Old 09-22-2020, 04:50 PM   #29
Icecreamtruk
Drives: Track preped NA FRS
Thanks, I will give it a go, I have two different front pads with different coeficients of friction, lower one is in at the moment (which is the same as rear, my rear brakes are kinda big compared to standart brakes by contrast). I can always put the fuse back in and pedal dance it, just looking at learning a bit more about threshold braking without the ABS holding my hand for the time being.
Old 09-22-2020, 05:53 PM   #30
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by rice_classic View Post
Did you ever remove your steering wheel or install an aftermarket wheel?
No, the car is mostly stock and the steering wheel has never been removed. Mods are camber plates, Bilstein B8s, Swift SpecR springs.
If you've never removed your steering wheel I think the likelihood of your Steering Angle Sensor (clock spring) being the culprit is low.
Might look into a used ABS unit if that will fix...
But then again I might just keep motorin on as is!
One thing's for sure, my 240Z never woulda did this to me!
Old 09-23-2020, 03:38 PM   #31
Remember, that published friction alone, is only the peak friction a given pad can make at a given temperature. It doesn't indicate the type of response, bite, release, and modulation the pad has at a given temperature or friction.
Would it surprise you to know that the W5 is actually a higher friction pad than the C2? The C2 is stiffer, and has a more immediate, linear response than the W5, so while the C2 has lower peak friction, it engages more readily, in this case, leading to a front biased response to your brake pedal input!
ZDan (09-23-2020)
Old 09-24-2020, 08:05 AM   #32
ZDan
ZDan's Avatar
Drives: '23 BRZ
Thanks for info! It doesn't surprise me but it does make me wanna get matching C2 rears for more initial bite at the rear. But the rear W5s seem like they're gonna last forever!
Old 09-24-2020, 01:53 PM   #33
They're going to go forever, because the C2 is doing more than it's share of work!
The W5 will have enough to stabilize the car, but not enough to really make the rear tires contribute as much as they can before the fronts are overwhelmed.
Not a huge priority, but you'll see some stopping distance improvements once you square up the compounds.
ZDan (09-24-2020)
Instability under hard braking on track, rear cross camber, road undulation, or toe? SmoothIsSlow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 11 06-26-2019 02:58 AM
Had trouble engaging ABS at the track this week; how come? SmoothIsSlow Suspension | Chassis | Brakes -- Sponsored by 949 Racing 23 06-04-2019 08:54 AM
Trouble at Track, Need Help Lunatic Scion FR-S / Toyota 86 GT86 General Forum 43 07-20-2014 07:12 PM
Braking system concern after track incident SubiePig Tracking / Autocross / HPDE / Drifting 22 01-22-2014 07:35 PM
Help me track down my braking problem :( #87 Other Vehicles & General Automotive Discussions 32 09-26-2011 12:49 PM
