go_a_way1
Old 04-19-2023, 05:58 PM   #5923
Jrdad
Jrdad's Avatar
Drives: 2013 Scion FR-S 6M Argento
Originally Posted by tomm.brz View Post
i found a bit funny you have such a powerfull config and no idea/don t care of the boost you are running with honestly
a c38 with high boost pulley will have 10 psi at 6000rpm, 12.5psi at 7000rpm and 14psi at 7400rpm
The problem with this kind of boost is that over time rods will bend...
boost alone isnt what blows your motor. its the amount of power, specifically torque, that does that. you could run two turbos or superchargers of different sizes and they will flow vastly different amounts of air at the same amount of boost. you could also put something in your intake path, which would raise the amount of boost but lower the airflow and thus power that you make and your engine wouldnt care.
Jrdad is offline   Reply With Quote
The Following User Says Thank You to Jrdad For This Useful Post:
CSG Mike (04-19-2023)
Old 04-19-2023, 07:10 PM   #5924
tomm.brz
Drives: brz 2017 hksv2
if you put something in the intake path, boost and airflow both drop. I.e. the hks supercharger restrictor of 39mm which limits boost to around 0.6, or 43 which then arrives easy to 0.75bar
i agree that too much torque at low rpm will kill rods to the point of snapping (been there) but also 1bar at high rpm can surely contribute to slowly bend rods
I saw csg mike claiking up to 360/380WHP with c38 and high boost pulley, with stock internals and e85.. don t you think the ignition timing used to produce the necessary torque to reach those Whp can't create very high internal pressure inside the combustion chamber? it surely does
what helps is the e85, because with normal pump petrol there will always some moment where a knock can occur at high rpm high boost and in that moment the pressure inside the cylinder is extreme
but also without knocking using only e85, how many people blew the engine anyway even with good reputable tuner? many
Old 04-19-2023, 07:55 PM   #5925
Jrdad
Jrdad's Avatar
My apologies, I meant between the compressor and the engine regarding having something in the intake path. The HKS restrictor is pre compressor.
tomm.brz (04-20-2023)
Old 04-20-2023, 07:48 AM   #5926
Breadman
Breadman's Avatar
Drives: 2017 BRZ w/PP
The problem with this kind of boost is that over time rods will bend, specially if you have no idea what s going on in your engine, or put less octane in tank than required by the tune, every knock with that high boost at rpm can help deteriorating
then suddenly one you get a rich afr, misfires and knock all the time and car doesn t run a shit and you ll notice the compression in cilinders is gone
luckily you use e85 only and that helped, probably you avoided often going to redline too
Sorry to jump back but even at 8k the most i saw in my logs were 1.95bar absolute. Do I have a boost leak?
Breadman is offline   Reply With Quote
Old 04-20-2023, 08:05 AM   #5927
tomm.brz
you also reach 8000 rpm with stock internal stock valve springs?
anyway i dont know if you have a leak, boost depends a lot to intake temperature and are you at altitude or sea level?
Do you have a log of a pull of your car?
Old 04-20-2023, 08:18 AM   #5928
tomm.brz
and 350whp or more with a c38 unit with high boost pulley (that on most car would give about 1bar of boost at high rpm) is not a concerning level of power and torque to worry about the engine?
If i m not wrong Cosworth did engine dyno test and they stated that anything over 0.65bar of boost and 280-300hp to the crank (250Whp or less) is unsafe.. that 's conservative for sure but here in Europe you don t get e85 in many countries
Old 04-20-2023, 08:26 AM   #5929
Breadman
Breadman's Avatar
I'm fully built. I'm sure I have logs somewhere from when I got Zach to tune it. Honestly even being built I'm not a huge fan of going that deep into the rpms but it is nice to have if needed. I'm not a good enough of a driver for it to matter I just found it interesting.
Old 04-20-2023, 08:32 AM   #5930
tomm.brz
oh yes sorry i confused you with the guy Brz866 i responded too
Old 04-20-2023, 10:59 AM   #5931
tomm.brz
Ok so , the boost i was talking actually is a bit higher than a regulat high boost pulley C38 because the logs i was looking at are with a custom bigger intercooler which adds about 1psi of boost as a result of more restriction, but also cools a lot and logs were taken in Canada with 5 Celsius or less
https://datazap.me/u/tommbrz/v6-0?lo...-34-38&solo=38 Here the boost a high boost pulley C38 can reach when it s pretty cold outside
Mind it's not the RS pulley
Old 04-20-2023, 12:52 PM   #5932
Breadman
Breadman's Avatar
I have since put vents on my hood due to iat but i checked my last log and it starts the pull at 31c and ends at 44.8c. Pretty sure that would do it
Old 04-20-2023, 12:59 PM   #5933
tomm.brz
yep, in that log i provided iat is much much lower, therefore the higher boost
big intercooler apparently works good
Old 04-21-2023, 08:14 AM   #5934
Teppka
Drives: Subaru BRZ
Does it mean that if I will run it on lower octane gas like RON 95 in Europe I can safely run higher pressure to achieve similar torque value estimated by Jackson Racing or other turbo kit/supercharger kit manufacturers as safe threshold? My understanding is that I will need to increase boost with lower RON gas to achieve similar torque compared to higher RON gas.
Teppka is offline   Reply With Quote
Old 04-21-2023, 08:32 AM   #5935
tomm.brz
that doesnt make sense
the more boost you have, the less the fuel resists
95 ron is so bad that over 0.8 bar the ecu corrects for knock by default all the time basically, ignition timing are so low that the car is just slow and the boost would keep overheating the charge and then it knocks even more
there is a point of deminishing return with boost and shitty fuel...in the same car, less boost and more ignition timing can give more power if the fuel can't stand the pressure and heat
Old 05-19-2023, 02:00 AM   #5936
86Hakone
86Hakone's Avatar
Drives: 2020 GT86 Hakone
Originally Posted by Ignore Your Doctor View Post
damn thats what im getting with the HBP lol. my 93 tune with the c38 was max 9.5psi making around 300whp and I daily drove that for the last 3 years (20k miles) with no issues. now with the HBP im at like 12psi and 360whp so we will see how long she lasts. My car only has 61k miles on it so keeping my fingers crossed
Is the 360 wheel a guess of from a dyno? I'm running c38 HBP, ID1050x injectors, UEL header, With Flex Fuel Kit/Tune from CSG. It would be nice to know i'm creeping up on 400 on a cold day with good fuel. The car feels fast so I haven't bother taking it to a dyno.
86Hakone is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
