05-01-2014, 07:06 PM | #183 |
Drives: 2014 WRB BRZ Limited
I did. And there is crazy, stupid amounts of play while in gear that definitely wasn't there stock. I've had $1000 beaters with 200k miles and way less shifter play than that. Stock was much better, imo
I'll take a video and post it up in a few. Maybe I did something wrong? Something definitely doesn't feel right Sent from my XT1053 using Tapatalk
05-01-2014, 07:55 PM | #184 |
This should show how much slop my shifter had with the quickshift installed. Did I do something wrong? Don't have any other shift related mods at all.
[ame]http://youtu.be/8445SoYm3T8[/ame] Sent from my XT1053 using Tapatalk
The Following User Says Thank You to xxBrun0xx For This Useful Post: | Mooseknuckle44 (06-06-2014) |
05-01-2014, 08:32 PM | #185 | |
Speed Chaser Thrill Seekr
Drives: 2014 Asphalt Monogram FR-S 6MT
Sent from my SAMSUNG-SM-N900A using Tapatalk
Performance: Jackson Racing SC & Oil Cooler, 18x9.5 Gram Lights 57Xtreme Wheels, 255/35 Yokohoma Tires, Rays Volk Racing Black 17hex 12x1.25 lugs, KW V3 C/O, Stance Control Arms
Exterior: LED DRL MOD Kit, Tom's Tail-lights, 5%/40% tint My Build |
The Following User Says Thank You to Xerious For This Useful Post: | nosi9frs (05-01-2014) |
05-01-2014, 09:11 PM | #186 |
This should work. Think the link is the same, but I'll repost it anyways. [ame]http://youtu.be/8445SoYm3T8[/ame]
05-01-2014, 10:23 PM | #187 |
Drives: '13 Argento MT FR-S
I got mine in today, it took me about 35-40mins to install and I'm very impressed. I was doubting the effectiveness of the part but went ahead and ordered it based on reviews and overall cost. The throws are short enough that when I tested shifting before taking my car off of the jackstands, I thought it was binding and not going into gear but it was.. Still retains factory feel as well (I'm still using my Perrin rear shifter bushing). Best short throw I've ever used (compared to Mopar Short Throw Shifter with Booger shift linkage bushings on my old SRT4, and a TWM shifter in a Civic Si).
05-01-2014, 11:39 PM | #188 |
Drives: 2013 FRS
anyone else provide input in regards to the play that @xxBrun0xx is talking about. mine is coming tomorrow and wondering if i should send it back before wasting my time on install
05-02-2014, 02:41 AM | #189 |
Drives: Whiteout frs
I had mine installed for a few days now and there is no play like that described and depicted in the video above. also, my knob position at neutral has changed after the installation and it is placed a little bit towards the right. I am loving the shifter so far.
Another thing to note, i am no expert so i tried to follow closely the instruction the shifter came with and applied loctite on every bolt that was part of the shifter kit... |
05-02-2014, 02:43 AM | #190 | |
05-02-2014, 04:40 AM | #191 |
Drives: Attitude
That's definitely not normal. You sure you installed everything correctly?
05-02-2014, 05:42 AM | #192 | |
Edit: I'll try replacing the rear shift busing first, since its easier, see if that fixes it, then try replacing the adapter to see if that fixes it. I'll let you guys know when I figure it out so that anyone else with the same issue can fix it as well! Wonder if some of the kartboy users complaining of play have the same root cause as I do? Guess we'll find out!
05-02-2014, 10:07 AM | #193 |
Solved! The bolt that goes into the adapter piece was loose. Tightened it up and there's almost no slop now! Also, doesn't seem to rattle, but I just took it out for a few minutes. Much much better!
The Following 9 Users Say Thank You to xxBrun0xx For This Useful Post: | chanomatik (05-02-2014), ericmpena (05-02-2014), ft86me (05-02-2014), Jmonty (05-30-2014), Kimsey47 (07-30-2014), Mooseknuckle44 (06-06-2014), unsurety (05-02-2014), wu_dot_com (05-02-2014), Xerious (05-02-2014) |
05-02-2014, 10:24 AM | #194 | |
Drives: Dodge Patitas
Sent from my C6906 using Tapatalk |
05-02-2014, 11:10 AM | #195 | |
Drives: Raven FR-S
Can you post the same video with the fix?? |
05-02-2014, 11:42 AM | #196 |
Yes sir!
[ame]http://youtu.be/2JIPNaEXxfA[/ame] Sent from my XT1053 using Tapatalk
The Following 6 Users Say Thank You to xxBrun0xx For This Useful Post: | chanomatik (05-02-2014), ericmpena (05-02-2014), nosi9frs (05-02-2014), SPCorBUST (05-23-2015), stockysnail (05-03-2014), Xerious (05-02-2014) |
Similar Threads | ||||
TRD Quickshifter | lovebeingbleu98 | Brakes, Suspension, Chassis | 3 | 02-13-2014 12:14 AM |
Amazing Wax | geb2391 | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 04-12-2013 04:42 PM |
The most amazing thing I've done with my BRZ so far | azngolfur | BRZ Photos, Videos, Wallpapers, Gallery Forum | 8 | 01-09-2013 08:23 PM |
Concept-Three-LED's DRL's are AMAZING! | soros151 | Cosmetic Modification (Interior/Exterior/Lighting) | 4 | 11-09-2012 01:42 AM |
