Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) Everything related to the mechanical maintenance of the FR-S and BRZ |
10-29-2020, 12:42 PM | #15 |
1st86 Driver!
Makes sense. My cars don't sit enough for any of this to be an issue.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following User Says Thank You to Dadhawk For This Useful Post: | Tcoat (10-29-2020) |
11-03-2020, 11:38 AM | #16 |
Drives: _
Things that don't degenerate with time (spark plugs, air filter, cabin filter, etc.) can go by mileage.
Things that do break down with time (oils & fluids, tires, etc.) should go by time (or mileage, whichever comes first). |
The Following User Says Thank You to chipmunk For This Useful Post: | Ohio Enthusiast (11-03-2020) |
02-08-2021, 02:51 AM | #17 |
Drives: '16 FR-S RS2 MT, '06 xA Polar MT
So as an example , if you drive a vehicle 2k mlles per year (use synthetic oil , and OE filter) , would you say changing the filter every 2k (so once per year , to help keep the oil as clean as possible) , then changing the oil every 2 years be acceptable ? Also, if I use Lucas Oil stabilizer ( 1/2 to 1 quart in our cars) , will that then help the oil go longer durations (of time) between oil changes ?
The main question would be is after a year how well does the "sharing" protection of synthetic oils hold up ??
Math is like Love, simple idea at first that quickly gets complicated
02-08-2021, 05:15 AM | #18 |
LMGTFY
Drives: 13 FRS, 91 Miata
Take a sample, send it in. Let them tell you what they think.
My car gets changes every 1.5 years now. (extended over time) M1 Advanced Fuel Economy. No additives. Spirited driving. |
06-08-2021, 07:42 AM | #19 | |
FT8Syg
Drives: `12 FRS & `17 BRZ Inazuma
Anyway, I think we are all overthinking this. To keep everything simple, it's better to put on fresh & clean underwear daily than weekly Note that there are 2 types of synthetic oil: SYNTHETIC BLEND (mixed synthetic & mineral oils) & FULL SYNTHETIC. Generally speaking, under NORMAL DRIVING CONDITIONS, mineral oil lasts about 3 mos. or 3k-5k miles, synthetic blend lasts approx. 6 mos. or 5k-7k miles, while the full synthetic can last more than a year or 7k-10k miles or even up to 15k. 0w-20, the oil for our FA20, comes in either blended or full synthetic. It's a smart idea to follow the PMS based on either mileage or time to avoid any problems. It also gives you the opportunity to CHECK any problems that may have developed since the last time you've taken a look under the hood (hey, some of us can be quite busy & forget about these maintenance scheds). Again, PMS is a GUIDE & not an absolute especially for normal driving conditions. EXTREME DRIVING CONDITIONS require more or frequent maintenance. When it comes to COST, oil change is a relatively cheap if you know where to find them & are smart enough not to be fooled by MARKETING strategies that make you pay EXTRA. You can get a "repackaged" FULL SYNTHETIC OIL for $20/5qts with the same or similar chemical components as the BIG BRANDED ones that cost $50/5qt. Examples of these are Costco's Kirkland, Amazon Basics, & even Walmart full synthetic oils which, if I remember correctly, are made by the same manufacturer as SHELL oils. They all have API seals & perform just like the other known brands. There are already tests done on YouTube to verify this. Unless you are racing, then you may need a racing oil.
Modding for daily fun & efficiency: Gruppe-S UEL, HKS dual res. FP, STi Per. Muffler, Delicious T. Ecutek tune, Crawford BPB, Grimmspeed CAI, STi Flex T. Bar, TRD Door Stabilizer, DSS aluminum propeller shaft, Verus diffuser & underbody covers, Verus LCA, Perrin bushings, Bilstein B6+RCE Yellows, Michelin PS4S + 18" WedsSport TC105X-summer, Michelin Alpin PA4 +18" Motegi MR140-winter
06-08-2021, 03:53 PM | #20 |
Drives: 2022 BRZ sport-tech
For low mileage garage queens, once a year is fine. I have even read that some have gone as long as 2 years with no ill effect (backed up by oil analysis) but why bother? With the cost of oil, it's cheaper to just change the oil than to do an oil analysis.
Daijiro Katoh - Champion Forever!
Past: 92 EG w/JDM B18C, 00 EK w/JDM B18C, 04 600RR, 97 ITR #421, 10 Acura CSX-S, 17 BRZ Current: 22 BRZ, 00 S2K - #0220 |
Similar Threads | ||||
What's your mileage? | Aussie Jase | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 08-16-2020 08:10 PM |
First Oil Change. Which is most important, Time or Mileage? | dudeslife | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 42 | 07-09-2016 04:47 PM |
Gas Mileage | AVodka14 | Issues | Warranty | Recalls / TSB | 32 | 03-03-2014 10:34 PM |
Gas Mileage | frosty86 | Hawaii | 12 | 10-09-2012 04:56 AM |
Gas Mileage | DuMa | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 12-07-2011 01:20 AM |
