Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
06-10-2020, 10:08 PM | #15 |
Drives: '13 FRS - STX
con·serv·a·tive
/kənˈsərvədiv/ adjective holding to traditional attitudes and values and cautious about change or innovation, typically in relation to politics or religion. Similar: lame |
06-10-2020, 10:14 PM | #16 |
Drives: '24 GR86
Aware of the dictionary definition. Just a ‘from left field’ analogy.
06-10-2020, 10:43 PM | #17 |
Only users lose drugs.
Drives: All the time
Was that a simile or a metaphor..? 😁
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
06-30-2020, 03:10 PM | #18 |
Drives: 2016 oceanic frs
hey all, sorry for necroposting but I just wanted to thank everyone. I put on adjustable endlinks and aligned it and it drives well now. TCS still activates early but it drove very well on a track with tcs off.
I am hearing some popping noises when turning but I think that is my sway bar not torqued correctly (I dont have anything to torque the sway bar... ) |
The Following User Says Thank You to degozaru For This Useful Post: | CrowsFeast (07-06-2020) |
07-06-2020, 01:27 PM | #19 |
Drives: 2013 BRZ Sport-Tech
OP actually came back with the resolution!
Now go pick yourself up a torque wrench |
The Following User Says Thank You to CrowsFeast For This Useful Post: | venturaII (07-15-2020) |
07-14-2020, 02:00 PM | #20 |
First check the tightness of your end links, particularly where they attach to the front struts. If they're even slightly loose, they will clunk. If those are tight, you might have a look at your front strut hats/bushings....they're a known problem area. I've already had mine replaced once under warranty, and they're clunking again now at 70K miles... They'll make weird popping/clunking/spring noise when turning and occasionally going over speed bumps...
07-14-2020, 02:56 PM | #21 |
Drives: 2023 BRZ
Really?
C'mon, dude. Before you start throwing stones you may want to review the primary factor in our civil war, and what side the conservatives were on.
Director of Rocky Mountain 86CUP
Similar Threads | ||||
Tein Flex Z Preload Help! | trinidadj | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 20 | 03-15-2017 10:44 PM |
Coilover Preload collars keeps coming loose | BDotG | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 1 | 11-21-2015 10:23 PM |
Benefits of a right preload adjustment? | Walla Walla | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-12-2015 10:39 PM |
FS (MI): Front strano swaybar, rear wrx swaybar | Aznsky | Brakes, Suspension, Chassis | 4 | 11-04-2014 02:09 PM |
Stance SS coilovers preload? | CyberAkuma | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 10-16-2014 02:26 PM |
