#4621 |
Drives: 2021 Supra / 2022 Tundra
Have you tried the full idle relearn process after flashing? My tuner had me do basically exactly what this guy details in the video below every time I flashed. One time I was in a hurry and didn't do it and the idle would hunt pretty badly with AC on so I reflashed and followed it again and the car is fine.
TomR
The Following User Says Thank You to ABQautoxer For This Useful Post: | Jerr (08-21-2022) |
#4622 | |
Drives: '17 BRZ Series Yellow Edelbrock SC
#4623 | |
Drives: 2016 Scion FR-S / Edelbrock SC
I edited my post a little, I noticed that counterintuitively, MAF and MAP readings increase as idle dips rather than decrease, which tells me their signals are being misinterpreted unless I am not understanding how those readings work. Idle goes from 900 to 600, but MAP reading goes from .3bar to .45bar, which is the opposite of how the supercharger should be functioning. I will check those grounds and make sure everything is still tight and wired up. |
#4624 |
I think it's in CSG's PDF or email he sends you. He was pretty clear about it to me. This is likely your issue if you havent done the entire process, it really makes a difference.
TomR
#4625 |
Drives: 15 BRZ, 2020 C8, '70 Elky, 06 TBSS
Is that a new issue running the same tune or issue with a new tune?
#4626 |
Drives: Honda Insight
Has anyone had to replace missing parts from their kit?
My MAF housing adapt wasn't included in the kit (even though it was checked off on the parts sheet) and I can't seem to Google it as an individual item. Is there a more direct way to contact Edelbrock than their support line? After 3x attempts all 30min plus tries I thought there had to be an alternative. A year of this thing collecting dust and now I finally start to assemble and in the final stretch I discover this *sigh*. |
#4627 |
Drives: BRZ ts
Calling them is a nightmare.
#4628 | |
#4629 | |
#4630 |
CEL P015B P015A
Hey all, anyone else seen these codes? I recently shifted to Delicious and it's been nothing but trouble. Got an updated tune and did an idle realest, 12 days later the fault came back Called delicious and was told that the most recent ECUTek update has seen a lot of both of those codes. DT says it's an ECUTek problem.
Can anyone shed some light on those codes? I know it has something to do with throttle response and the O2 sensors, but I'm a bit unclear on it. Thanks everyone |
#4631 | |
TomR
#4632 |
Fair question, but no the O2 is fine and works with no issue on the tune from Edelbrock. Haven't actually needed with the sensor, stock exhaust.
#4633 | |
https://datazap.me/u/snowtaipan/p015...?log=0&data=28 |
#4634 |
I recently had an update on my ECU tune and didn't have any issues with new codes. I've never even seen those before and I'm running my A/F wideband farther down from the original location. I believe there is a ms delay adjustment in ECUTEK so it can properly gauge when the pulse wave hits the sensor. Don't have access to my software right now to confirm.
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 01:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 05:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 03:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 11:09 PM |
