Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
02-17-2014, 09:21 PM | #101 |
Drives: 2013 all stock frs
02-17-2014, 09:22 PM | #102 |
Drives: '13 Gen Coupe 3.8 R
02-17-2014, 11:13 PM | #103 |
Drives: 2013 Firestorm FRS
I don't think running a header without a tune causes damage...lots of people run the borla with a spacer on one of the o2 sensors. However, you won't see the gains that you could get with a tune
But the oft(open flash tablet) is pretty cheap, and you'll get the most gains for oft+header... |
02-25-2015, 04:55 PM | #104 |
Drives: 92 Prelude
Bump from the dead, but my J2 front pipe certainly made a difference in throttle response, not sure about the top end if theres a difference but throttle response certainly improved.
The Following 2 Users Say Thank You to jaorocks1 For This Useful Post: | Mr.Impreza (02-16-2016), tracerit (10-17-2016) |
02-25-2015, 11:58 PM | #105 |
Drives: 2013 FRS
Out of curiosity, is a resonated front pipe even worth getting when you already have a header ? I'm skeptical of how much of an improvement a front pipe will make when you already have a header.
02-26-2015, 12:03 AM | #106 |
Drives: '16 WRX, CBR1000RR
Looking at your mod list, I doubt you'd notice a difference in performance. You've already done the big stuff.
Phantom ESC'd Build Thread (Retired):http://www.ft86club.com/forums/showthread.php?t=75293
02-26-2015, 12:10 AM | #107 |
Drives: 2013 FRS
02-26-2015, 02:20 AM | #108 |
Engineering Student
Drives: Scion FR-S 2015
You should try a straight pipe with some unrestricted header! Also, change the drop in to a whole new intake since the stock have a lot of turbulence. In other words, the intake slows down the air.
Or TurboCharge the car and go with rich ethanol fuel.
There’s no time to stop for gas, we’re already late
02-26-2015, 02:43 AM | #109 |
Drives: 2013 FR-S Whiteout MT
I've done a straight pipe and catless everything with only an invidia mid pipe resonator.. just save yourself the trouble and don't try it haha
When in doubt, throttle out!
02-26-2015, 06:51 AM | #110 | |
Drives: Neptune GR86
Where are you getting your data from?
The Following 2 Users Say Thank You to Andrew025 For This Useful Post: | shifter907 (02-27-2015), tinma (02-26-2015) |
Similar Threads | ||||
Installed Over pipe,no more low end torque? | Sniper2606 | Engine, Exhaust, Transmission | 40 | 10-16-2017 03:53 PM |
What is the difference between a Front pipe, a down pipe and an over pipe? | liajet24 | Engine, Exhaust, Transmission | 5 | 09-19-2013 10:03 PM |
Nameless Performance Track Pipe Installed | MTeator | Engine, Exhaust, Transmission | 46 | 09-15-2013 08:57 PM |
Tint, lights and backup cam installed, and camber kit installed in Gainesville area? | husker741 | Southeast | 2 | 08-16-2013 03:59 PM |
