Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
02-07-2016, 08:45 PM | #1 |
Drives: WRB Limit BRZ 2015
Grinding noise in neutral
What could this be? Sitting in my drive way in no gear itll make a grinding noise but when I push the clutch in itll go away, it also doesn't make the noise when I go as far as I can tell
02-07-2016, 08:49 PM | #2 |
That's the throw out bearing, it's normal. If you get a screeching sound get it replaced. Until then turn up the tunes.
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
02-07-2016, 10:56 PM | #3 |
義理チョコ
google "neutral rollover."
02-08-2016, 12:14 AM | #4 |
Drives: 2013 FR-S 10 series [755]
Is it a serious problem? Because i have that noise too.
Is it self fixable or do i need to take it back to toyota? |
02-08-2016, 12:24 AM | #5 |
義理チョコ
If the transmission doesn't make any noise while driving then there's nothing wrong.
Idle up to about 2K RPM. I bet the noise goes away.
02-08-2016, 12:31 AM | #6 | |
I have a N1 exhaust...so i cant hear if the noise goes away or not.... I just try with my dad rev about 2000rpm,, the rattle noise still exist! |
02-08-2016, 12:43 AM | #7 |
義理チョコ
Do you have a lightweight flywheel?
02-08-2016, 12:54 AM | #8 |
02-08-2016, 01:02 AM | #9 | |
I'd suggest you pay a visit to your dealer and ask to listen to another FR-S for a comparison. While you are there, you may consider asking a tech for an opinion. humfrz |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (02-08-2016) |
02-08-2016, 01:08 AM | #10 | |
It kinda sounds like a quiet clothes dryer, running on low speed, when it's empty. humfrz |
02-08-2016, 01:10 AM | #11 | |
I just did a little bit research right now,,many people say its a high pressure fuel injection, and its normal. so i dont know... |
02-08-2016, 01:12 AM | #12 |
義理チョコ
It's probably a good idea to have a dealer tech give it a listen. A little neutral rumble is no biggie but who can say when it becomes excessive?
02-08-2016, 01:15 AM | #13 |
義理チョコ
We're specifically discussing the sound of the transmission in neutral. this sound will disappear when you push in the clutch. If it doesn't disappear then it's not the transmission.
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (02-08-2016) |
02-08-2016, 01:24 AM | #14 | |
But i do have the rattling noise problem when idling/neutral. |
Similar Threads | ||||
Transmission Noise in Neutral @ Cold Start | Jackal84 | Issues | Warranty | Recalls / TSB | 57 | 03-01-2021 03:21 PM |
clutch grinding noise | BoxerBlock88 | Engine, Exhaust, Transmission | 13 | 11-14-2015 06:12 AM |
Grinding noise during slalom | JM197 | Issues | Warranty | Recalls / TSB | 9 | 08-11-2014 10:50 PM |
Grinding noise? | frs10 | Issues | Warranty | Recalls / TSB | 7 | 09-20-2013 10:57 AM |
MT, neutral 15-10mph slowing, ratcheting noise | bcj | Engine, Exhaust, Transmission | 7 | 04-18-2013 12:33 AM |
