Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > 2nd Gens: GR86 and BRZ > BRZ Second-Gen (2022+) — General Topics
BRZ Second-Gen (2022+) — General Topics General topics for the second-gen BRZ
Old 08-31-2023, 06:39 PM   #15
14stu
14stu's Avatar
Drives: 2014 Subaru BRZ
Originally Posted by new2subaru View Post
I have the sprint kit too. Just out of curiosity what is your favorite brake pad? I'm do for a set and have been looking around.
I'm a big fan of the Ferodo Pads, they're loud and dust a lot; however, they work so damn well they make other pads hard to go back to. I've run all the versions from DS1.11 to DS3.11 with all of the intermediate steps, they pretty much all work similarly but if you have a compound that can't take the heat you're putting into them, they'll wear at a faster rate. They've gone up in price in recent years, but if you like a firm brake feel and smooth release, they're just hard to beat.
GLoC/Carbotech are fine (I've got a set one the car right now), but when available, I'll still spring for the Ferodo pads. The Hawk DTC pads can work too (60's or 70's with the sprint kit), they're as loud and dusty as the Ferodos but don't work quite as well and the 70's don't like to be cold (I'll drive the Ferodos daily with my very short commute, but the DTC 70's are real track pads that do not work when cold so you do not want to daily drive them). I have a track buddy who liked the CSG pads, but I haven't tried them personally.
14stu is offline   Reply With Quote
The Following User Says Thank You to 14stu For This Useful Post:
JRitt (10-17-2023)
Old 08-31-2023, 06:54 PM   #16
new2subaru
Weight Weenie
Drives: 15 FR-S
Thanks! Essex claims that the DS3.12 are almost silent and is what they're suggesting next. They don't offer the DS3.12 for the rear and are suggesting the DS1.11 I'm not sure if I'm crazy about mixing pads...
I started with a set of DS2500 as per their suggestion and killed them in no time. I'm a bit gun shy now. The car is primarily a track car now that I do drive on the street occasionally.
The Following User Says Thank You to new2subaru For This Useful Post:
JRitt (10-17-2023)
Old 09-01-2023, 10:34 AM   #17
autosenses
autosenses's Avatar
Drives: 22 Raven 86, 19 STI, 15MK7 SE daily
As of right now, seems the ESSEX'S system is the best option for us. Some guys are running front and rear and some just front.
I just put in Hawk DTC 60 pads and fluid. Breaks are significantly better but a lot nosier and dusty.
autosenses is offline   Reply With Quote
The Following User Says Thank You to autosenses For This Useful Post:
JRitt (10-17-2023)
Old 09-01-2023, 04:10 PM   #18
14stu
14stu's Avatar
I was running the 3.12's front and GLoC R10's in the rear, balance and performance worked well.
new2subaru (09-01-2023)
Old 09-01-2023, 10:19 PM   #19
falcon_wizard
Drives: BRZ 2013
I had both the ds2500 and ds1.11. The 1.11 are in a complete different category and much more durable than the ds2500 for track use, and can still be used on the street with minimal fuss and little noise when bedded-in following ferodos instructions. If you drive them on the street a lot between track days, the pad transfer layer will eventually wear off and they’ll become noisy again, so at that point you re-bed them and they’ll be near silent except a tiny bit of squealing when coming slowly to a full stop, but for me it wasn’t objectionable.
falcon_wizard is offline   Reply With Quote
The Following 2 Users Say Thank You to falcon_wizard For This Useful Post:
JRitt (10-17-2023), new2subaru (09-02-2023)
Old 09-02-2023, 03:44 PM   #20
new2subaru
Weight Weenie
Drives: 15 FR-S
The DTC 30/60 I was using on OEM where the same. Bed them in prior to track and they were good. Once you were on the street it didn't take long for the compound on the rotor to vanish. They were loud!
I've spoken to Essex about using the 3.12 on the front and 2500 on rear and they don't see that as an issue.
Old 09-04-2023, 03:20 PM   #21
alex87f
Meow
alex87f's Avatar
Drives: GT86 (now sold)
Originally Posted by Lelandjt View Post
Yeah, I guess that's the best option. Kinda surprised it doesn't included rear rotors & caliper brackets.
I'd be nice if they'd sell the front rotors with brackets to run stock calipers.
The rotors are massively thicker than stock. Wouldn't work.
What you're after can likely be achieved for much cheaper with some good pads, disks, hoses and fluid, whilst retaining the stock braking system.
alex87f is offline   Reply With Quote
Old 09-04-2023, 11:51 PM   #22
Lelandjt
Drives: '04 STi, '12 Mazda 3 Hatch
I thought there would be enough demand for this that someone would be selling slightly larger 2-piece rotors and caliper relocating brackets. I got a kit like that for a '98 Impreza.
Lelandjt is offline   Reply With Quote
Old 09-05-2023, 09:31 AM   #23
alex87f
Meow
alex87f's Avatar
Well if you've got one grand to spend, you can upgrade the existing system with better components (which can take a lot of abuse).
If you've got three grand, you can buy the AP front kit.
The market for "I want slightly larger disks even though the car doesn't really need'em, and I'm not willing to pay for a BBK" is just that small I'm afraid . Especially considering there are parts bin specials out there (PP brakes, WRX calipers, CTS-V calipers) that work.
