03-16-2020, 12:21 PM | #393 |
Drives: 2015 FRS - FFR GTM
Thanks,,, it'll double as a Covid-19 isolation ward.
2015 FR-S - One Day I'll Finish The Swap |
The Following 3 Users Say Thank You to gtpvette For This Useful Post: |
03-16-2020, 06:42 PM | #394 |
Sanded with 1500,, buffed and installed. Fronts aren't done as the bumper isn't installed.
The Following 6 Users Say Thank You to gtpvette For This Useful Post: | Code Monkey (03-16-2020), Hypnocracy (03-20-2020), mrg666 (03-17-2020), Raven86Project (03-17-2020), Ultramaroon (03-17-2020), Zer0 (03-16-2020) |
03-17-2020, 12:21 AM | #395 |
義理チョコ
Brilliant improvisation! I will steal that sometime, I'm sure.
03-17-2020, 08:59 AM | #396 | |
Garage would be better if for nothing else the comments and question regarding when is it coming down from the wife LOL. I'm going to try and spray the scoop an underside of hood this afternoon. Tomorrow paint the top of the hood and the bumper emblem. At that point the booth can go away. She who must be obeyed will be pleased.
2015 FR-S - One Day I'll Finish The Swap Last edited by gtpvette; 03-17-2020 at 09:20 AM. |
03-17-2020, 09:45 AM | #397 |
Only users lose drugs.
Drives: All the time
Hmm...not sure I knew you'd installed a hitch. What brand, and what have you hauled with it so far?
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
03-17-2020, 10:42 AM | #398 |
Drives: 14 BSP Edelbrock BRZ
Please recycle the pallet wrap! Home Depot will take up to 6 mil plastic film.
03-17-2020, 11:09 AM | #399 | |
Didn't know they did that,,, thanks.
03-17-2020, 09:22 PM | #400 | |
義理チョコ
03-17-2020, 09:49 PM | #401 |
You Sir Are My Hero.
03-22-2020, 06:20 PM | #402 |
Paint is complete. Still need to sand and buff hood and scoop. Hoods got a lot of crap in the paint for some reason. We'll see what tomorrow brings with sanding and buffing. I also painted an aftermarket emblem for the front bumper. Wanted to shave it all together but the shape of the bumper really needs an emblem. Filled in the SCION. Not 100% sure I like it.
The Following User Says Thank You to gtpvette For This Useful Post: | Zer0 (03-23-2020) |
03-26-2020, 09:10 PM | #403 |
A few final shots of the paint work......
03-27-2020, 10:16 AM | #404 |
Man...I cannot wait to the see the finished product and watch/hear it run! And I'm soooo glad you went with a more traditional button flare than a huge Rocket Bunny type...that car is gonna look sharp.
The Following User Says Thank You to venturaII For This Useful Post: | gtpvette (03-27-2020) |
04-18-2020, 05:31 PM | #405 |
Work continues. Lots of small tasks to complete,, basically a punch list before I try to start. Tomorrow I'll finish up a few then pull the motor hopefully for the last time. The biggest tasks are install the clutch, crank pully and oil pan. I want to detail the engine compartment as it's been sitting open for over two years and there's a little paint work to do as well. I need to detail the motor as well. It's amazing what the salt air does to aluminum.
July this year will be three years,,, just dam. - Fix Dipstick x Shorten lower radiator hard line x Weld in bung on hard line for surge tank supply X Lengthen fuel hose x Trace and confirm location VSS and E85 wires X Install Gas Cap x Install pressure switch for AC X Fab AC Lines x Resolve PCV Lines - Install Puke Tank x Install clutch remote bleed Pull motor/trans Tighten Engine Side Fuel Line Paint Valve Covers - Maybe Detail engine bay Detail Motor Paint front support and above headlights Install/Seal oil pan & pickup tube Install new clutch Install crank pulley Fab transmission dust shield Replace VSS Install motor/trans Fill Transmission Install Oil Filter - Oil Water Reinstall dash
The Following 2 Users Say Thank You to gtpvette For This Useful Post: | Sportsguy83 (04-19-2020), Ultramaroon (04-20-2020) |
06-21-2020, 05:20 PM | #406 |
Took a bit of time off the work to do some honey do's, back at it again. Started the detail of engine compartment. For all of my years, cant say I've really every done this before. Wet rag, tooth brush and compressed air work pretty well considering it's been sitting open for almost 3 years. The aluminum on the motor has some oxidation that I still need to address but generally just about done.
I've also come to the conclusion the oil pan is a bit too close (for comfort) to the sway bar. I had bought an additional Oil Pan some time back so spent some time working on it this weekend. First problem the pan was nasty,, and I do mean nasty. Opted to clean it up myself. Made a redneck hot tank and cooked it for 3-4 hours. Did pretty well but should of put more degreaser in it. Hit it with brake cleaner, small wire brush then pressure cleaned. All in all came out OK. OK for the modification. The back of the sump is just too close. You can see in the picture the area 'X'ed, just need 3/4" or so and I'll be happy. Like to have it cut up this week and sent out for welding.
Similar Threads | ||||
Should I have just got a new motor? | SoundsOfTheUniverse | Issues | Warranty | Recalls / TSB | 12 | 07-31-2017 07:51 PM |
Seized motor!! What STX mods should I do while I have the motor out?? | BlaineWasHere | Tracking / Autocross / HPDE / Drifting | 27 | 12-11-2014 02:39 PM |
K2 Motor? | Ronin Sascha | Engine, Exhaust, Transmission | 8 | 08-16-2014 06:51 PM |
Does every motor say #1 | sosick | Engine, Exhaust, Transmission | 21 | 05-05-2014 09:28 AM |
MOTOR UNION | David | Southern California | 0 | 06-22-2013 01:32 PM |
