10-02-2021, 05:40 AM | #155 | |
Moutain Runner
10-02-2021, 07:32 AM | #156 |
Rust bucket enthusiast
I don't have the underbody trays installed right now either
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block |
10-04-2021, 02:31 PM | #157 |
Well, something I had feared came to happen. Because JDL angles the flange, I can't get the turbo to drain and it's blasting oil out of the turbo seal into the exhaust.
I'm going to set up the oil scavenging pump to see if it puts enough vacuum on the CHRA to draw it through. Not ideal at all. Eventually I will need someone to fix the angle of the manifold flange (or convert to v-band), but my guy is scheduling into late November. Sorry for the sideways picture. Never know how this forum will deal with images.. Here's what I mean-
10-05-2021, 01:51 PM | #158 |
Set up the ol pump today. Made some new -an lines, tightened everything down. Just need to extend the harness for the pump an extra 3 feet and we'll see how it goes!
Ignore the hokey wiring, it was for the halos that are being re-done, I wanted to protect them while the car sat and only had those wire caps nearby
The Following 2 Users Say Thank You to DarkPira7e For This Useful Post: | NoHaveMSG (10-05-2021), villainous_frx (10-05-2021) |
10-26-2021, 11:22 AM | #159 |
While the pump does work as anticipated (proper drain = no smoke) I don't have it in me to go forward with running the car with such a bandaid, it just doesn't make sense.
Only correct solution for this setup is vband so the oil drain can sit at the correct angle. I managed to get my hands on a TiaL Vband .82 housing. Ordered downpipe and header accompanying vband flanges. I truly with I had just bought the turbo hot parts in this configuration to begin with. Now we have to chop up the beautiful JDL artwork... Oh well. Better than having the oil pump fail and causing aeration in the oil. Yes, picture of the shiny housing
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
12-28-2021, 11:41 AM | #160 |
Little update- changed the exhaust flanges which went smoothly. The driver's side exhaust cam sprocket clacks around when VVT enables so we're going to replace it. Thought that maybe it was the break in oil but after pulling the oil and replacing it, replacing the OCV, and have resolved to just changing the sprocket. It only happens as soon as VVT enables so there are only so many things it could be. Ignore the drain line but pay attention to the angle- way closer to straight down than the to flange allows! One victory at a time. Another note- ignore the turbo guard, it'll have a proper filter on. Just don't want bugs or anything getting in there while it's outside
Here's some pre-vvt idling!
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 12-28-2021 at 11:56 AM. |
04-25-2022, 09:07 AM | #161 |
Update!
Took the front cover off to replace the sprocket- turns out that the bolts holding it to the cam had loosened. This was probably a reinstallation error on my part, or a freak accident. In either case, the others seemed fine so the sprocket has been replaced and it's ready to start break-in today Edit: Idling 15 min, no issues, spot on afr. No leaks, so excited
JDL EL Recirc manifold, Boostlab BL58x Turbo w/ T51R, 17x9 ARC-8, IAG block Last edited by DarkPira7e; 04-25-2022 at 11:08 AM. |
The Following 4 Users Say Thank You to DarkPira7e For This Useful Post: |
04-25-2022, 04:40 PM | #162 |
義理チョコ
Congrats!
The Following User Says Thank You to Ultramaroon For This Useful Post: | DarkPira7e (04-25-2022) |
04-25-2022, 08:48 PM | #163 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Congrats! Love seeing this car alive again
The Following User Says Thank You to villainous_frx For This Useful Post: | DarkPira7e (04-26-2022) |
05-03-2022, 04:07 PM | #164 |
Working through break-in. Looking decent so far, 40 miles in!
Modified my Grimmspeed engine cover to fit, looks decent. The TrueFocusFab crash bar requires a lot of modification to fit, much more than anticipated, mine is also off-center slightly, which may have something to do with it.
The Following User Says Thank You to DarkPira7e For This Useful Post: | villainous_frx (05-03-2022) |
05-03-2022, 07:38 PM | #165 |
Drives: '88 Supra 1JZ, '16 FR-S, '23 GR86
Nice!
When you get it dyno'd, you should post the dyno pull so we can hear it whheeeeeeee whoooooshshhs
NARFALICIOUS
Noob Poster 1988 | 2016 |
The Following User Says Thank You to NARFALICIOUS For This Useful Post: | DarkPira7e (05-05-2022) |
05-03-2022, 08:05 PM | #166 |
Drives: Bone stock
Makes me wish I had my turbo installed
Sent from my SM-G998U using Tapatalk |
The Following User Says Thank You to Joveen For This Useful Post: | DarkPira7e (05-05-2022) |
05-05-2022, 08:14 AM | #167 | |
You've got marriage to look forward to! You'll have time to do a build, it's worth the wait. Bucket lists are meant to be done gradually
05-09-2022, 03:10 PM | #168 |
Doing the break in miles, had to capture some t51r noise
Tags |
brz, frs, iag, jdl, turbo |
Similar Threads | ||||
Joel's BRZ - Low Budget Time Attack Build | DIY | Member's Car Journals | 403 | 12-11-2023 05:59 PM |
Cxracing turbo problem | Kalebhall | Forced Induction | 10 | 11-16-2017 07:57 AM |
Tony's Budget Turbo Build | glorydays | Member's Car Journals | 22 | 01-25-2015 11:02 PM |
My boosted build...on a budget | PineappleFriedRice | Member's Car Journals | 95 | 08-17-2014 09:29 PM |
Aznsky's budget STX build | Aznsky | Tracking / Autocross / HPDE / Drifting | 13 | 05-12-2014 08:44 AM |
