10-20-2016, 06:38 AM | #43 |
Can any of you guys with a stock 2017 log the tune with oft or ecutek or even torque app or some other obd logger just interested to see a third gear full throttle run to redline
if you could log afr, commanded afr, ignition advance, llong term fuel trim, rpm , load, throttle if you have better logging like oft or ecutek then add iam, flkc and fbkc knock parameters toyyota techstream should work as well jist want to see what general afr and timing its runnong and compare it to tables instock tune needs to be new K00C ro D rom thanks |
10-20-2016, 01:19 PM | #44 | |
btr.life
Drives: 2022 GR86
Also, planning to go to the dyno for baseline runs on Saturday if I have time...(HPDE weekend in BMW).
10-20-2016, 06:32 PM | #45 | |
Thanks Im really interested in the stock rom fueling and timing in logs at WOT |
10-20-2016, 11:59 PM | #46 | |
btr.life
Drives: 2022 GR86
Also on datazap.me: 1 through 3 http://www.datazap.me/u/justinco/201...og=0&data=1-13 4 http://www.datazap.me/u/justinco/201...og=0&data=1-13
The Following User Says Thank You to justinco For This Useful Post: | solidONE (11-05-2016) |
10-21-2016, 02:53 AM | #47 | |
Thanks any chance you can log Commanded AFR if that available ? looks like maf v IAM not working so maybe leave one of those out. could you maybe try logging Fuel system Status ( ie closed loop open loop) , instead of Boost. Yep looks like it runs quite lean. other interesting thing is STFT is not 0 as you would expect if it was running on Open loop, maybe it runs closed loop all the time ????? Thanks some things starting to make sense , possibly :-) |
10-21-2016, 05:00 AM | #48 |
Drives: UK GT86
@steve99 listening to me again now? :p
The min open loop value has been raised from 14.0 to 14.4 so in theory it would hold closed loop less, however you can see that the open loop fuel maps are all above 14.4 at lower RPM. Definitely a change in fueling strategy, however a change to full time closed loop would suggest a complete change in the ROM operation and I would expect that a much more accurate and reliable O2 sensor would be required. Other cars that run full time closed loop tend to run true WBO2s I believe, like the GT-R/370Z etc.
.: Stealth 86 :.
10-21-2016, 05:32 AM | #49 | |
haha was always listening mate I can believe 12.5 or so but 13.4 was a bit suspect on. I think that due to being a tailpipe sensor after 2 cats ? I run about 12.2-12.4 petrol and E85. You would think with stft being active its not in open loop, if we can believe monitoring. Or its using a completely differnt fuel strategy, that seems to not use the discovered OL fuel tables, hard to comprehend why you would be 25-30% off target AFR. Maybe those tables now only used in fallback/failsafe mode who knows. The AFR does seem to be remarkably stable though and if logging can be believed stft active all the time be interesting to see ecutek logging. Last edited by steve99; 10-21-2016 at 06:10 AM. |
10-21-2016, 12:36 PM | #50 | |
btr.life
Drives: 2022 GR86
Might get some more logs this weekend, I am also gathering for Shiv as I flashed his Stg1 Beta map this morning.
10-21-2016, 04:34 PM | #51 |
Drives: 17 86
Any smart people know what running E85 in the 17's might bring?
11-05-2016, 08:28 AM | #52 | |
Drives: FR-S Whiteout
Intent > Content
cowardice is the mother of cruelty. |
11-05-2016, 09:13 PM | #53 |
btr.life
Drives: 2022 GR86
Umm, I would have to check, I am not sure.
11-28-2016, 10:32 AM | #54 |
Drives: 2017 86
Bump for an update on the 2017 tunes.
11-28-2016, 02:23 PM | #55 |
btr.life
Drives: 2022 GR86
Tunes are still in beta stage as far as I know, I haven't heard from Shiv since SEMA time frame.
I have been running one of his beta tunes for ~800 miles or so, no problems and good improvement over stock. Ran the car in an autocross a couple weeks ago with the tune as well.
The Following 2 Users Say Thank You to justinco For This Useful Post: | gtengr (11-28-2016), invaliduser (11-28-2016) |
12-23-2016, 11:35 AM | #56 | |
Drives: 2017 BRZ Manual
Is your tune still running good? I just got stage 1 beta tunes from Shiv and may flash over the weekend. Also have OFH but may install that later. |
Similar Threads | ||||
openflash tablet vs ecutek tune | brz23 | Software Tuning | 104 | 07-28-2020 04:36 PM |
Openflash tune problem with brz | sgoldberg01 | BRZ First-Gen (2012+) -- General Topics | 6 | 02-09-2016 01:13 PM |
fi and openflash tune | Hachi6 | Forced Induction | 59 | 11-20-2015 01:28 PM |
OpenFlash-- header tune | mtimney | Forced Induction | 3 | 08-07-2014 03:51 PM |
Top Gear Solutions| OpenFlash Tablet Tune| Stage 1 Tune, Stage 2, Custom and E85 | TopGearSolutions | Engine, Exhaust, Bolt-Ons | 90 | 04-14-2014 08:15 PM |
