Old 05-06-2019, 10:39 AM   #197
smg1138
smg1138's Avatar
Drives: 2013 Raven FR-S
Anybody know when JDL might have these on sale again? I really want to swap out my JDL UEL for the 4-2-1 but I'm also a cheapskate
smg1138 is offline   Reply With Quote
Old 05-06-2019, 02:01 PM   #198
the new guy
Drives: 2014 Asphalt FR-S/2018 Thunder GT
Black Friday is normally their best sale of the year. I’ve seen Jesse post some pretty good deals in the Facebook sale groups as well.
2014 FRS: Sold
2018 Thunder GT: RCE Superstreet 1 Coilovers, HKS HI-POWER SPEC L CATBACK, WedsSport TC105n 18x8
the new guy is offline   Reply With Quote
Old 05-07-2019, 01:42 PM   #199
smg1138
smg1138's Avatar
If I end up switching to the JDL 4-2-1, would it be worth upgrading my overpipe too? Wasn't sure how much gains could be had by changing it, but it seems like removing the stock piece is a PITA.
Current exhaust setup: JDL UEL catless header > stock overpipe > stock frontpipe > Perrin resonated catback
Old 05-07-2019, 01:44 PM   #200
jflogerzi
jflogerzi's Avatar
No not imo.
2013 Series 10 FRS #553
Old 05-07-2019, 01:50 PM   #201
wparsons
wparsons's Avatar
Removing the overpipe is much easier if the header is out already.
flickr
Old 05-08-2019, 12:46 AM   #202
TMF
TMF's Avatar
Drives: '14 FRS TT5
I had similar questions... Here were my questions and answers from JDL:
1. Which front pipe would you recommend for the most power in an NA application? 2.5" or 3" test pipe?
There's really no difference in power between the "Test" pipe and any resonated version. However the resonator(s) will add some weight. I personally haven't seen much of a difference in power levels between the 2.5" and 3" on na testing. The 3" makes slightly more top end while the 2.5" is stronger in the mid range. Nothing major though.
2. Any idea roughly what the power gain difference is between the test pipe and catted front pipe? Or are there any gains with the catted front pipe?
No cat is worth 3-4 horsepower from what I've seen. To be honest the cat that comes in our front pipe isn't recommended for track or autox use. I do have an option for a motorsports use cat that is rated for high heat and horsepower however it is quite a bit more expensive. If you can run without a cat it's what I would suggest.
3. Over pipe - any idea of power gains with this, or about the same as stock?
Definite gains with a header, especially ones where the merge collector is located near the overpipe connection. The overpipe essentially becomes an extension of the merge collector at that point so making sure the diameters are match and flow is smooth is important .
Follow my NASA TT5 build here: JHill Motorsports
TMF is offline   Reply With Quote
Old 05-30-2019, 11:32 AM   #203
smg1138
smg1138's Avatar
Has anyone come up with a specific OFT tune for this header? I'm guessing due to the 4-2-1 design the standard OFT Stage 2+ tune isn't going to be optimal.
Old 05-30-2019, 11:47 AM   #204
jflogerzi
jflogerzi's Avatar
That's correct. There are several tuners that can help with this on the forum. They will use the ace numbers and tweak from there.
Old 05-30-2019, 12:02 PM   #205
churchx
churchx's Avatar
Drives: 2014 GT86
I'd try OFT tune changes for longtube headers that was floating around for nameless/plm/ace alikes as starting point .. eg. search for nameless in OP of this thread.
Old 05-30-2019, 12:09 PM   #206
Roadcone
StreetKart
Drives: 2014 Scion FR-S Monogram
You're going to need a real custom tune. The cam tables are WAY different from the El and uel tunes for everything else.
Sent from my Pixel 2 XL using Tapatalk
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
Roadcone is offline   Reply With Quote
Old 05-31-2019, 01:40 AM   #207
Turdinator
Señor Member
Turdinator's Avatar
Mine should be arriving in a few weeks. Who has everyone used for their tune?
1974 TA22 Celica
2013 86 GT
Old 05-31-2019, 01:44 AM   #208
Roadcone
StreetKart
James at HRi. Contact Kevin Ket at Atlanta Speed Company to get your ecutek setup and tune scheduled with them. Tell them Kyle sent you and that his BRZ needs an H6 swap.
Old 05-31-2019, 05:31 AM   #209
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
I could be wrong but I doubt @Turdinator would be willing to ship his car to the U.S. to get a tune.
Sent from my PC.
Old 05-31-2019, 07:03 AM   #210
Roadcone
StreetKart
Sent from my PC.
That's why you do what I did an use email.
Search this Thread:
Advanced Search
JDL UEL header/Nameless header-back exhaust (Atlanta area) carbon_raven Engine, Exhaust, Bolt-Ons 16 05-09-2015 02:26 AM
Who has Open Flash Header (or aftermarket UEL header) in the GTA with stock exhaust? alanhung85 CANADA 6 10-21-2014 10:41 PM
RevWorks UEL Header + Nameless Catted Front Pipe VS Stock Gutted Header + FP NickFRS Engine, Exhaust, Transmission 44 04-19-2014 05:42 PM
Top Gear Solutions| HKS Header |Borla EL & UEL Headers| Agency Power Header| + MORE! TopGearSolutions Engine, Exhaust, Bolt-Ons 82 04-14-2014 08:16 PM
Gutted cat stock header vs aftermarket catless header NA application stevo585 Engine, Exhaust, Transmission 8 04-04-2014 04:12 PM
