Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
10-08-2014, 07:20 PM | #2101 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
I'm usually mid pack in my local group. At this same autocross, I spun out and had some sort of slip angle going most of the course.
10-10-2014, 04:52 PM | #2102 |
Drives: Toyota GT86
want some advice Toyota GT86.
I will run the Time Attack Club series for 2015 in Sweden and would like some guidance to begin with, know that they're completely individual how one prefers to set his car, but thought that perhaps more people have tried different settings here and can recommend what is bad and not Have driven 7 track events 2014, on the following chassis. BC racing BR coilovers. 10kg front / rear 7kg, oem Toyota GT86 swaybars and 225/45 17" Falken Azenis FK453 TW200. the car has felt good, and have been really competitive, but on quick sharp turns,I think the car rolls a bit on the chassis. so now I'd like some help with experience, about how stif sway bars I should have to tw180. Club regulations allow only tires with a minimum UTQG180 = TW180 like the Yokohama Advan AD08R. do not want to be too hard either,because then I will lose time,because the tires are not sticky enough so whats the limit of the thickness of solid and hollow sway bars, before they become too stif that they are just for r-tires and slicks fitment. would appreciate it if people who have tried different thicknesses on swaybars and spring rates on fast street tires. And actually seen a difference at times could answer O and for 2015 i will be driving Advan AD08R 245/40 17" on enkei rpf1 17x9 et35. |
10-12-2014, 10:05 AM | #2103 |
Drives: 2013 Firestorm FR-S
I recently installed the RCE yellows on my car which is running stock shocks and wheels. I have camber bolts upfront. I plan to get an alignment tomorrow, what should I be aiming for as far as a daily driver with occasional hpde time? Note this car is not my primary daily and is more of a toy/weekend car. What toe settings are optimal?
I know there isn't much they can do in the rear but I assume the springs will yield some camber gains.
2013 Firestorm FR-S, MTX, build date 1/13.
10-14-2014, 04:51 PM | #2104 |
Drives: 2014 Subaru BRZ Premium
@Racecomp Engineering @CSG Mike
I’m wondering if I could get some advice on possible setups. Right now I’m running 225 Michelin Pilot Super Sports on an 8 inch wide wheel, but I might go up to a 235 or 245 if the suspension requires it. I’ve done quite a few autocross events in the STX class and I’m looking to improve the suspension. My goal is to get something that would be considered at least somewhat competitive in STX, but I’d also like to add in more track days and possibly transition to that in the future. I like the KW V3’s and the RCE Tarmac 2’s but for now I’m looking at slightly cheaper options: (I will probably include lower control arms for the rear in all of these setups, so I didn’t include the price of those) Option 1: Feal 441 Coilovers (include camber plates) = $1350 Total 7k front, 6k rear spring rates with adjustable height and one way adjustable damping The main reason I’m looking at these is because a few people have trophied with them in STX at nationals. Option 2: Koni Yellow dampers + RCE Tarmac springs + HVT Camber Plate = $1373 Total 5k front, 5k rear spring rates with non-adjustable height and one way adjustable damping Option 3: Bilstein B8 dampers + Swift Spec-R springs + Camber Plate = $1659 Total 4.4k front, 5.3k rear spring rates with non-adjustable height and non-adjustable damping I realize that autocross and track driving require different setups, but if it’s possible I’d like to find a somewhat competitive autocross setup that would also be an improvement on the track. If there’s any other setup you guys would recommend for my goals at around $2000 or less, please let me know. I’m always looking to gain knowledge from other people and any insight would help. |
10-14-2014, 10:05 PM | #2105 | |
- Andy |
10-14-2014, 10:12 PM | #2106 | |
- Andy |
10-14-2014, 10:18 PM | #2107 | |
Yes a nationals level STX car might be set-up a little different than a hardcore track car but you can do pretty well with both if tuned right. Personally I'd think about option 2 with a few bushings added on. - Andy |
10-14-2014, 11:30 PM | #2108 | |
@Racecomp Engineering Thanks for the advice. You guys have been very helpful and I'd be happy to become a customer with the RCE Tarmac springs. With that being said, do you think the Koni's would still be a better match over the Bilstein B8's, regardless of the price difference? (Both being paired with RCE Tarmac springs) Or is there another damper you would suggest to pair with the Tarmacs that would suit my goals better? (I'm willing to go up in price slightly) |
10-15-2014, 03:46 AM | #2109 |
Junior
Drives: a car
the replacement performance dampers are very limited, as just Koni and Bilstein make them. The B6 vs B8 is literally only a difference in spring height you wish to use (damping is the same). Even that is subject to debate, with the B6's being cheaper, I'd go with those. IF you prefer adjustable dampers, than Koni no brainer.
The Following User Says Thank You to cdrazic93 For This Useful Post: | Racecomp Engineering (10-17-2014) |
10-17-2014, 10:10 AM | #2110 | |
I'm more of a Bilstein guy and I would strongly consider a set of revalved Bilstein B6 as I think that would be the best option. I like the feel of a responsive monotube with some good gas pressure and the custom valving would take it to the next level. Not cheap though (add about 450 when it's all said and done with shipping). Short of that, the Konis are pretty darn good too and what I run on my personal car (MINI). - Andy |
10-17-2014, 11:55 AM | #2111 | |
I like the idea of a revalved Bilstein B6, but I wouldn’t be entirely sure what to ask for when sending them in for the revalve. Is it just a matter of having them optimized for the 5k spring rates of the RCE Tarmacs, or will I have to be more specific about what I want out of the car and how I want the dampers to behave? Can the B6 shocks handle the drop that the RCE Tarmac springs would provide? (From what I understand the revalve wouldn’t alter that) |
The Following User Says Thank You to Plastic Robot For This Useful Post: | Turkish (10-17-2014) |
10-17-2014, 01:06 PM | #2112 | |
Off Topic
10-17-2014, 01:13 PM | #2113 | |
B6s can handle the drop of the Tarmacs. - Andy |
10-17-2014, 01:14 PM | #2114 | |
- Andy |
Similar Threads | ||||
Air Suspension Discussion Thread - Let's Get Nerdy | Andrew@ORT | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 174 | 02-13-2016 03:17 PM |
RallySport Directs Everything Suspension thread!! | RallySport Direct | Brakes, Suspension, Chassis | 21 | 07-02-2014 05:31 PM |
The OFFICIAL Ohlins Coilover Suspension thread - High End Competition Suspension | ModBargains.com | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 63 | 05-22-2013 08:15 AM |
2012 Team USA vs the 1992 Dream Team | ERZperformance | Off-Topic Lounge [WARNING: NO POLITICS] | 1 | 09-14-2012 06:19 PM |
Team build thread; PROJECT.STH | trueno86power | Other Vehicles & General Automotive Discussions | 0 | 03-02-2010 10:13 AM |
