Software Tuning Discuss all software tuning topics. |
04-07-2020, 08:42 PM | #15 | |
Drives: 2018 Toyota 86
I've linked another video for it, the bouncing is at 00:18. Not sure how I can modify the MAF table to improve it. And there is some grinding noise when rev changes, is that normal or a leaking? Thanks. My current MAF correction table: |
04-07-2020, 08:46 PM | #16 | |
But at least the exhaust sound is just as good as I expected. |
04-08-2020, 01:59 AM | #17 | |
Drives: FT86
Dont change the maf aftercstart tavles what you have is correct. Any grinding noise has nothing to do with tune its a hardware issue. The rpm change may be incorrect settings in ghe idle target tables |
04-08-2020, 10:03 AM | #18 | |
04-08-2020, 11:07 PM | #19 |
Drives: FT86
04-12-2020, 05:32 PM | #20 | |
After that one-time bouncing back the rev is around 1.2k and quite steady for some seconds, not sure if that is a little bit too low for warming up in winter. Last edited by powerwdp; 04-13-2020 at 12:52 AM. |
04-28-2020, 09:20 PM | #21 |
Updated:
I just rise the stock oft v4 rune idle target table A/B from 1200 to 1400, MAF correction row 1-2 starting from 25, 3-8 stay the same as lower value. There is still one small rev bouncing at cold start but is quite stable afterward and is high enough for winter warming up. |
Similar Threads | ||||
Unstable revs when switched to R/D from P | powerwdp | Engine, Exhaust, Transmission | 3 | 03-22-2020 10:53 AM |
Money Shifted my car, should I be nervous? | norcalpb | Engine, Exhaust, Transmission | 11 | 12-31-2019 06:38 AM |
Unstable idle when A/C cuts out | paulca | Engine, Exhaust, Transmission | 14 | 10-24-2015 09:18 PM |
2.5L with lower revs/more torque, or 2.0L with higher revs? | Superhatch | Engine, Exhaust, Transmission | 124 | 08-28-2013 12:20 PM |
Unstable feeling | Toyobaru808 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 11 | 06-28-2013 11:06 AM |
