Software Tuning Discuss all software tuning topics. |
05-28-2020, 10:35 PM | #15 | |
Drives: brz
It seems to run great besides this 85% throttle thing. I will see what they say. Thanks for your help Last edited by solidsnake11; 05-29-2020 at 12:03 AM. |
05-29-2020, 01:03 AM | #16 |
Drives: brz 2017 hksv2
they told me I couldn t flash other regions' calid , what they tell you doesn t matter, they still can help you debugging This or at least try to understand why the fuel cut
The Following User Says Thank You to tomm.brz For This Useful Post: | solidsnake11 (05-29-2020) |
05-29-2020, 03:13 AM | #17 |
but hey first try disabling launch and flatfoot!
Didn vtec enabled with the same custom maps you did on the cpc output? was sufficient the a01g switch? |
05-29-2020, 06:15 AM | #18 |
Drives: brz
05-29-2020, 06:27 AM | #19 |
well at least someone that finally confirm USDM racerom patch don t work good
Also, just for more integrity, put X axis on the intake cam you did for Vtec as Engine load as the stock table instead of MAP and move the activation map you did(can t remember maybe Custom Map N? ) before the cam custom map Ecu reads them in alphabetically order but I saw you put some deactivation delay so it s probably already ok, try anyway to put them in correct order just to avoid strange behaviour |
05-29-2020, 07:30 AM | #20 | |
Drives: FT86
yes can confirm racerom 9.1 seemed stable very few bugs. Racerom 10,11,12 quite a few strange bugs especially on 2017+ cars and especialy on non european roms ie usa roms. |
05-29-2020, 07:40 AM | #21 |
Drives: brz
With launch turned off and launch retard map off it has ran flawless. Turning to 8400rpm
Now what? A01G did the same as A01C with the mystery fuel cut with launch and map enabled. |
05-29-2020, 08:29 AM | #22 |
now you can ignore the bug, put accelerator trigger for launch a bit higher
and maybe enable launch only on another map on the cruise lever and then switch over to the stable map or you do debugging with ecutek support if they are willing to |
05-29-2020, 09:30 AM | #23 |
Drives: brz
The fuel cut only happens in lfa 3.
Last log never went in lfa 3 |
05-29-2020, 10:43 AM | #24 |
Drives: brz
I sent Ecutek an email
Do you think this map could cause it fuel cut. Boost Target Mode/Gear Limiter |
05-29-2020, 10:48 AM | #25 |
no, that modifies only the target when you have an ebcs
it won t fuel cut ever Neither boost limit that you already encountered days ago will cut fuel, it s cut accelerator pedal % |
05-29-2020, 10:57 AM | #26 | |
Drives: brz
05-29-2020, 12:34 PM | #27 |
it's sketchy as hell , i see what you mean
i think fuel cut is an error from them and they meant throttle closing Anyway you set boost limit to 4 bar, it shouldn't trigger Also it fixes by disabling launch, so i guess it was that Last edited by tomm.brz; 05-29-2020 at 12:46 PM. |
05-29-2020, 01:04 PM | #28 | |
Drives: brz
Here is my answer from ecutek
Similar Threads | ||||
ABS C1288 - ECU Matching failed | MatGO | Issues | Warranty | Recalls / TSB | 21 | 05-30-2022 09:19 AM |
Rocker arm failed | displacedTexan | Issues | Warranty | Recalls / TSB | 77 | 08-22-2018 06:16 PM |
AC failed under 6 years. | wparsons | Issues | Warranty | Recalls / TSB | 5 | 05-16-2018 11:08 PM |
Hlep. I failed. | Shaisters | Northwest | 14 | 06-02-2016 10:56 PM |
Nameless overpipe/downpipe welds failed and perrin endlink failed | stockysnail | Northwest | 4 | 01-14-2016 06:27 PM |
