BT, dpfarr
Old 06-16-2022, 09:52 AM   #4579
GPhilly
GPhilly's Avatar
Drives: 2020 Subaru BRZ (Edelbrock SC)
Review time!
Installation 3/5
This kit is basically bolt on but there are some things you need to look out for along the way. I had a mechanically skilled friend help me through the install, which came in handy for steps like placing the SC manifold on the block. I also installed the JR Dual Oil/Cooler during this. One thing to pay attention to is the clocking alternator step. If you have a newer 2017+ car, the alternator connector cable is on the driver side. If you forget to plug the black connector in like I did, it will give you a massive headache and you wont be able to plug in the connector while the SC manifold is in. 50% my fault for not reading directions carefully, 50% for the photo directions not showing the connector plugged in. I had to grab 2 people to lift the SC enough to finesse the connector in.
The intake box was also a PITA. Its a very tight fit to get the MAF piping to fit into the airbox. The airbox wouldn't clamp correctly so I ordered slightly longer button hex screws so that it could locate the threads easier.
My kit did not also come with a PCV support bracket even though it was checked off on the part list. Luckily the customer service is great and @CSG Mike helped me get a bracket on order.
Some frustrating bits during the install but I'm glad everything is working properly.
Tuning 5/5
I tuned with Zach from CSG and he did a fantastic job tuning my car. Drove the car with light throttle for a bit before doing some pulls for data logs. This was a week process before the final tune. It was really cool to see the power being "unleashed" during the tuning process. This tune was much better then the local tune I previously received, I can tell Zach knows this platform well.
Driving Experience 4.8/5
The linear power feels absolutely fantastic. Made the car a much better daily as well. I am currently seeing about a 8-10mpg drop but the car is becoming more about smiles per gallon. The only reason I cant give this a perfect score is because I expected more power, however I plan on swapping to a catless header and 3" pulley in the near future. I think this will make a difference. E85 is not close to me in CT so I suspect these mods will get me close to the 270-300whp mark without needing to upgrade the clutch.
Overall 5/5
I would recommend this kit to anyone, its hella smooth
GPhilly is offline   Reply With Quote
The Following 4 Users Say Thank You to GPhilly For This Useful Post:
Brewster (06-18-2022), CSG Mike (06-16-2022), FunnyGopher (06-17-2022), Teseo (06-16-2022)
Old 06-17-2022, 06:19 PM   #4580
Decep
Drives: 2013 FR-S Series 10
Oof 8-10 mpg drop you must be enjoying the newfound power I average 26 with my kit and tbh worst ive ever seen is like 24. But i dont beat on it too hard.
2013 FR-S 10 Series ~75k (SOLD)
RCE SS-1 Coilovers
Corsa Catback
Edelbrock Supercharger installed @ 50k
Old 06-19-2022, 04:33 PM   #4581
apatel471
apatel471's Avatar
Drives: 2017 World Rally Blue BRZ
Voltage Drop after installing PTuning flex fuel kit
So I just installed the PTuning v2.2 kit with my preexisting Edlebrock kit but I am having issues with voltage drop right after installation. While idling and accelerating, the voltage drops to 12v but while coasting it stays at 14v. However, the car drives normally with no issues. I haven't connected the PTuning harness at all but only the fuel lines. The reason for this is that I haven't installed the injectors and started the retuning process with CSG yet. Why would installing the fuel lines along with mounting the ethanol sensor and box inside the cabin cause any electrical issues? The harness isn't connected to any part of the flex-fuel kit or even on the car so I'm not sure why this would happen.
apatel471 is offline   Reply With Quote
Old 06-20-2022, 08:19 AM   #4582
GPhilly
GPhilly's Avatar
Yes, its hard to resist the pedal now
My avg is going up now, I have been driving normally on the highway. Saying about 23mpg. The backroads is what destroys fuel economy.
