02-03-2016, 09:39 PM | #729 |
just an FYI, I built a similar plow years ago with a cutting edge and it worked well until I picked up a small crack in the concrete. I came to an unpleasant and abrupt stop luckily I was going quite slowly. I was not going to make a spring breakover so I replaced the cutting edge with a solid 2 inch round of steel. it weighed enough to stay low in the snow but was able to jump over small obstacles.
oh, bye the way harbor freight makes a remote control winch for atv"s that should work well. |
02-04-2016, 08:48 AM | #730 | |
Drives: Sterling BRZ Ltd
For the control the wires are actually plenty long enough to run in the cab, already ran them in.
02-23-2016, 06:53 PM | #731 |
Winter down time getting to me, Garrett 60-1. This shares a Stage 3 turbine wheel with the T04E 50 Trim so its hot side swappable. I'll be running this instead of the Borg, Borg for sale!
The Following User Says Thank You to mrk1 For This Useful Post: | [YOYO] (02-23-2016) |
03-13-2016, 10:43 AM | #732 |
Got out the saw all, taking the jump to full cage
The Following User Says Thank You to mrk1 For This Useful Post: | civicdrivr (03-13-2016) |
04-28-2016, 10:19 AM | #733 | |
Drives: 2015 Scion FR-S RS 1.0
I was really curious where you were first planning to go with your intake scoop. I thought to myself, why not still use what you initially had with the small duct, but make a box on the backside to enclose the filter. That way your not sucking in engine bay heat. Something like this. Excuse my freehand drawing skills with a mouse. Not questioning your choice of where your cold air intake is, just curious what your initial idea was porting through the radiator support. |
05-01-2016, 03:34 PM | #734 |
I don't mind filters on turbos at all, my intercooler is more then up to the task of cooling the charge. I do have a filter in the bumper with the 3" GT28, if I go back to a 4" intake turbo I would have no second though about going back to a plain filter.
I wish I had a dollar for every time someone called it a hot air intake. There are other factors that are bigger limits on power then the intake air temp.
05-01-2016, 03:37 PM | #735 |
The roll bar is completely out and ready to start on the cage.
My buddy came over to remove my roof skin, he is a pro body guy and was excited for the job. He removed the panel in completely reusable shape. Even though it may not be going back.
The Following User Says Thank You to mrk1 For This Useful Post: | solidONE (05-04-2016) |
05-01-2016, 06:52 PM | #736 |
Shaving unnessecary brackets from the interior
05-04-2016, 04:36 PM | #737 |
Got my seat in, always nice to build around the seat that will be used. This is the Pro Light from GP Race, I'm told this is one of the first in the US. Super happy with the seat, FIA Approved and very comfy. Team Driving Impressions is importing these now from Europe.
The Following User Says Thank You to mrk1 For This Useful Post: | 8R6 (05-11-2016) |
05-05-2016, 02:54 PM | #738 |
crew chief
Drives: Race car FR-S
did you weight the roof skin by any chance?
05-06-2016, 05:29 PM | #739 |
I didn't but I will when I get it back from the body shop, it was heavier then I expected. There is a mold being made.
Since I am putting a roll cage in this car I removed the center support as well, so even more weight off the top, that alone was more then the skin.
05-06-2016, 05:41 PM | #740 |
Off Topic
05-06-2016, 07:51 PM | #741 |
Carbon / Kevlar
05-06-2016, 08:09 PM | #742 |
Y u do dis?
No roof > any roof.
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now. |
Similar Threads | ||||
AMR Performance: How to remove the factory bumper (walk-through images inside) | AMR | Engine, Exhaust, Transmission | 9 | 04-10-2013 07:45 PM |
86 Modelista walk around and GT Limited | SoCal_86 | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 04-24-2012 11:53 AM |
