Software Tuning Discuss all software tuning topics. |
06-24-2020, 04:05 PM | #1 |
Drives: turbo frs
grimmspeed ebcs brz install????
Dear all
I need good setup For grimmspeed EBCS WITH EXTERNAL WATEGATE WITH BOOST GAGE car tuned by ecuTek What your recommendation for Port 1.2.3 And where I have to put the T for boost gage Thanks |
06-24-2020, 04:26 PM | #2 |
Rust bucket enthusiast
I put the T for the boost gauge before the bump in the line ( T goes on the engine side) going to the brake booster.
These can be confusing, but I have mine set up so the port on the FRONT is going to the compressor housing, the port on the left (EBCS oriented with the front port facing you and the ports on the bottom half) connected to the wastegate. 3rd port ( on the right) has a muffler on it. Mine is NOT a branded Grimmspeed EBCS< it is a Mac 3 port valve Last edited by DarkPira7e; 06-24-2020 at 05:21 PM. |
The Following User Says Thank You to DarkPira7e For This Useful Post: | gt7877 (06-24-2020) |
06-24-2020, 04:28 PM | #3 |
Drives: turbo frs
Can you please explain with diagram or image
06-24-2020, 04:36 PM | #4 |
WG - WASTEGATE T - Turbo compressor housing. I don't have a photo of where I tapped for boost gauge. Start at the brake booster and work your way down the vacuum line. 4" in you'll feel a hard piece. 1" after that is where I put a T |
06-24-2020, 05:20 PM | #5 |
Just got done work. Here's one fresh from the garage. Be sure if you use a T to try and get a tapered T fitting. |
Similar Threads | ||||
EBCS options | wise345 | Forced Induction | 4 | 12-02-2016 05:21 PM |
Grimmspeed EBCS | TheLaughingMan | Forced Induction | 9 | 08-05-2016 09:39 PM |
Grimmspeed EBCS | lbroskee | Engine, Exhaust, Bolt-Ons | 1 | 05-06-2016 07:10 PM |
EBCS set up options | Brick | Software Tuning | 17 | 04-13-2014 06:48 PM |
EBCS vs MBC | gdrider77 | Forced Induction | 17 | 02-05-2014 10:30 AM |
