Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
01-22-2014, 03:02 PM | #15 |
Boosted
Drives: Not a supra....yet
01-22-2014, 04:01 PM | #16 | |
Drives: Firestorm FRS
I'd rather be ready to move then save what will probably be only a couple thousand miles of it's life. |
01-22-2014, 05:36 PM | #17 | |
Drives: MDX, Camry
What would you do then? Shift into 1st gear and keep both clutch and brake down? If real emergency happens, you might release clutch before step on gas.
01-22-2014, 05:36 PM | #18 | |
Drives: Some rust bucket
01-22-2014, 05:42 PM | #19 | |
Yes and if I leave it in neutral I might forget to put it in gear and just rev it. Or I put it in gear and I move too fast the clutch might be released too quick anyway. I'll take less steps and less risks any day. Typically when I am stopped on level ground I am not holding the brake anyway, the car will stay right where it is because the clutch is in. In which case my foot is already covering the gas, again risk reduced. I am not sure if this is the preferred practice (it may be horribly bad), it is just a habit I picked up. Sent from my iPad using Tapatalk |
01-22-2014, 05:48 PM | #20 | |
01-22-2014, 06:07 PM | #21 | |
I did not claim it to be the best way, you may be completely right in that matter and I will not argue on that. And yes I do watch my mirror when someone is coming up behind me while I am stopped, and it has saved me a couple times from minor fender benders. Optimally yes you can try to get out of the way if possible, but obviously often times it is not possible, and just standing on the brake is your only option. Either way I would rather have the extra control/less steps to get moving again. I feel it is generally a good idea to have the car in the right gear for the situation, including when stopped. When driving in Boston you gotta keep your eyes wide and your foot on the gas, people drive like complete assholes so you really have to watch yourself. As far as premature wear I'm not sure What kind of impact it has, it, as long as the clutch is all the way in I am not worried. I have yet to wear out a clutch before 70-80k, and my father (who taught me this way) is currently still on the original clutch after 145k miles in his Corolla. Sent from my iPad using Tapatalk |
01-22-2014, 06:17 PM | #22 |
Drives: car
I think the throwout bearing will need to be replaced before the clutch.
I plan on installing a new clutch around 60k, regardless of if it's still in working condition, I'd like a fresh clutch. I'll probably get it done in the same 60k service when I get my spark plugs replaced. |
01-22-2014, 06:20 PM | #23 |
Drives: 2013 Toyota 86 GTS, Marine Blue
I just hit 32k kms on my 86 about an hour ago and I drive it everyday for work in bumper to bumper traffic 8 hours a day and when there's a gap, in the mind numbing traffic or a dead quiet road I'll drive it hard, to enjoy going above 40km/h !!
Long story short, I have had no issues with the clutch engaging, disengaging or no noises (as of yet) keep your car up to its service and hopefully scion, or Subaru or Toyota will truthfully fill you in on when your clutch is dyeing. To add to that, if you have a dyno graph or you know what power your car has (with your mods, if any) and the power is less than the OEM clutch power rating; You can replace clutch parts through the warranty for free 20% window tint, Full DB drive sound system, Trunk & footwell neons, Injen SES, Number plate, reverse, dome LED upgrade, Debadged 'TOYOTA', Injen CAI, Borla UEL headers, ecutek tune w/ racerom, alloy pulley kit soon! 186hp at the wheels best dyno
check out my on-going build here: My blue 86
01-22-2014, 07:04 PM | #24 |
Car Nut
Drives: BMW 335d, Toyota Echo RS, FRS
I've had clutches last anywhere from 160000km to 225000km+ on vehicles I have owned.
01-22-2014, 07:47 PM | #25 | |
Drives: Subaru BRZ Sport Tech Satin White
There should be no emergency while stopped at a light. Obviously, your technique only makes any sense if you are first in line, otherwise it makes no sense. I recommend you rethink this one. |
01-22-2014, 08:04 PM | #26 | |
01-30-2014, 08:48 PM | #27 |
Keep calm and drive on
Drives: 2013 WRB BRZ Limited 6M
All depends on your driving style. Lots of aggressive launches and riding your clutch will wear it quick. Rev-match your downshifts and keep slippage to a minimum. I got over 100k on a stock VW TDI clutch pushing 330tq, 80k on a 400whp LS2 GTO clutch. I expect 125k out of this clutch. I'm at 188whp and don't plan any more power adders.
02-02-2014, 08:36 PM | #28 |
is better than you
Drives: 2013 raven FRS
with me clutch kicking, and launching everyday, who knows. It's lasted 20k miles so far heh
Similar Threads | ||||
Average Gas Mileage | Bach415 | Northern California | 57 | 07-18-2017 09:18 AM |
Average MPG in SoCal? | PradiG | Southern California | 64 | 07-30-2013 05:41 PM |
Garage Life: We bring your dreams to life! | Garage Life | Southern California | 0 | 08-17-2012 07:33 PM |
WHATS YOUR AVERAGE MPG? | imravenit | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 07-10-2012 01:10 AM |
What will the average MPG be? Poll! | SOB | Scion FR-S / Toyota 86 GT86 General Forum | 52 | 04-22-2011 05:48 PM |
