Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
07-02-2020, 10:38 AM | #1 |
September
Drives: 2015 BRZ
Stage 2+ Brz runs like stock
Hello everyone, it’s been awhile since i posted here. I’m having a problem so im hoping we can figure it out together. last night on the way home my CEL came on and i had my OFT with me so i scanned it, came to be P013a. deleted the code and came home. This morning when i started my car i thought something was off, even when driving it doesn’t pull like it used to, the car is a lot louder and feels mushy. I also had pop tune which doesn’t work anymore. anyone have any tips on what to do? i was thinking reflash the ECU.. let me know thanks!!
07-02-2020, 10:58 AM | #2 |
Drives: 13 White MT FR-S
When you clear a code it also resets the all the learned fuel tables and other stuff so you just need to drive it a bit before it feels normal again
07-02-2020, 11:02 AM | #3 |
September
Drives: 2015 BRZ
could it be just that? reason is after i clear the code (last night) the car ran perfectly fine. Another thing is i have an nameless EL long tube header setup and the power doesn’t come in till 3700rpm(def feels the pull after) and now there’s no power coming in anywhere.
07-02-2020, 11:18 AM | #4 |
yup, its really that simple.
The Following 2 Users Say Thank You to ML For This Useful Post: | CSG Mike (07-03-2020), SamtheKorean (07-02-2020) |
07-02-2020, 12:40 PM | #5 |
Drives: 2017 toyota 86
Most likely what above said. Give it about 10 heat cycles / 100 miles to relearn everything.
That code is for faulty 02 sensor. Could just be a one time fluke. If it returns replace 02 sensor. Are your fuel trims good? |
07-02-2020, 02:21 PM | #6 |
September
Drives: 2015 BRZ
what should i look for when checking my fuel trim, on the OFT i can see St fuel trim and LT fuel trim percentages.
07-02-2020, 02:43 PM | #7 |
Combined values shouldn’t be over +/- 10% and individual values shouldn’t be over +/- 10% either.
IE 6% ltft +7% stft = 13% = bad if ltft is say +7% and stft is -4% = +3% = fine (probably needs more time to sort out) If ltft is +12% and stft is -7% = +5% but individual value is over 10% either something is off or possibly still sorting itself out especially if recent reset or recent fill up from different gas station. If trims are consistently off, you may have a vacuum or exhaust leak, or based on that code the 02 sensor is going bad and might be giving bad readings. If aftermarket intake could mean MAF needs scaling. |
07-02-2020, 03:39 PM | #8 | |
September
Drives: 2015 BRZ
07-02-2020, 03:55 PM | #9 | |
friendly
Drives: 17' 86
Fuel trims should almost always be in the window given above, whether you're maintaining speed or accelerating.
Seek comfort in discomfort.
The Following User Says Thank You to alphasaur For This Useful Post: | SamtheKorean (07-02-2020) |
07-02-2020, 04:24 PM | #10 |
For a very quick brief moment like half a second or less fuel trims can swing pretty far on throttle engagement (after being fully closed) or throttle closing (after being open) otherwise in any other conditions/scenarios it shouldn’t be outside that window.
The Following User Says Thank You to 86TOYO2k17 For This Useful Post: | SamtheKorean (07-03-2020) |
07-02-2020, 08:30 PM | #11 |
Drives: 2013 frs red
I would reflash it. Sounds like the cams aren't moving
The Following User Says Thank You to Lantanafrs2 For This Useful Post: | SamtheKorean (07-03-2020) |
07-03-2020, 08:30 PM | #12 |
September
Drives: 2015 BRZ
specially when the ignition timings were retarted i was seeing some high values. guessing the unburnt fuel was causing it to set higher value?
07-03-2020, 08:34 PM | #13 |
Drives: '13 Whiteout
Get a good tuner.
The Following User Says Thank You to TommyW For This Useful Post: | CSG Mike (07-03-2020) |
Similar Threads | ||||
Anyone runs aftermarket header with stock catback? | stlgrym3 | Engine, Exhaust, Transmission | 46 | 03-01-2023 06:14 AM |
If my stock clutch is about to go out should I replace it with a stock or a stage 1? | Bread1 | Engine, Exhaust, Transmission | 6 | 01-28-2018 01:24 AM |
Quick Review-OpenFlash (Dyno Test) - Stock vs. Vishnu Stage 1.0 vs. Vishnu Stage 1.1 | FRSTEVE | Software Tuning | 105 | 08-04-2017 04:48 AM |
P&L Motorsports BRZ / FR-S Stage 1 Turbo Base Kit Runs 12.4@112 | P&L Motorsports | Forced Induction | 28 | 11-20-2013 07:01 AM |
Bone Stock 2013 GT-R runs a 10.7 | 2013GTRNate | Other Vehicles & General Automotive Discussions | 0 | 10-14-2012 05:18 AM |