Old 09-05-2023, 03:40 PM   #24
OkieSnuffBox
Drives: '23 BRZ Limited
Larger rotors create more brake torque for a given squeeze. They can absorb more heat and they cool faster. Better calipers have their own advantages over stock calipers but the easiest, cheapest way to improve your brakes (after pads & fluid) is larger rotors and they're usually much cheaper than calipers.
Stock brakes are more than capable of locking up even Hoosiers, so why do you NEED more front brake torque?
You've mentioned before you aren't going to be tracking this car, but you want to drop as much weight as possible.
AP Sprint Kit, Rear seat delete, lightweight battery.......you've just dropped 65-70 lbs. You can drop some more with a single exit, Ti Tomei exhaust not sure how much. Depending on what you do with wheel tire setups, you may or may not lose weight....TWS are about the lightest wheels you can buy I think, but they do not come cheap.
But you're about $10k deep at that point, for what? I seriously doubt you'll notice a big difference on the road for less than a 100lb weight drop.
For instance my 18x9.5s are lighter than the factory 18x7.5 (and they are just flow formed, not even fully forged), but I suspect the wider tires offset that.
"95% of the time, more throttle is the answer. 5% of the time, it ends the suspense."
Old 09-05-2023, 08:30 PM   #25
smoltz
Drives: 01 911 Turbo, 03 G500
Sprint kit is a waste of money unless all you care about is looks, just run the factory setup. It's very good. Select new pads suited to your application if you feel the stock ones are inadequate.
smoltz is offline   Reply With Quote
Old 09-29-2023, 04:50 PM   #26
vindiesel
vindiesel's Avatar
Drives: 2023 brz limited 6mt red
Vote is for stock brakes +pads. Nobody gives a shit at the car show or your forum signature your weight reduction mods. If your not tracking and trying to obtain a particular lap time then aftermarket caliper setup is a waste.
True weight reduction would be lose weight yourself and or gasoline weighs 6lbs per gallon. So don’t buy a brake kit and only drive around with a max of 3 gallons of gas in the tank. So that should shed 60lbs. Definitely signature worthy bro (hits vape)
2023 brz red limited 6mt 10k miles ish
2009 Chrysler 5.7l hemi eagle 300c heritage edition 205k miles
vindiesel is offline   Reply With Quote
The Following 2 Users Say Thank You to vindiesel For This Useful Post:
MyHybridBurnsGasAndTires (10-02-2023), smoltz (10-04-2023)
Old 09-30-2023, 11:01 AM   #27
Opie
Opie's Avatar
Drives: 2020 GMC Canyon Denali Diesel
I'll strongly disagree...if you are actually tracking your car regularly and care about pedal feel, actual decreased stopping distances and reducing your consumables cost vs the OEM brakes. The Sprint kit is the way to go.
You will get many more track days out of the pads & rotors before they need replacement, have better control and very likely lower lap times with the Sprint kit.
I, and many other, track focused owners here can attest to that. Pretty sure that if the track time spreadsheet listed brake configutration, many are on an Essex kit.
2020 GMC Canyon Denali Duramax, 2021 Forester Sport, 2000 Subaru Legacy B4 RSK 5MT (JDM Import) and random 86 chassis rebuilds....
Opie is offline   Reply With Quote
The Following 3 Users Say Thank You to Opie For This Useful Post:
JRitt (10-17-2023), new2subaru (10-06-2023), wheelhaus (10-02-2023)
Old 10-04-2023, 10:33 AM   #28
smoltz
I am curious what your personal experience is with this kit and the OEM setup?
I track my car regularly. 25+ days this year. About midway through this season, I "upgraded" to the Sprint kit from OEM.
Keep in mind that the sprint kit includes braided lines, so some of the feel is coming from there compared to stock if you are going from OEM to Sprint.
I was running CSG C1 pads with OEM rotors on the front and I switched to AP Racing Sprint w/ DS3.11.
I wouldn't say they are worse than the stock setup I had, but they aren't appreciably better either. I didn't say that they didn't work, I just said they're a waste of money.
There is talk of this being cheaper in consumables, but I don't see how that's going to work out. The AP rotor rings are not cheap and there are no third party options. OEM sized blanks can be bought very cheaply. And while the pads are slightly thicker for AP, since the setup weighs less overall you're putting a lot of heat into the system.
The spreadsheet you referenced doesn't list brake setup so that's neither here nor there. A lot of people might run the sprint kit, but a lot of people go to McDonalds everyday, that doesn't mean the food is good.
At the end of the day it's your money, spend it how you see fit but in hidsight I would have done Brembo BM4 or maybe the Stock Brembo setup or maybe AP endurance, but not Sprint. It just doesn't deliver enough value over the stock seutp for the price. YMMV.
The Following 2 Users Say Thank You to smoltz For This Useful Post:
bkd705 (10-05-2023), blsfrs (10-05-2023)
Search this Thread:
Advanced Search
Lightest Stock Size Wheels Lelandjt GR86 General Topics (2nd Gen 2022+ Toyota 86) 35 03-01-2023 08:58 AM
15" wheels that fit over stock brakes churchx Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 08-19-2017 08:40 AM
Lightest wheels for the $$$ - besides the RPF-1's SubieNate Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 109 02-04-2016 04:50 PM
Lightest Brakes or BBK? Anthony Suspension | Chassis | Brakes -- Sponsored by 949 Racing 39 09-11-2015 02:33 PM
What are the lightest wheels for this car? quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 10-15-2014 05:56 PM
