Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
12-16-2020, 08:19 AM | #1 |
Drives: 2016 Sport Tech BRZ
High pitched squeal only when braking only with a winter wheel
One would think that my brake pads are in need of a replacement , but the squealing never happened with my stock wheels.
The winter wheel set up is the same specs as the oem wheel and tire. One notable oddity is that I had to reuse an oem lug nut because one of the aftermarket lugnuts looked deformed from from the package. Any tips are appreciated, thank you. |
12-16-2020, 10:25 AM | #2 |
Drives: 2014 GT86
Squealing .. if as in brakes squeal .. my guess is due lower overall limit, and some real winter tires having (reasonable, but) less grip on tarmac (for gaining most grip on snow/ice), it's simply harder to bed brake pads properly, as braking always is lighter, brake pads/rotors never get upto temps, bedded layer gradually wears off and squeal returns.
12-16-2020, 02:00 PM | #3 |
Thanks for replying,
So you're saying its because of a colder temperature and me lightly braking keeps the brake system from warming up? I can't seem to understand the correlation between the tires and brakes affecting each other from your statement. |
12-16-2020, 02:07 PM | #4 | |
Rust bucket enthusiast
I don't see how there's a correlation at all, unless someone bent your dust shield when putting the winters on, or if there's a rock stuck in there. |
12-16-2020, 03:57 PM | #5 |
Yeah me neither. Gonna be real I'll have to google what a dirt shield is, but nevertheless there's no squealing sounds when the stock wheels are on.
I appreciate the insights though! |
Similar Threads | ||||
High pitched chirping when AC on?? | Spectral Entity | Issues | Warranty | Recalls / TSB | 8 | 01-29-2021 05:50 AM |
High pitched noise when lightly braking | brsaresmgs | Issues | Warranty | Recalls / TSB | 7 | 11-29-2017 12:22 AM |
High Pitched Noise, Engine Off | TheLaughingMan | Issues | Warranty | Recalls / TSB | 10 | 01-04-2014 05:25 PM |
not very loud, but high pitched sound at 70+mph | fiveoneoh | Scion FR-S / Toyota 86 GT86 General Forum | 16 | 10-16-2013 10:30 PM |
TSB - FRS (re: High pitched chirping...) | PNW FRS | Issues | Warranty | Recalls / TSB | 1 | 01-19-2013 01:05 AM |
