Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
05-27-2018, 03:39 PM | #16 |
Drives: 2013 frs red
172 sounds like you got a good one.
05-27-2018, 08:39 PM | #17 |
Drives: FT86
05-28-2018, 08:35 PM | #18 |
Some days I wish this thing had a softly tuned bigger motor in it so I wouldnt have to brake drag it to get the iam back. Knock sensor shit . I guess it would make me less of an "enthusiast" though.
05-28-2018, 08:46 PM | #19 | |
Yep. It might not revert on a hot restart, but definitely if parked for a while.
05-29-2018, 10:03 AM | #20 |
It will reset even on a key flick while rolling. As steve99 pointed out, it will only reset if the IAM climbed above the initial. If it was below the initial then it will restart at the lower value.
The Following User Says Thank You to ermax For This Useful Post: | wparsons (05-29-2018) |
06-03-2018, 12:53 PM | #21 |
Drives: BRZ 2017 Pure Red, MT
I just learn reading this about the 0.7 IAM. Is it only on the 2017?
I do autocross a lot with my 2017, and often stop the car between runs. This would mean i lose a lot a HP in the following run!! How much time does it take to go back from 0.7 to 1? Does it come back after the first pull in first gear? Does that pull need to be to redline? From the start line I usually shift to second at 6500rpm, since I reach the first slalom before redline. Is that enough to go back to 1.0 IAM? And is there a way I can monitor the IAM without an Ecutek or OFT? I have a OBD2 reader. Maybe I can check the timing advance and deduce the IAM? Thanks Last edited by nico_rsx; 06-03-2018 at 02:15 PM. |
06-05-2018, 11:25 PM | #22 |
Drives: Q5 + BRZ + M796
Was the negative battery terminal pulled; ie was the ECU reset, and it needed to learn?
Similar Threads | ||||
Where to go for quick dyno runs? | TM | Northern California | 1 | 07-27-2015 06:53 PM |
FREE Dyno runs when you buy a Tune/Flash | vividracing | Arizona | 0 | 05-19-2015 05:43 PM |
Kraftwerks Supercharger - Time-lapse of install + dyno runs. | The Sentinel | Forced Induction | 1 | 02-06-2015 09:04 PM |
Baseline Dyno runs at VIP performance: 2015 FR-S | sachu | Engine, Exhaust, Transmission | 0 | 01-10-2015 10:32 PM |
My Dyno Runs | Crewzern | AFRICA | 4 | 10-30-2012 03:52 PM |
