10-21-2018, 12:08 AM | #19797 |
Drives: 2015 Scion FR-S
10-21-2018, 05:29 AM | #19798 | |
Hypnocratic Missionary
But, you have green light led and a red filter. Green - Red = ??? not the same. Filtering a green light with red lenses will be darker. Look into subtractive color theory. Last edited by Hypnocracy; 10-21-2018 at 05:39 AM. |
The Following User Says Thank You to Hypnocracy For This Useful Post: | Face_Plant (10-22-2018) |
10-21-2018, 08:26 AM | #19799 |
Drives: 2018 Toyota 86 Base
Installed Tomei UEL and Tanabe OP
Tomei Expreme UEL, Invidia N1, Injen Evolution CAI, Crawford BPB, Tanabe OP, Tanabe FP, Radium MC Brace, CSF Filler Neck, Torque Solution TBS, Tanabe Rear STB, OFT STG2+ E85
10-21-2018, 04:04 PM | #19800 |
Country Boy 4 Life
Parts keep coming in. Now just need my front sway bar and bumpsteer kit.
via Imgflip Meme Generator via Imgflip Meme Generator
I LIKE TIRES! |
The Following 2 Users Say Thank You to Leonardo For This Useful Post: | StraightOuttaCanadaEh (10-21-2018), zeal86 (10-22-2018) |
10-21-2018, 04:33 PM | #19801 |
The Following User Says Thank You to humfrz For This Useful Post: | Leonardo (10-21-2018) |
10-21-2018, 05:53 PM | #19802 |
Country Boy 4 Life
Thanks! I think so too!
Initial impressions. FA COILS - These coils are nice quality parts. review after install. BLACKWORKS LCA - Wow! These are beautiful! They have completely exceeded my expectations. More pics soon.
I LIKE TIRES! |
10-21-2018, 07:25 PM | #19803 |
Sittin' Sideways
Drives: 2016 Toyota FR-S
Did it yesterday, and nothing special, just replaced the cabin air filter and wiper blade inserts, both terribly overdue.
The total cost of both inserts was less than the cost of one replacement blade like a Bosch Icon that you'd get at a store, and the swap was practically child's play. Would recommend for those of you who haven't eliminated your OEM wipers yet to stick with replacement inserts.
-O/D
2016 FR-S, Hot Lava |
10-21-2018, 08:44 PM | #19804 |
Drives: 2015 FRS 6 Speed Turbo
Installed the fit back up camera. Fun times it took me 3 hrs.
10-21-2018, 09:07 PM | #19805 | |
If you are going for maximum cornering traction, I found the rear sway bar actually made it slipperier
The Following User Says Thank You to Ashikabi For This Useful Post: | Leonardo (10-21-2018) |
10-21-2018, 11:51 PM | #19806 |
Drives: GTS 86 auto
I prefer an armrest on the door that rests my elbow up high enough that aligns my hand with the steering-wheel spoke. I rest my other hand on the underside of the wheel on my thigh. Make a mock-up to try. I found a center armrest constricting and got in the way when changing gear.
GTS86 Auto (Australia)
10-21-2018, 11:59 PM | #19807 | |
Drives: GTS 86 auto
Like the red trim. Is it guaranteed not to fade.
10-22-2018, 12:24 AM | #19808 |
Drives: GTS 86 auto
I hope you didn't put the video cable along the door sill like I did. If you go across in the trunk , put it between the rear seat backs and poke it up under the tunnel cover (no need to remove the cover) it is easy.
The Following User Says Thank You to notout86 For This Useful Post: | wulfstan (11-04-2018) |
10-22-2018, 07:59 AM | #19809 |
Just bought an OFT and installed the Stage 2+. I will try E85 went my tank gets low, have 93 in right now.
First impressions: Cold start is about 400 RPMs lower which is nice since I leave for work at 4:30 and the neighborhood is dead quiet lol. Idle after warm up is at about 600, makes for a nice loping rumble at the intersection Lots more throttle response and pretty decent pull even in higher gears which is really nice in traffic, no constant down shifting. Overall very pleased with the purchase. I was even able to clear the CEL I got the other day after installing the catless uel.
10-22-2018, 09:41 AM | #19810 | |
Country Boy 4 Life
Thanks for the input. The rear sway pictured is a 16mm Perrin. Plan on using the softest setting for the rear. Rear : 16mm 3 position 16mm Hole #1 30% 16mm Hole #2 65% 16mm Hole #3 116% What bar did you install that made it slipperier feeling? My goal is to have my car feel: more connected, planted, stiffer, yet still not harsh, and a bit more technical to drive. And if anyone notices that I have 2 sets of front endlinks... I was told by the vendor, that THESE FA coils 100% did not come with them. (even though front endlinks are pictured on the FA's website) So, I ordered whiteline front to match the rear endlinks. Now I have two sets....
I LIKE TIRES! |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
