05-22-2014, 04:50 PM | #267 |
Never on Time Always Late
Drives: #silenced crickets
Nothing against the "rub doctor," but can we have more unmolested cars chime in to verify if their drive shaft was violated by the TRD part? The violated car car has many small parts installed that may have a part in this inappropriate rubbing.
CO>CA Cartel
05-22-2014, 04:57 PM | #268 | |
Drives: Attitude
The Following User Says Thank You to OrbitalEllipses For This Useful Post: | chanomatik (05-22-2014) |
05-26-2014, 11:45 AM | #269 | |
Drives: 13 FRS
Please don't do stuff like this... Just go to walmart and spend 50 bucks on ramps. Factory scissor jacks aren't really intended for stuff like this and plenty of people have died from cars falling on top of them. Not trying to give you shit but seriously, that's not safe. |
The Following 3 Users Say Thank You to Such Boost For This Useful Post: |
05-26-2014, 02:29 PM | #270 |
Drives: brz
mine has this buzzing vibration in second gear only now... not at a certain rpm, but just no matter how fast I drive in second its there. and I can tell the shift throws are getting longer and longer, witch means that that dumb adapter bolt is coming undone.. again.
05-26-2014, 02:31 PM | #271 |
USMC
Drives: 2013 FR-S 6-MT Raven
Again?? Not cool! I have had and still have that cluttering noise when in neutral when slowing down.
Sent from my SAMSUNG-SM-N900A using Tapatalk |
05-26-2014, 02:52 PM | #272 |
Was so close to ordering until reading the last few pages. Thanks for the info, guys. I recommend letting TRD USA know about this so maybe they will make an upgrade.
05-26-2014, 06:50 PM | #273 | |
Drives: 2003 S2000, 2008 Fit
Canadian Tire sometimes has sales on 2T Michelin jacks for $15.99 CAD (2 per pack). |
05-26-2014, 06:53 PM | #274 | |
Drives: 13 FRS
Figured since he was using two scissor jacks, the idea of spending 150 bucks on a good jack and stands might be ill-received. That being said, I don't own ramps. I use a jack and 4 stands from harbor freight. No problems thus far.
So spool.
Much Power. Wow. |
05-27-2014, 11:00 AM | #275 | |
Drives: 2014 WRB BRZ Limited
Also, it sounds like you have something else going on. When that bolt starts to come loose, throws don't get longer. What happens is the play in gear/in neutral increases, particularly side to side (forward/backward play does not increase). Sounds like the adapter bolt isn't your problem.
The Following User Says Thank You to xxBrun0xx For This Useful Post: | unsurety (05-27-2014) |
05-27-2014, 11:21 AM | #276 | |
05-27-2014, 11:29 AM | #277 |
Drives: Subaru BRZ
Talking about safety - remember when you have your front wheels on a ramp and you start jacking up the rear end there is a chance that the car will roll down the ramp. The front wheels are unaffected with the emergency brake on and the car in gear. Make sure you use chocks.
The Following User Says Thank You to jpit For This Useful Post: | swpbrz (05-31-2014) |
05-27-2014, 01:12 PM | #278 | |
Drives: brz
The Following User Says Thank You to tjohnson104 For This Useful Post: | xxBrun0xx (05-28-2014) |
05-28-2014, 04:58 PM | #279 |
Drives: 2017 WRB BRZ w/ PP
I have the TRD Quick Shifter installed on my BRZ. So far no issues. Took a while for it all to break-in - initially required more effort to shift, was very notchy - but it's gotten better now. Our cars should've come this way from the factory. My BRZ has had no modifications to the driveshaft.
The Following User Says Thank You to tomkozski For This Useful Post: | xxBrun0xx (05-28-2014) |
05-28-2014, 10:57 PM | #280 |
Drives: 2013 BRZ Premium Dark Gray Metallic
Installed mine last weekend and all I can say SWEET!!!!!!!!! Enjoying my SC car more with E85
Similar Threads | ||||
TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 12:14 AM |
Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 04:42 PM |
The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 08:23 PM |
Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 01:42 AM |
