GR86 General Topics (2nd Gen 2022+ Toyota 86) General topics for the GR86 second-gen 86 |
#57 |
Drives: GR86
#58 | |
Drives: Crapcan
This is the CSG C1 pad on a stoptech BBK with 328mm rotors. Much different setup.
#59 |
ProCrastinationConsultant
that's not a problem, as you're going to be changing pads and rotors soon anyways!
#60 | |
Drives: Too fast
It is neither. |
#61 |
deposits are a bad thing. they create an unpredictable friction surface.
#62 | |
Ted Roo
Drives: My18 wrxsti My19 brzts
This is what you want to hear. Replace the rotors with bigger dia rotors and a set of 4 piston front and 2 piston rear calipers (AKA BIG BREAK KIT) LOL BIG BRAKE KIT.
Wait until my Flex capacitor hits 88
The Following User Says Thank You to gen3v8 For This Useful Post: | soundman98 (04-15-2022) |
#63 | |
For all intents and purposes, there is no reason to disable or turn the system off, even on track, as it is a reactive system. It only intervenes if you've already locked up one or more wheels. It is generally faster to leave ABS on, and to judiciously use the system only under circumstances where traction is uneven. (e.g. left tires have way less traction than right) ABS comes with a LARGE heat penalty when used. |
The Following User Says Thank You to CSG Mike For This Useful Post: | soundman98 (04-15-2022) |
#64 |
He just needs to get better pads. No need for a BBK at this time.
#65 | |
This happened because the pad is completely insufficient for your use. You need a better pad combination. |
#66 | |
If you think deposit are NOT a negative thing, then you should check out your own data. You'll very quickly change your mind when you see how it affects your braking ability. |
#67 |
Drives: Too fast
Haven't said anything about the dtc working for anyone or me, did I.
My data says that OP level of deposits have zero impact on braking, unless there is pad contamination. |
#68 | ||
Drives: Crapcan
![]() I personally don't consider that level of deposit or difference in rotor heating alarming. I just wouldn't buy that combo again if it was me but I'd continue to run them till I wore that set out. As for your goofy comment on "rich" CSG pad owners. Are they really more expensive if they last longer? XP10's at 500 a set lasted me maybe 60-65% of the life of C1's, not to mention the XP's suck. I am running Raybestos this go around, will probably try something else the next time variety being the spice of life so they say.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | CSG Mike (04-16-2022), soundman98 (04-15-2022) |
#69 |
Drives: GR86
#70 | |
Drives: Too fast
XP10 were awful to me too. 5+ sets on this chassis, probably 30+ dtc sets total. Hundred+ of sets from other brands combined...dtc are very high on the scale of performance and life per $. |
Brake pads to swap between for DD and Track Days | jim985 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 17 | 12-25-2020 08:12 PM |
Brake compound for Track Days | fer3d | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 13 | 07-31-2018 08:47 AM |
Brake Pads and Fluid For DD/AutoX/Track Days/HPDE | ToyoburuBRZ | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 29 | 07-23-2016 03:59 PM |
NPA: APR Carbon Fiber Brake Cooling Kit with Ducts - A must for track days | 86_Insider | Brakes, Suspension, Chassis | 1 | 09-26-2013 01:39 AM |
Brake pads for track days | why | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 2 | 05-26-2013 06:42 PM |
