04-13-2022, 07:31 AM | #715 | |
1st86 Driver!
It has a bad habit of tripping when everyone is upstairs and you have to walk down two floors to reset it, usually because MomHawk is using her blow dryer at just the right time, or someone plugs the vacuum into it. I now have a habit of looking at it every time I walk by it, or out to the garage where our freezer is just to make sure the freezer power light is on.
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 2 Users Say Thank You to Dadhawk For This Useful Post: | humfrz (04-14-2022), soundman98 (04-13-2022) |
04-13-2022, 09:36 AM | #716 |
Drives: 2017 BRZ
All this talk reminds me I really need to sort the AFCI to our office. I had a laser printer on it, can't any more. And I have to delay power to my fanatec wheelbase or it'll trip when I power up the monitors, etc. That's with a battery backup between. Might be related to the LED strip lights I have as backlighting. Would need new conduit from the back of the house to the front and up to the second floor to run anything better, like a 20a or two. Even to replace the current one. And short slots in the breaker box too.
So many problems. Not sure I trust the last company I hired. And this isn't gonna be cheap work.
The Following 2 Users Say Thank You to cjd For This Useful Post: | humfrz (04-14-2022), soundman98 (04-13-2022) |
04-13-2022, 10:09 AM | #717 | |
When we moved in there was a GFI outlet on the one bathroom GFI circuit breaker. Of course the two didn't play well together and one or the other would trip if you caused a slight breeze nearby.
The Following 3 Users Say Thank You to Tcoat For This Useful Post: |
04-13-2022, 11:33 AM | #718 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
My house has 6 gcfi breakers, including one 220 breaker for the hot tub. When I bought this house, I was confused that there were no gcfi outlets in the bathrooms in a house built in 1988. All my previous homes were so old I had never seen a gcfi breaker.
04-13-2022, 11:40 AM | #719 |
Drives: Crapcan
I didn't find out about the breakers till 4 or 5 years ago through work. Certain counties were mandating GFCI's on some of our outdoor equipment. Our variable frequency drives where playing havoc with them, finally figured out if you use the GFCI breaker the issue goes away. Dunno why.
04-13-2022, 09:20 PM | #720 |
Airborne at your service
Drives: '17 BRZ Series.Yellow
I feel I'm crazy for liking the instant coffee that comes in MREs
The Following 2 Users Say Thank You to weederr33 For This Useful Post: | Spuds (04-13-2022), Ultramaroon (04-14-2022) |
04-13-2022, 09:49 PM | #721 | |||
ProCrastinationConsultant
i've installed at least 100 arc fault breakers. and removed about 50 of them due to random tripping issues. many on brand new wiring that i know has zero issues. dimmer switches cause a lot of problems, mostly when the dimmer is turned up all the way. lately, i've been pulling fewer and fewer breakers, so i think they're getting better. but no guarantees. i've mostly been using seimens brand arc faults, YMMV... they especially seem to like to trip during dinner parties though. worst part is that unlike gfi's, there's no real test procedure other than "check your connections" and "could be ___"... unofficially, many contractors only leave the arc faults in for inspections, and then replace them afterwards, then re-use on the next job. everyone easily tires of tons of wasted money on callbacks for intermittent tripping issues that can't be tested, repeated, or fixed. leaving them in and trying to explain 'that's code' only leads to discouragement and lack of trust in the contractors... Quote:
The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (04-14-2022) |
04-13-2022, 11:06 PM | #722 | |
Drives: 2017 BRZ
We've been here since 2014, and that printer worked great till late last year... It's a 10a surge at power up... I mean, the printer still works, but it's been on that breaker So these AFCI aren't the worst ever. Tempted to swap with one from a basement bedroom just to be sure it's a dead breaker... Say, the one that's my workshop now? Table saw is great for arc fault (ok, it's on a different circuit). So yeah. Easy fix. Don't put an arc fault in as a replacement. But if I'm maxxing the gaming rig and the printer fires up it could be close to circuit max...
The Following User Says Thank You to cjd For This Useful Post: | soundman98 (04-13-2022) |
04-14-2022, 12:08 AM | #723 |
義理チョコ
Nope. I like all kinds of weird shit like that. Maybe I'm just crazy too.
The Following User Says Thank You to Ultramaroon For This Useful Post: | weederr33 (04-14-2022) |
04-14-2022, 12:49 AM | #724 |
The Following User Says Thank You to humfrz For This Useful Post: | Ultramaroon (04-14-2022) |
04-14-2022, 12:53 AM | #725 | |
04-14-2022, 01:14 AM | #726 | |
After you install it, be sure to check around fer smoking wires - |
The Following User Says Thank You to humfrz For This Useful Post: | cjd (04-14-2022) |
04-14-2022, 01:20 AM | #727 | |
義理チョコ
See? It's funnier when I explain it, right? Hahaha...
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
04-14-2022, 01:27 AM | #728 | |
The Following 2 Users Say Thank You to humfrz For This Useful Post: | soundman98 (04-14-2022), Ultramaroon (04-14-2022) |
Tags |
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
Similar Threads | ||||
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
