Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
09-25-2020, 12:53 PM | #29 |
Persona Non Grata
Drives: '15 BRZ (WRB)
You may well find jackstands more useful than you realize. If you are planning to flush your brakes, replace the pads and/or rotors, mess around with suspension mods or anything else that you may need or want to have the car elevated with the wheels off, ramps just won't do it. You'd be surprised how convenient it is to get the wheels out of the way for many other things.
I use these jack stands. https://www.amazon.com/ESCO-10498-Ja.../dp/B0019JVIPM Each stand has a three ton capacity and they are rock solid. I top them with these pinch weld protectors. https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 They are machined aluminum with a slice of delrin in the channel and a couple of magnets to hold the protector to the pinch weld while you lower the car.
Slow is smooth, and smooth is fast
The Following 2 Users Say Thank You to Capt Spaulding For This Useful Post: | DarkSunrise (01-07-2021), Tcoat (09-25-2020) |
09-25-2020, 08:26 PM | #30 | |
Drives: Toyota 86 GTS
ie - Is that height even enough for me to be able to get down to my midpipe, - will the angle of that ramp be too steep to avoid scraping the front bumper when it's on the ramp - Does that specific ramp look 'safe'?- I'm sceptical of it being made of plastic and the 17000kg weight limit claim https://www.tradetools.com/renegade-...m-height-186mm This ramp looks more reliable to me but I don't know whether the 250mm (9.8 inches) will be too steep of an angle for the front end of the car |
09-25-2020, 08:40 PM | #31 | |
The angle could indeed be as issue. There isn’t a whole lot of leeway. It probably has a capacity of around double it's rated one. There are some tough plastics. Like the Capt said jack stands have a more all around use.
09-27-2020, 09:00 PM | #32 |
Drives: 2017 Toyota 86
My car isnt lowered, but I have a lip on front which makes it too low to drive the front up on ramps. I could probably back up onto the ramps, but haven't tried. With lowered cars ramps can get to be a pain - you need some cheater board to get you on them. A low profile jack and stands will do.
09-27-2020, 09:12 PM | #33 | |
Drives: 16 Silver BRZ, 04 Silver WRX wagon
The Following User Says Thank You to Ernest72 For This Useful Post: | Tcoat (09-28-2020) |
09-28-2020, 02:01 AM | #34 |
Drives: 2020 Toyota 86 GT 6M
the only problem with ramps is how low our cars are. In stock form, our front bumpers won't even clear the rhino ramps. You may need cut a few pieces of wood to drive up on so you can clear em, or pay a premium and get those race ramps that are available for low clearance sports cars.
pros to ramps = quick and easy, safer as long as you don't drive right over the top cons = takes way more room storing if getting race ramps, more expensive, and limits what you can work on (cannot work on brakes/suspensions with ramps. Quickjacks are an option as well but even more pricier, may take as long to set up as jacks + quickstands but I liked the quickjacks because they have optional pinch weld blocks |
09-28-2020, 02:15 PM | #35 | |
10-08-2020, 11:19 PM | #36 |
Wow thread necro!! I have commmmeeeee along way since posting this wow.
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | Wally86 (01-07-2021) |
01-07-2021, 09:23 AM | #37 |
Be Kind
Drives: 2020 86
I use four of these low profile ramps to get the car off of the ground enough to do any work. Up on the ramps and then jack the car up to put it on jackstands. You won't need them for stock height but if you lower the car, they're a life saver.
Tomioka Racing Super Slopes - Low Profile Car Ramps ($70/pair) Exhaust is totally doable on jack stands.
The Following 2 Users Say Thank You to Wally86 For This Useful Post: | jeepmor (01-16-2021), Ultramaroon (01-07-2021) |
01-07-2021, 10:48 PM | #38 |
義理チョコ
Oooo... look at all those shiny clean fasteners.
The Following User Says Thank You to Ultramaroon For This Useful Post: | Wally86 (01-08-2021) |
01-08-2021, 06:46 AM | #39 |
Be Kind
Drives: 2020 86
Easier to work on when she's new
The last time I did an exhaust I needed a drill bit (or six) and some serious patience. This time? Nope. Everything unbolted like buttah.
The Following 2 Users Say Thank You to Wally86 For This Useful Post: | SCFD (01-08-2021), Ultramaroon (01-08-2021) |
01-08-2021, 09:10 AM | #40 |
I just installed my exhaust on jack stands before the holidays. I only had 2 jack stands but definitely recommend using 4.
After removing the muffler, I actually had to remove the jack stand from passenger side rear to driver side front so I could get to the mid-pipe. |
01-08-2021, 09:13 AM | #41 | |
Be Kind
Drives: 2020 86
The Following User Says Thank You to Wally86 For This Useful Post: | Ultramaroon (01-08-2021) |
01-16-2021, 04:16 PM | #42 |
Drives: 84 CJ7, 08 Duramax, 2014 FRS
Just did a CSG cat back exhaust change with only the tail end up. It was as high as my 3ton floor jack could support, then I put the small jackstands in front of rear wheels Bit tight at the mid-pipe connection, but still pretty easy reach.
I could not get the rig high enough to use my large 12 ton jackstands. I tried as they offer some serious clearance, I just didn't want to lift it up in multiple stages with more blocks on the jack puck. Exhaust only took about 20-30 minutes to swap out. The CSG slip joints connections and the clamps are really nice. Connected them all up loosely and hung the exhaust on the hangers, wiggled a bit to get everything straight and centered so it didn't bind or bump hard points, tightened the bolts. Really nice kit. That said, more time was spent getting ready and cleaning up. WD40 on the exhaust hangers made that bit pretty messy, that stuff is hard to wash off. |
The Following User Says Thank You to jeepmor For This Useful Post: | Wally86 (01-28-2021) |
Similar Threads | ||||
DIY install ISIS catback exhaust | sirhc | DIY (Do-It-Yourself) Guides | 13 | 07-10-2015 10:33 AM |
DIY-TANABE MEDALION TOURING CATBACK INSTALL | kinryu | DIY (Do-It-Yourself) Guides | 10 | 07-28-2014 11:05 AM |
Wtb greddy evo 3 catback | Jeong | Engine, Exhaust, Bolt-Ons | 1 | 01-07-2013 12:21 PM |
HKS Catback Exhaust Group Buy - Legamax Premium Exhaust & Hi-Power Spec L Catback | FT-86 SpeedFactory | Groupbuys | 11 | 10-21-2012 08:59 PM |
Are my accessory jacks plugged in? | dale.m | Electronics | Audio | NAV | Infotainment | 3 | 10-09-2012 12:14 AM |
