Old 10-11-2013, 02:09 AM   #1
speedy racer
Drives: 92 lexus sc300 > whiteout MT FRS
My front turn signal lights not working after shop installed LED DRL bezel
I have no functional turn signal lights after a shop installed LED DRL bezel, They do not work with turn signal, hazard light or keyless unlock. Do you guys think its the fuse TY.
speedy racer is offline   Reply With Quote
Old 10-11-2013, 04:39 AM   #2
SuperGTS
FOXTROT-ONE Founder
SuperGTS's Avatar
Drives: 12 Toyota 86 GTS,13 Subaru Forester
probably the fuse... it's pretty easy to knock it out or something when installing led drl bezels... you could probably try going back to the shop and ask them.
Proud owner of a Satin White Pearl 2013 Subaru Forester and a Pegasus White 2012 Toyota 86 GTS. --> **Garage**
Previous: '05 Evo 9, '05 S2000, '00 Civic, '02 VX HSV, '04 Z HSV, '08 E HSV, '90 EXA Coupé
SuperGTS is offline   Reply With Quote
Old 10-11-2013, 08:33 AM   #3
speedy racer
Replaced the fuse and still no go.
Old 10-11-2013, 10:28 AM   #4
Gen
Drives: Scion FR-S
Have you checked to make sure the lights are in the sockets? It wouldn't be the first time someone left them hanging in the wheel well.
Gen is offline   Reply With Quote
Old 10-11-2013, 11:57 AM   #5
FR-Shadow
FR-Shadow's Avatar
Drives: 2013 Scion FRS
are you referring to LED DRLs in the high beams or LED DRL bars (where the fog lights would be)?
either way the turn signals should not have been touched. Sounds to me like the shop didnt know what they were doing.
The LED DRL in the high beams is just replacing a bulb
the LED DRL bars is literally tapping two wires, power, and inverter wire
FR-Shadow is offline   Reply With Quote
Old 10-11-2013, 02:17 PM   #6
speedy racer
They are idiots like you said they should not even touch signal lights installing led drl bezel
Old 10-11-2013, 05:08 PM   #7
speedy racer
Finally got it corrected, idiots didn`t plug bulbs back in.
BRZ Front and Rear LED Turn Signal Bulbs convoy Cosmetic Modification (Interior/Exterior/Lighting) 23 11-25-2013 07:51 AM
WTB Stock FRS front turn signal housing Yruyur Interior Parts (Incl. Lighting) 0 07-30-2013 12:09 AM
Turn signal lights Brzer Cosmetic Modification (Interior/Exterior/Lighting) 9 10-18-2012 01:36 PM
DIY: front and rear LED turn signal bulbs jjdrivesajazz DIY (Do-It-Yourself) Guides 6 10-15-2012 09:53 PM
