02-28-2022, 12:52 PM | #155 | |
Drives: 2018 Subaru BRZ
If you're also looking to get rid of the quick-jack I'll kindly take it off your arms. Save you even more room.
02-28-2022, 01:13 PM | #156 |
Be Kind
Drives: 2020 86
I can put a sticker on the dishwasher that says quick jack if you'd like
The Following 3 Users Say Thank You to Wally86 For This Useful Post: |
02-28-2022, 02:01 PM | #157 | |
Its something /*-*/.
The Following User Says Thank You to spcmafia For This Useful Post: | Wally86 (02-28-2022) |
08-14-2022, 07:58 PM | #158 |
ProCrastinationConsultant
time for a bump!
got a free 18" dishwasher from a customer. sorta an oddball size, so was a long shot when i started looking a few years ago. was going to be tricky, as none of my cabinets are a standard size. going both ways off the sink, i've got 15", 36" lazy suzan units, and then pair of 37" cabinets. i went to the left. the plan? remove the 15" cabinet, then cut down the lazy suzan to fit. cabinet came out simple enough, but turns out my sink "cabinet" is just a facia front panel with a a hacked in raised floor and toekick. wasn't expecting that. ended up salvaging the removed cabinet side panel to make a sink panel side then had to pull apart the lazy susan and 're-size' it to make everything fit. cutting down the rotating assembly of the lazy susan, and marking out how to get the rear panel to re-wrap back around to the front lazy susan cut down. i knew it was going to reduce my space, wasn't expecting this much! but it is what it is... and the finished product of course, no project is without it's surprises all-metal undersink drains, starting to rot out, the 1 is held together and not leaking only by rust/corrosion. needed to re-pipe anyways to get the dishwasher drain in, good thing too, this was already on borrowed time! all piped in and almost read to go! lots of crud in the old setup for some reason i was all set, and celebrating not having any leaks, then everything plugs up and water starts backing up the drain... i knocked some of the sediment somewhere loose re-piping it, it's clogged somewhere. so after all that, NOW i need to call a plumber this week to roto rooter out the line...
08-14-2022, 08:27 PM | #159 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
Can't believe you are single.
08-14-2022, 09:17 PM | #160 |
The Following 4 Users Say Thank You to soundman98 For This Useful Post: |
08-15-2022, 02:47 AM | #161 | |
The Following User Says Thank You to humfrz For This Useful Post: | Wally86 (08-15-2022) |
08-15-2022, 11:15 AM | #162 |
The Following 4 Users Say Thank You to Tcoat For This Useful Post: |
08-15-2022, 04:04 PM | #163 |
The Dictater
Drives: '13 Red Scion FRS
The Following User Says Thank You to Spuds For This Useful Post: | soundman98 (08-15-2022) |
08-15-2022, 04:54 PM | #164 |
¯\_(ツ)_/¯
The Following 4 Users Say Thank You to Sapphireho For This Useful Post: |
08-15-2022, 05:15 PM | #165 |
Well Walmart dishwashers are well equipped even if a bit cheap.
The Following 6 Users Say Thank You to Tcoat For This Useful Post: | humfrz (08-16-2022), NoHaveMSG (08-15-2022), Sapphireho (08-15-2022), soundman98 (08-15-2022), Spuds (08-15-2022), Wally86 (08-16-2022) |
08-15-2022, 05:18 PM | #166 |
1st86 Driver!
Not for me, too tall, lanky and they all seem to walk funny.
I prefer the local strip joint, at least then you know exactly what you are going to get. Short of that, Weight Watchers is good, at least you have a better than even chance she can also cook and do dishes.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 5 Users Say Thank You to Dadhawk For This Useful Post: | NoHaveMSG (08-15-2022), Sapphireho (08-15-2022), soundman98 (08-15-2022), Spuds (08-15-2022), Tcoat (08-15-2022) |
08-15-2022, 10:36 PM | #167 |
that was plan a. it's been 5 years, time to move to plan b!
The Following User Says Thank You to soundman98 For This Useful Post: | humfrz (08-16-2022) |
09-23-2022, 09:01 PM | #168 |
Drives: 18 Brz (Sold) / 22 BRZ
Lately had to do some maintenance
1. Refilled ar-conditioner gas (took me a while trying to figure out what the issue was, until someone gave me a hint, to check line pressure 2. Replaced fridge evaporator fan Youtube, google and asking the right people saves a lot of money. |
The Following 2 Users Say Thank You to Stonehorsw For This Useful Post: | bcj (09-24-2022), soundman98 (09-23-2022) |
Tags |
diy, home, living |
Similar Threads | ||||
Brought my BRZ home today | Smokinbuffalo | Northwest | 8 | 05-31-2012 11:49 PM |
WRB-Got it home!!! | jaytaurus | BRZ First-Gen (2012+) -- General Topics | 28 | 05-29-2012 11:33 AM |
#64 brought home today. | FujiwaraTofuShop | Scion FR-S / Toyota 86 GT86 General Forum | 8 | 05-24-2012 09:04 AM |
Home Sweet Home, it made it today. Delivery party 5/11 though.. | MarkRacerX | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 05-14-2012 03:24 PM |