Old 06-20-2022, 06:13 PM   #4583
aKaGorganZola
aKaGorganZola's Avatar
Drives: 2017 BRZ Series. Yellow
So at least for BRZs that's normal operation. They do it to save some fuel mileage I guess according to my buddy who's a master tech. I panicked when I noticed that on mine as well until we finally got to the bottom of it.
aKaGorganZola is offline   Reply With Quote
The Following User Says Thank You to aKaGorganZola For This Useful Post:
apatel471 (06-20-2022)
Old 06-20-2022, 08:11 PM   #4584
apatel471
apatel471's Avatar
Makes sense, I ran it by Zach at CSG and he said the same thing. I guess I never had noticed the voltage fluctuation before on the 17+ screen. Thanks for the reassurance!
The Following User Says Thank You to apatel471 For This Useful Post:
aKaGorganZola (06-21-2022)
Old 06-30-2022, 04:34 PM   #4585
Colin86
Drives: 86
I'm having challenges with my Edelbrock car. All electronics are cutting out/car is stalling. Positive battery terminal got so hot it melted the cover. More details in my thread linked below.
https://www.ft86club.com/forums/show...85#post3532185
I struggle with electrical challenges, any help greatly appreciated!
Colin86 is offline   Reply With Quote
Old 07-01-2022, 02:00 PM   #4586
Rayez08
Drives: 2014 Scion FRS
Just installed the Edelbrock sc kit on my 2014 FRS. My problem is that the car won't start. It will crank but not turn over. I've confirmed that I'm getting fuel and the spark plugs were replaced a year ago. Not sure what I could have done during the install. Any trouble shooting suggestions are appreciated.
Rayez08 is offline   Reply With Quote
Old 07-01-2022, 04:46 PM   #4587
Muskoka800
Drives: 2016 Scion FRS Release Series 2#439
Wow, that sucks.
My first thought was that the fuel pump fuse wasn’t re-installed but you say you’re getting fuel. I’m not sure how you know that but…
Not sure it’s possible but is there any chance you mixed up the four ECU plugs? That stressed me when the time came to plug-in the ECU weeks after removing it.
Other than that double check all the other connections for positive engagement (click!).
My EVAP plug was loose and I got no fire-up until it was clicked in.
Good Luck!
Edelbrock S/C with CSG 94 & 91 maps
TRD Short Shifter, CTS/EvoX Brakes
Ohlin’s R&T Dampers, Hotchkis F/R Bars, Blox LCA & Toe Arms
235F/245R Conti ECS on TRD/Enkei wheels (street),
245/40 sq. A052 on 17x8 720Form GTF2 wheels (track)
Muskoka800 is offline   Reply With Quote
Old 07-01-2022, 09:06 PM   #4588
aKaGorganZola
I've posted before about my issue after install but I had a broken wire to the map sensor that was causing a full rich issue. Car wouldn't fire unless I held the accelerator slightly.
Old 07-07-2022, 12:53 PM   #4589
toast
Drives: 14 BSP Edelbrock BRZ
If that is happening to your positive terminal it is loose and you are getting intermittent arcing. If it isn't loose clean the terminal off, something is inhibiting electricity and raising resistance.
toast is offline   Reply With Quote
Old 07-08-2022, 03:26 PM   #4590
Chris3007
Drives: 2013 BRZ Limited 6MT
Have you done the ECU re-flash yet? If it is not flashed it likely will not run. Also make sure all the harnesses to your ECM are fully seated and locked into place.
Chris3007 is offline   Reply With Quote
Old 07-09-2022, 11:16 AM   #4591
apatel471
apatel471's Avatar
Which oil cooler works the best with this kit? Not looking at the JR DROC. Thanks!
Old 07-11-2022, 11:32 AM   #4592
Colin86
Drives: 86
Why not look at the JR dual radiator/oil cooler? It works great both on street and track, highly recommend. I have a gen1, so I swapped the oil lines so they didn't kink -but I've heard the gen2's don't have that issue.
Vortech Owner Thread & Setup Questions reyruiz191 Forced Induction 340 05-17-2022 12:44 PM
Edelbrock E-Force Supercharger itsibarra Forced Induction 938 07-31-2021 04:48 PM
Most annoyingly over-asked questions on FT86 forums mit_peid Off-Topic Lounge [WARNING: NO POLITICS] 36 01-16-2014 02:48 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) -- General Topics 0 05-24-2012 10:09 PM
