07-04-2015, 01:01 AM | #1765 | |
Drives: WRB Subaru BRZ Limited MT
Try this: "For the limited: Open the driver door with the car off, hold down the lock and panic buttons on the key fob for approx 5 seconds. When you let go the car should beep. Now both doors will unlock when you touch the door handle. Not sure if that works with the premium." |
The Following User Says Thank You to MAX For This Useful Post: | Target70 (07-04-2015) |
07-04-2015, 01:06 AM | #1766 | |
Drives: 2013 Asphalt 6spd
just tried it, but my horn starts going off after 1 second and it's 1am, If the horn is supposed to go off, then I'll try it again tomorrow, if not, it may not be compatible with the frs, either way I appreciate the effort.
07-04-2015, 01:26 AM | #1767 | |
The Following User Says Thank You to D_Thissen For This Useful Post: | MAX (07-04-2015) |
07-04-2015, 07:43 PM | #1768 |
Back on topic:
I've been driving my car with the stage 1 tune for two days now... And the power and especially the "drivability" are dramatically improved over stock... However... My exhaust is noticeably quieter. Very noticeably actually... I installed an invidia N1 less than a month after I bought the car because I wanted a louder exhaust sound... And it was nice and loud... But with the tune... It's almost like I'm driving a hybrid if you compare the two sounds... I have a Catless UEL header on order as well as an OverPipe... So hopefully it will go back to loudish... But is this common with people running stage 1? |
07-06-2015, 12:07 PM | #1769 | |
Sent from my A0001 using Tapatalk
07-06-2015, 01:35 PM | #1770 | |
Drives: 2013 FRS
07-06-2015, 03:32 PM | #1771 |
Drives: 2013 FR-S Ultramarine 6MT
Anyone in new Hampshire running catted or hypothetically cat less headers and using OFT to disable P0420 CEL. If so How are you getting around the requirement that New Hampshire has that "all" monitors must be in a ready state. The OFT guys said that they disable the O2 monitor in stage 2, which is a fail in NH. They suggested running a stock tune for the state emissions test. How if you are popping the P0420 code with the factory stock tune will reverting to the "stock" tune help. Am I back to taking of the Injen intake and putting the stock intake back on? Or worse yet swapping out the headers? What a PITA
Starting to question my sanity as to why I bothered to mess with the car in the first place! $250 intake, $960 FT86 catted headers and now a $500 OFT tune that I have to revert back to stock and then will still not pass emissions. |
07-06-2015, 04:59 PM | #1772 | |
07-06-2015, 11:14 PM | #1773 |
This is the answer I got from the OFT guys.
"The P0420 is turned off when you run our stage2 map and no CEL will be present. We are disabling the O2 monitor. If you "catted" header is emissions friendly then you can simply run a stock tune when you need to pass your state emissions test. " If I read that correctly, it certainly sounds as though the O2 monitor is disabled and I would assume from this that the ODB readout would indicate that the O2 monitor is "not ready". This will fail our emissions in NH. I'm going to try tomorrow to get it inspected as the P0420 code has been cleared and the 8 monitors are in the "ready state. This haphazard appearance of the CEL indicates to my limited knowledge of the test and methodology that I am running at a borderline condition of the sensors. I will recheck the odb in the AM and if it's good I'll shoot down to the local auto parts store where they do inspections. If I'm back to a pending error code I am going to replace the Injen intake with the stock one and see if that helps. I guess the intake and the header mess with the sensors just enough to cause all this grief. Live and learn! The benefits from these minor mods is appearing to not be worth the hassle. On a side note, the last statement from the OFT guys makes no sense what so ever as it is the stock tune with my mods that causes the P0420 code. $500, I don't think so! Cheers |
07-07-2015, 11:25 AM | #1774 |
There is definitely an increase in loudness from the intake... And my exhaust on cold start is still pretty loud... But driving under 3000k is now like stealth mode... And before whenever I let off the gas my exhaust would howl, that has gotten much less noticeable... Would the new mapping reduce air flow when the throttle is backed off somehow?
07-14-2015, 07:09 PM | #1775 |
Drives: 2010 MS3
How's the basic stage 1 tune for a completely stock car?
07-14-2015, 10:35 PM | #1776 |
Drives: '22 BRZ
The Following 3 Users Say Thank You to DocWalt For This Useful Post: |
07-15-2015, 01:07 AM | #1777 |
Drives: 2014 ASPHALT FR-S MT
whats up guys tried uploading the new maps the 2.067 but i cant see them in rom raider
Sent from my Nexus 6 using Tapatalk |
07-15-2015, 01:30 AM | #1778 | |
see romraider tips link below |
Tags |
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
Similar Threads | ||||
Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
