08-08-2017, 10:58 AM | #323 |
Drives: none
Yeah, not something that was lost on me However, they only list a sales contact, not service. I think they may prefer that people obtain service through dealers since there's a dealer portal login.
Either way, I've managed to suss it out. The sensor appears to be this one: http://aemelectronics.com/files/inst...nsor%20Kit.pdf It conforms to the standard GM/Delco IAT specs. To that end, I found that COBB have published a IAT scaling map for the impreza to use a GM sensor. After breaking out my meter I determined our ecu has the same 1k pull-up resistor and ~4.75V sense voltage as the impreza. The COBB map even uses the same voltages in the cells as the stock BRZ IAT scale map. You can find the mapping here (along with some other helpful scaling calculators) Hopefully others find this useful. Code:
0.204999998 120 0.361000001 120 0.518000007 113 0.674000025 102 0.829999983 93 0.986000001 86 1.143000007 80 1.299000025 76 1.455000043 72 1.610999942 67 1.768000007 63 1.924000025 60 2.079999924 56 2.236000061 53 2.392999888 49 2.549000025 45 2.704999924 41 2.861000061 38 3.017999888 34 3.174000025 31 3.329999924 28 3.486000061 24 3.642999888 21 3.799000025 18 3.954999924 13 4.111000061 8 4.268000126 1 4.423999786 -8 4.579999924 -23 4.736000061 -40 Last edited by armstrom; 08-08-2017 at 12:52 PM. Reason: Sticking to the important info |
The Following User Says Thank You to armstrom For This Useful Post: | CSG Mike (08-09-2017) |
08-08-2017, 12:40 PM | #324 | |
Drives: '14 981CS, '99 NB1
That figuratively blows my mind. How could you not analyze a boost setup before tuning it... I just... wow. |
08-08-2017, 12:52 PM | #325 | |
Drives: none
I mean, think about it critically... Delicious has released many revisions to the flash-and-go tunes over the years. They incorporate new findings, new ideas, new results and improve things going forward. That's how I WANT my tuner to operate. If you bought rev 1 of the tune should you be all up in arms that it wasn't "100% perfect" straight out of the box? Just because something can be improved doesn't mean it was "BAD" to start with. My car runs beautifully and smoothly and has done so for months on a delicious tune. Will this new information help improve it? Maybe a little... was it "bad" or "broken" before? Hardly! My comments were not meant as a ding against Delicious as they have been amazing to work with and Zach has been super patient with all of my questions I'm going to edit my comment to remove that section. I was simply trying to share the information I found and I don't need to go into extra detail to do that. -Matt |
08-08-2017, 03:01 PM | #326 |
Drives: UK GT86
@armstrom that is a different IAT scale to what I have seen on a Harrop tuned car. Has that scale been confirmed by Harrop as I suspect the one I've seen has?
.: Stealth 86 :.
The Following User Says Thank You to Kodename47 For This Useful Post: | armstrom (08-08-2017) |
08-08-2017, 03:14 PM | #327 | |
Drives: none
I would be very interested in seeing the "official" scaling from Harrop though. -Matt |
08-08-2017, 07:29 PM | #328 |
Drives: UK GT86
It's not my tune, so I can't. I also don't want to suggest it's the correct one but they are the main UK importers of the Harrop. The shape is similar and different to OEM so it won't be far off either way.
.: Stealth 86 :.
08-08-2017, 09:08 PM | #329 | |
Drives: none
I produced a spreadsheet that will allow you to calculate an IAT scaling map from any sensor and at temperature values of your choosing. When I do that I also come up with a slightly different curve than the one I posted above. However, my scaling is based purely on nominal sensor specs and measurements on my own car (Vsense and Rpull-up) so I figured I would go with the scaling from a proper tuner I've attached the spreadsheet in case anyone finds it useful. Standard disclaimer, I'm not a tuner and you should verify any calculated values with testing on a real sensor, etc etc... if you blow anything up with values from my spreadsheet you're on your own and so forth If nothing else you can look at the equations in the spreadsheet to see how to do linear interpolation in Excel -Matt Last edited by armstrom; 08-09-2017 at 01:50 AM. |
08-09-2017, 12:35 AM | #330 | |
08-15-2017, 04:03 PM | #331 |
I'm wondering has anyone put a stroker kit on their car with this setup?
Harrop ran there car with the HKS stoker kit which runs $4482.00 USD with cams and can give you a compression ratio of 11.4:1 while the Greddy kit cost significantly more at $6157.00 USD without cams and gives you a compression ratio of 9.5:1 Does anyone know why the big difference in cost? Is it even worth a going with a stroker kit? From what I sourced out engine internals are going to run you similar to the HKS kit. Thanks |
The Following User Says Thank You to G-Unit86 For This Useful Post: | byun (11-22-2017) |
08-15-2017, 05:46 PM | #332 | |
Airborne at your service
Drives: '17 BRZ Series.Yellow
08-15-2017, 10:34 PM | #333 | |
"POINT-1:PISTON KIT Carefully selected specially forged raw materials used POINT-2:CONNECTING ROD High strength I beam design and revised connecting rod bolt size. POINT-3:CRANKSHAFT STROKE 90.0mm Made from HKS special forged material." https://www.hks-power.co.jp/en/produ...city/fa20.html The only thing I can tell is HKs uses I-Beam rods like Manely, while Greddy uses H-beam like Carillo |
The Following User Says Thank You to G-Unit86 For This Useful Post: | CxG (04-26-2019) |
08-16-2017, 12:39 PM | #334 | |
Drives: 2018 STI
08-16-2017, 07:27 PM | #335 |
Drives: '17 BRZ PP, old Legacy SSs and SVXs
Ordered mine today from Niel@The Racers Line along with EcuTek, Delicious tunes and the E85 kit. Now the waiting begins.....
The Following 2 Users Say Thank You to PhyrraM For This Useful Post: | Irace86.2.0 (08-16-2017), johan (08-16-2017) |
08-16-2017, 11:05 PM | #336 |
Drives: Q5 + BRZ + M796
Similar Threads | ||||
HKS Supercharger owners thread | wbradley | Forced Induction | 1048 | 10-12-2023 08:03 PM |
JDL turbo kit owners thread | yomny | Forced Induction | 1346 | 08-29-2023 11:07 PM |
P&L Turbo kit Owners thread | Hawaiian | Forced Induction | 73 | 07-07-2018 02:31 AM |
Harrop car lip kit? | djdnz | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 12-15-2015 02:50 PM |
**Offical 213/323/626/818 owners thread** | mr. slim | Southern California | 71 | 10-07-2013 12:58 PM |
