Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
04-04-2018, 12:30 PM | #15 |
StreetKart
Drives: 2014 Scion FR-S Monogram
For example the braces that I will be getting will be the ones that connect the rear subframe to the floorboards as it would limit the side to side and front to back motion of the subframe but maintain oem compliance up and down. This would retain ride quality while having a minimal effect on NVH. The whiteline subframe inserts stiffen everything up.
Another one that intrigues me is the trunk cage. one of the tS cars came with a trunk Vbrace and i've always heard of people noticing the rear deck click goes away when you brace it. in addition to added stiffness it would be great for hooking a cargo net to as a place to hold small things in the trunk in place.
TRD|Verus Engineering|Titan7|DEZOD Motorsports|JDL Auto Design
04-04-2018, 02:35 PM | #16 | |
Drives: Crapcan
What is the OP's purpose for their car? I track my car, and aside from some bushings i'd like to swap, I don't really feel the need for additional bracing. |
04-04-2018, 02:58 PM | #17 |
StreetKart
This isn't a which parts should i get. It's an inquiry as to which ones work. I'm trying to help pool information.
04-04-2018, 03:46 PM | #18 | |
The Following User Says Thank You to norcalpb For This Useful Post: | SuperTom (03-06-2022) |
04-04-2018, 04:09 PM | #19 |
Only users lose drugs.
Drives: All the time
Vibration certainly is, but I think outright flex is an even more obvious one. And vibration is only an issue as it translates to flex, so while you might be transferring more vibration, it could be a non-issue if it isn't at a frequency where it actually causes work hardening of the panel joints. I both track my car on occasion as well as drive it year round in terrible road conditions. I'm FAR less worried about the flex from going around a corner on a track than I am about the flex generated from smashing down a road full of potholes where driving under the posted speed limit puts you at genuine risk of being run over by the rest of the traffic.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
04-04-2018, 04:48 PM | #20 |
Chassis are designed to flex in certain ways to relieve stress. Stiffening Willy nilly will just put stress where it wasn't intended to be and could cause failure much sooner than if the chassis was left as designed. There are a handful of people in the world who understand this chassis down to a tenth of a mm, the rest are just guessing.
04-04-2018, 04:49 PM | #21 | |
I only have flexible V bars and I did an off-road section of SF (it was on a street, but there were steel plates and uneven ground) and it was amazing how the chassis flexed over the bumps. I could feel all my shocks/springs working in series like a truck going over a technical off-road section. It was amazingly comfortable and if I still had my Grimmspeed, Tanabe, or Hotchkis strut bar I would’ve been crying after. |
04-04-2018, 05:18 PM | #22 | |
04-04-2018, 06:44 PM | #23 |
I think a lot of people are confused here. Chassis rigidity is good for performance and comfort. It's why rigidity goes up for new cars in all segments. You let your suspension do the suspending. Either way, there isn't a single person on earth asking this question where a brace would be the best place to spend money on speed or comfort.
Drive upgrades. Don't buy them.
04-04-2018, 07:04 PM | #24 | |
Drives: 2019 Mazda Miata RF
04-04-2018, 07:24 PM | #25 | |
This isn’t an e30 bmw or NA Miata, it’s rigidity is going to last. |
04-04-2018, 07:38 PM | #26 | |
04-04-2018, 07:52 PM | #27 |
Compliance comes from suspension
04-04-2018, 08:50 PM | #28 |
Similar Threads | ||||
Agency Power Chassis Braces and Strut Bar? | megamarines | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 3 | 07-17-2015 10:23 PM |
DIY Lower Chassis Braces | vividracing | DIY (Do-It-Yourself) Guides | 0 | 04-08-2015 01:30 PM |
TB Performance Products Chassis Braces | TB Performance Products | Brakes, Suspension, Chassis | 6 | 08-20-2013 07:58 PM |
Carbing Chassis Braces | ttknf | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 24 | 08-14-2012 09:21 PM |
Coilovers, swaybars, chassis braces and more! | No Limit Motorsport | Brakes, Suspension, Chassis | 0 | 08-05-2012 11:31 AM |
