01-05-2022, 09:54 AM | #2367 | |
Drives: 2018 Subaru BRZ
Whenever I get warm days, is because is raining. Im just going to take the car to a touchless wash even if its cold outside.
01-05-2022, 10:25 AM | #2368 | |
1st86 Driver!
It's not going to help much with traction. Don't be that guy.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 4 Users Say Thank You to Dadhawk For This Useful Post: |
01-05-2022, 11:02 AM | #2369 |
ProCrastinationConsultant
lol. left snow on the roof for "reasons" besides being lazy...
i don't know how dense the snow is around your area, but without a doubt it's nowhere near as dense as that reasoning... a. 1 60-pound sand bag is going to weigh more than most any snow on the roof b. i've never been in any snow situation that 1 sandbag makes a difference c. any weight on the roof will be somewhat distributed to the front wheels-- for any weight to directly effect the rear axle, it needs to be behind the axle...
01-05-2022, 11:18 AM | #2370 | ||
Be Kind
Drives: 2020 86
The Following 2 Users Say Thank You to Wally86 For This Useful Post: | Dadhawk (01-05-2022), soundman98 (01-05-2022) |
01-05-2022, 11:45 AM | #2371 | |
The Dictater
Drives: '13 Red Scion FRS
If we assume 46/54 in a 2800lb car, 60lb over the rear axle is ~2% change in distribution. More if it is placed behind the rear axle. However, the further back it is, the more weight is taken off the front. If someone is going to add weight, I would add it as far forward in the trunk as possible. What would be better than extra weight is reducing tire pressure a bit. Also, +1 to don't leave snow on the roof if possible. I have seen people brake and then the melting snow moves forward onto their windshield. Also, driving behind them is pretty dangerous. |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
01-05-2022, 11:57 AM | #2372 | |
Be Kind
Drives: 2020 86
01-05-2022, 12:45 PM | #2373 | |
DO NOT reduce tire pressures. Not only does it reduce overall traction it reduces stability so you get the worst of both worlds!
01-05-2022, 12:55 PM | #2374 | |
The Dictater
Also, I never had any problems with the FRS understeering in the snow. That's usually manageable by driving an appropriate speed. I have had problems with not being able to make the car go in a straight line, or go to at all due to oversteer in the snow, which isn't something one can really affect by just going slower. |
01-05-2022, 12:59 PM | #2375 | |
01-05-2022, 01:00 PM | #2376 |
The Dictater
01-05-2022, 01:49 PM | #2377 |
i think it really depends on the snow we're talking about. lake effect, and lower snow belt regions are entirely different than mountains. all of my experience is in the lake effect stuff, which is mostly melted off the roads within 2-3 days.
in the slushy melty crap, the pizza-cutter approach tends to make a difference to cut through the snow to the surface to grip. but i can see how in colder consistent temps, flotation on top of the snow hardpack would more more desirable. but i don't think anyone can get any decent floatation out of a 45-series tire that most of us would run.. my first few years driving, i had my parents 2wd single cab ranger, but through various dealership connections, people would trade in trucks and leave sandbags. so i had essentially an unlimited free supply of sandbags. the first few years, i dragged around somewhere close to 600 pounds of sandbags, even went so far as to build an jig to hold the bags centered over the rear axle. after a couple years of dragging the bags in and out of the truck, and eventually replacing the spring shackles after they rotted out, i got tired of it, and started throwing 3 bags/120 pounds in. what i found was that the truck was just as capable with 120 pounds in it as it was with 600 pounds. it stopped a lot better at least! only difference was that a 2wd pickup needed some extra weight in the back just to even out the weight of the truck, otherwise it wanted to tiny dancer and pirouette everywhere. contrasted to pickups, these cars have amazing weight distribution. i did try 2 sandbags the first winter with this car, and found almost no effect. it doesn't change any handling characteristics enough to justify even free sandbags.
The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (01-05-2022) |
01-05-2022, 02:06 PM | #2378 |
What works for snowmobiles and tanks is not so effective for 4 wheeled cars.
01-05-2022, 02:31 PM | #2379 | |
01-05-2022, 02:42 PM | #2380 |
The Dictater
Similar Threads | ||||
WRC Car: TMG GT86 CS-R3 | riyal | AFRICA | 8 | 11-19-2013 02:03 PM |
XXR 527 on GT86 | jesperswe | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 10-27-2013 10:17 PM |
GT86 FOB KEY | SPEEDGOD | Canada Classifieds | 0 | 07-29-2013 10:17 AM |
GT86 OEM Option Pin Stripes (anyone done this to their 86/GT86/FRS/BRZ)??? | jbsali | Cosmetic Modification (Interior/Exterior/Lighting) | 27 | 07-28-2013 11:10 PM |
MEETING 'MR GT86' - Tada San drives GT86 in Scotland (Pistonheads) | RadOnc | Scion FR-S / Toyota 86 GT86 General Forum | 15 | 11-23-2012 08:42 AM |
