crawford BPB, DSS al. driveshaft, Beatrush underpanel, DiodeDynamics SS3 fogs, GTR Lighting Ultra Series 2 low beams, Tom's tail lights v1, TRD's (shift knob, door stabilizers, 2019 SE exhaust, lowering springs, & aeros), Verus diffuser & underbody covers, Bilstein B6 shocks, Michelin PS 4S on 18" Enkei PF01, Michelin Alpin PA4 on 18" TRD wheels
#23 |
Drives: 2K19 GT86
#24 | |
Drives: 2K19 GT86
#25 |
#26 | |
The stock heatshields are for cat, that can reach very high temperatures. No cat, lower temperatures. |
#27 |
Drives: Crapcan
Hood ducts make a big difference in under hood, coolant and oil temps. Even with a non catted header. I am running uncatted with a ceramic coated header and noticed about 10F difference in oil temp in a 20min track session.
#28 |
Drives: 2017 subaru brz
I won't comment on any of the downsides of wrapping the headers as I have no experience with its potential effects, however I did notice that after wrapping my new catless headers, it does feel like the heat went down significantly within the engine bay. May or may not be placebo, but I feel it reduces heat even better than when I had my stock headers/heatshield.
How to cure silicone coating for exhaust wrap? | Stomachbuzz | Engine, Exhaust, Transmission | 9 | 01-07-2020 02:11 AM |
Wrap exhaust side pipes on turbo? | drz400dude | Forced Induction | 3 | 05-29-2017 05:21 PM |
Impressive Wrap Vinyl wrap Thread Discounts For Forum Members | ImpressiveWrap | Southern California | 4 | 05-26-2017 02:59 AM |
Good carbon fiber vinyl wrap for ABS spoiler to wrap it? | dssence | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 02-07-2014 05:31 PM |
