Old 06-14-2021, 04:30 PM   #1
dazhbucked
Drives: Subaru BRZ 2014
I added 6 quarts of oil by mistake
So I did my oil change this morning and by mistake I added 6 quarts of oil instead of the 5.8. I checked the dip stick and the oil level was perfect on the 2 point of the dipstick but it had a line of oil on the side just above the 2 point, I was wondering if it’s safe to drive with 6 quarts of oil? Has anyone done this mistake before?
dazhbucked is offline   Reply With Quote
Old 06-14-2021, 04:35 PM   #2
Westen86
Purist
Westen86's Avatar
Drives: 2013 FRS - Hot Lava
If youre always at redline, you may have oil going places it shouldnt. But if its a "daily", itll be fine. The bottom notch or mark on a dipstick is COLD fill, like 40-60*F. When you check your oil HOT, 250*F+, it should be at the top mark.
WTB: Everything Verus
RaceComp SS-1, Complete SuperPro bushings, TR Motorsport FF10 17x9 +45, GruppeS UEL, HKS Hi-Power V2, OFT(93/E85)
Westen86 is offline   Reply With Quote
Old 06-14-2021, 06:38 PM   #3
ZDan
ZDan's Avatar
Drives: '23 BRZ
High mark is "full". Low mark is 1 liter (1.1 qt) short of "full". Difference between hot and cold won't be anything like the difference between the low and high marks!
The Following 4 Users Say Thank You to ZDan For This Useful Post:
Cephas (06-16-2021), Spuds (06-16-2021), Wally86 (06-15-2021), WildCard600 (06-16-2021)
Old 06-14-2021, 06:41 PM   #4
ZDan
ZDan's Avatar
Drives: '23 BRZ
For sure you're fine at 0.2 quarts (probably a little more than that as engine wasn't totally dry when you added 6 quarts). I've run somewhat overfilled as well, by probably 1/2-qt, on the street and at the track, never had any problems.
Old 06-14-2021, 09:33 PM   #5
Sapphireho
¯\_(ツ)_/¯
Sapphireho's Avatar
Drives: '15 ultramarine
The car will blow it you drive it.
You sure you changed the oil and not the muffler fluid?
Old 06-14-2021, 09:46 PM   #6
McMCOO
Anti-Social Media
McMCOO's Avatar
Drives: 24 GR86 Premium MT is on the way!
McMCOO is offline   Reply With Quote
The Following 3 Users Say Thank You to McMCOO For This Useful Post:
soundman98 (06-14-2021), Spuds (06-16-2021), Wally86 (06-15-2021)
Old 06-14-2021, 11:35 PM   #7
McMCOO
Anti-Social Media
McMCOO's Avatar
I do not pay attention to much in the way of Diesel technology. So one day. like in only the last year, I saw a reference to Diesel exhaust fluid and thought someone must be having fun at my expense. Turns out Google and the automotive industry are in on the joke.
Old 06-15-2021, 02:11 AM   #8
The muffler doesn't have oil, the muffler bearings are sealed -
The Following 4 Users Say Thank You to humfrz For This Useful Post:
Cephas (06-16-2021), NoHaveMSG (06-15-2021), Wally86 (06-15-2021), WildCard600 (06-16-2021)
Old 06-15-2021, 06:13 AM   #9
ZDan
ZDan's Avatar
Drives: '23 BRZ
Funnily there is a weird spherical "gasket" at the spring-loaded joint between the forward pipe and catback, p/n 44022AA123. Muffler bearing! Kinda...
The Following 3 Users Say Thank You to ZDan For This Useful Post:
humfrz (06-15-2021), soundman98 (06-15-2021), Wally86 (06-15-2021)
Old 06-15-2021, 01:06 PM   #10
Well, OK, if that's what you want to call it -
ZDan (06-15-2021)
Old 06-15-2021, 08:51 PM   #11
soundman98
ProCrastinationConsultant
soundman98's Avatar
you don't even want to know what DEF has done to repair bills on semi trucks
some trucking companies have seriously gone to the lengths of frame-up restorations of the old non-DEF-equipped trucks because of it...
Old 06-16-2021, 08:45 PM   #12
Spuds
The Dictater
Spuds's Avatar
Drives: '13 Red Scion FRS
OP. It's fine don't worry about it.
2 cases Eneos 0W20 oil (12 quarts) Red John Mechanical Maintenance and Tools 15 11-12-2015 02:55 PM
How many quarts of engine oil for cars with oil coolers toby714 Engine, Exhaust, Transmission 8 12-11-2014 07:16 PM
WTB 6-quarts of Eneos Sustina 0w-20 FR-S Matt Want-To-Buy Requests 3 09-22-2014 11:48 PM
7 Quarts of Eneos 0w-20 OMNOM Mechanical Maintenance and Tools 3 04-12-2013 08:41 AM
5.8 quarts too much? Brimford Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 14 08-08-2012 10:36 AM
