Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum - FT86CLUB > Technical Topics > Mechanical Maintenance (Oil, Fluids, Break-In, Servicing)
Old 07-15-2020, 06:38 AM   #15
Halo_2
Drives: 2014 MY15 86 GTS
Penrite synthetic (AUS)
Halo_2 is offline   Reply With Quote
Old 07-17-2020, 06:56 AM   #16
sneaky_pete
Drives: TBA
+1 Penrite GL4 for the transmission and Penrite GL5 for the diff!
sneaky_pete is offline   Reply With Quote
Old 07-18-2020, 12:03 AM   #17
itschris
Drives: '14
Originally Posted by rice_classic View Post
Pennzoil synchromesh. 85k street miles and almost 2 full race seasons and not a single crunch or grind.
None of that fully synthetic stuff for me in the trans. Synchros like a little friction - their very job function specifically relies on it.
I made this switch a few days ago based off your continued posts suggesting it . I cannot praise it enough after having suffered through many changes of Motul 300.
I assume I'll be changing it more often, other car's UOAs seem to suggest additives disappearing quickly. How often do you change it during the season?
itschris is online now   Reply With Quote
Old 07-18-2020, 01:40 PM   #18
AKITA
AKITA's Avatar
Drives: 2016 Scion FRS Halo
Use Motul.. better than stock.. but I'd be willing to try some of the other suggestions like Amsoil and Penzoil
AKITA is offline   Reply With Quote
Old 07-19-2020, 01:53 AM   #19
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
Street car... 20k miles or so.
Race car... every 2-3 race weekends. I just did 4 double race weekends without a chance and it came out Looking rough so that was too long... still no grinds or crunches.
SCCA T4 - FRS
The Following User Says Thank You to rice_classic For This Useful Post:
JohnH (07-30-2020)
Old 07-21-2020, 12:46 PM   #20
gravitylover
Originally Posted by Bonburner View Post
Another oil I've been debating is: https://products.liqui-moly.com/oils...ct-media-modal
I just tried LiquiMoly's engine oil additive CeraTec which has been pretty amazing.
I reached out to LiquiMoly and they recommended to use MoS2 isntead of Ceratec and their High Performance Gear Oil with the MoS2. So I'm debating that now.
This is LiquiMoly's email:
"thank you for sending us your request regarding Ceratec's use in manual transmissions.
Your manual transmission on your Scion is better of using our anti-friction additive named MoS2 Anti-Friction for Gears. This additive is specifically designed for use in gearboxes and differentials and will be the best choice for your 6 speed transmission. Lower internal friction will add protection to gears, bearings and synchros.
Also make sure to use a high quality gear oil in the transmission, like our High Performance Gear Oil GL4+ 75W90.
Please let me know if you have any questions.
Stefan Braun
Application Specialist"
What benefits have you noticed using the CeraTec? I didn't know that they also make gear oil. I'm going to look into that, thanks.
I've been on the fence about trying the Redline next fluid change and now I'll add that Pennzoil to my confusion. A while back I changed to Lucas and something else, don't remember what it was now, and they sucked so I went back to whatever the guy at the Subaru parts counter gave me in January. The shifting went back to at least as good as the original, maybe a little better because things were worn in now, but less than 10k later and the tranny is whining like it was never done so the next change is coming up sooner rather than later.
Old 07-21-2020, 01:24 PM   #21
NoHaveMSG
NoHaveMSG's Avatar
Drives: Crapcan
Originally Posted by ItsReiko View Post
However, everyone on the forums states to not use GL5 rated fluid in the manual transmission,
A lot of people have been recommending Motul Gear 300 for years which is GL5. I personally didn't like it.
Old 07-23-2020, 03:15 PM   #22
Bonburner
Bonburner's Avatar
Drives: M/T Argento FRS
Improvements have been really drastic.
My MPG has been 24's, and the drive down from nothern CA to southern CA have been averaging 24 mpg. It shot up to 34 (I think the ECU was re-calibrating still as my MPG seems to have returned to mid 20's .. but I'm not driving as much lately).
Engine has been incredibly smoother to redline (more so than before).
https://www.ft86club.com/forums/show...6&postcount=10
Purchased: 6/22/12
Mods: aFe Magnum FLOW Pro 5R; Deka Intimidator 35; JDM Underpanels; KYB Excel-G Struts; EBC Yellowstuff pads; PowerStop Drilled & Slotted Rotors; Seicane S16003; Morimoto 35W XB H11B 6500K HID kit
The Following User Says Thank You to Bonburner For This Useful Post:
gravitylover (07-24-2020)
Old 07-29-2020, 10:34 PM   #23
Petah78
Drives: 2017 BRZ sport-tech
Pennzoil Syncromesh in both transmission and diff? Have you used amsoil syncromesh MTF?
Thanks.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 03 Acura 1.7 EL, 10 Acura CSX-S
Current: 17 BRZ, 00 S2K - #0220
Petah78 is offline   Reply With Quote
Old 07-29-2020, 11:10 PM   #24
rice_classic
Thanks.
Absolutely not in the Diff! Just about any synthetic 75-90 gear oil in the diff. Iím partial to amsoil and motul for Diff
SCCA T4 - FRS
Old 07-30-2020, 03:55 PM   #25
JohnH
Drives: 2020 BRZ ST RS
thanks! I am not going to put GL5 in a manual trans that has yellow metals in it, and not specifically asking for it. I've also used Pennzoil synchroshift in another platform I played with for a couple of decades. It worked quite well, and most guys used it.
JohnH is offline   Reply With Quote
Old 07-30-2020, 08:52 PM   #26
Mike_ZN6
Mike_ZN6's Avatar
Drives: 2016 Toyota 86
Motul Gear 300 LS is what you want for the rear diff. Many people on this forum recommend a 50:50 Mix of Redline 75W90NS/MT-90 for the trans.
Mike_ZN6 is offline   Reply With Quote
Old 08-04-2020, 08:34 PM   #27
Petah78
Thanks. Have you ever used amsoil syncromesh in the transmission? Does that work as well?
As for diff, will amsoil severe gear 75-110 work?
Old 08-05-2020, 01:54 AM   #28
rice_classic
Both are good but the syncromesh from amsoil is full synthetic so when things get hot and fast the oil will prevent the synchro from adequately slowing down the gear and youíll get a crunch. This is in track/racing scenarios.
I like the 75-110 but I race on the 75-90
SCCA T4 - FRS
differential, fluids, maintenance, oil, transmission fluid
Changed Diff/MT Trans Fluid to Motul 300 and super low MPG jfg5067 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 15 01-18-2016 09:24 AM
Trans and Diff fluid change feedback Freedom AFRICA 0 08-07-2015 11:52 AM
Manual Trans./Diff. Fluid Change.?. westmansweed Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 13 07-15-2015 08:02 AM
Replacing Trans & Diff Fluid, Hot vs Cold BRZNutt Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 8 12-22-2013 09:04 PM
Trans/Diff Fluid. DanoFA20 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 18 01-11-2013 03:11 PM
Copyright ©2000 - 2020, vBulletin Solutions Inc.
User Alert System provided by Advanced User Tagging v3.3.0 (Lite) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
