06-08-2020, 06:03 PM | #15 |
Drives: '23 BRZ
At ~56/44 weight distribution post-swap, the FT86 isn't an ideal platform for a big-power LS IMO, but of course it can be done...
I'm coming from a 6.8 LS3 swapped FD RX-7, which at 50/50 post swap is a better place to start. But yeah, if you're not doing the work yourself you'll come out WAY ahead getting a C6 Z06. |
The Following User Says Thank You to ZDan For This Useful Post: | p1l0t (06-09-2020) |
06-08-2020, 06:04 PM | #16 | |
Drives: Q5 + BRZ + M796
Roughly $35-40k if you want full canbus integration with a Motec. PureAuto could set you up. In the end, you won't have a Z06 drivetrain. You will have a LS7/LT1 or whatever engine with a Camaro T56. I haven't seen anyone swap a torque tube and rear transmission into an 86, but if your pockets are deep then anything can be done. I would just buy a used C6 Z06. Prices have come down a lot. You will have better weight distribution than a swapped 86 and a stronger platform. It won't be unique, but you can always twin turbo it or something.
06-09-2020, 09:02 AM | #17 |
Drives: 2015 FRS - FFR GTM
Here you go.....
https://www.corvetteforum.com/forums...and-sport.html grand sport 29K miles..... a bit pricy but nice As a sidebar,, if you buy a Vette,, buy it from an old guy. One that spends it life in the garage and only comes on the weekends. There are plenty of them like this,, trust me.
2015 FR-S - One Day I'll Finish The Swap |
The Following User Says Thank You to gtpvette For This Useful Post: | Dadhawk (06-09-2020) |
06-09-2020, 09:44 AM | #18 | |
Site Moderator
Drives: Stuff
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
06-09-2020, 11:22 AM | #19 | |
Those that can do it are not asking if they should or what it costs. The impression seems to be that it is cheap, easy and fast to swap an engine. I suppose the availability of kits does make it ever so slightly easier than six or seven years ago but it is still not cheap nor fast. There are probably several hundred half done projects sitting and rotting under tarps beside garages for every completed swap no matter what year, make and model car you are talking about.
The Following User Says Thank You to Tcoat For This Useful Post: | Dadhawk (06-09-2020) |
06-09-2020, 11:44 AM | #20 | |
1st86 Driver!
How can that be?!? Heck on one documentary, I saw them install it while it was running and half the crew was just dancing around....
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (06-09-2020) |
06-09-2020, 12:08 PM | #21 | |
06-09-2020, 12:18 PM | #22 | |
Rust bucket enthusiast
The swap does not end at "Ok, I want to do this and so because I want to, I can." Square peg into round hole doesn't begin to cover it. More like squeezing an orange through the eye of a needle and intending for it to look like an orange at the end. |
06-09-2020, 12:30 PM | #23 | |
06-09-2020, 01:33 PM | #24 |
The Following 3 Users Say Thank You to DarkPira7e For This Useful Post: |
06-09-2020, 02:12 PM | #25 |
1st86 Driver!
OHHHH! I thought that was just a fancy shipping container....daaayyyymmmmm
06-09-2020, 02:48 PM | #26 |
But they cost too much!
06-09-2020, 02:59 PM | #27 |
Can get an LS1 for like $1500-2500 freedom bucks and put it into just about any car if you are a good enough welder/fabricator...
Sent from my SM-G975U using Tapatalk |
06-09-2020, 02:59 PM | #28 |
Shit I shouldn't have posted that how do I delete again?
The Following User Says Thank You to p1l0t For This Useful Post: | DarkPira7e (06-09-2020) |
Similar Threads | ||||
Another V8 Swap | DustinS | Engine Swaps | 1305 | 04-12-2024 04:32 PM |
2JZ Swap - Looking for Labor Info from Swap Shops/XP'd Members | Cookiemonster | Engine Swaps | 18 | 05-25-2019 12:40 PM |
Dead RB25 Swap, Alive 2jz swap | -Phil | Engine Swaps | 72 | 09-15-2018 02:35 PM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
2JZ swap? | jordydiaz | Engine Swaps | 44 | 05-21-2015 10:19 PM |
