06-03-2022, 11:48 PM | #1947 |
ProCrastinationConsultant
aw, my internet's being slow tonight, i missed the edit..
The Following User Says Thank You to soundman98 For This Useful Post: | Spuds (06-04-2022) |
06-03-2022, 11:59 PM | #1948 | |
Drives: Crapcan
I’d look to go something like this. https://www.primelights.com/collecti...ns-pl-blt44wcl Then since you are hardwired, just add occupancy sensors to them. They are 15 bucks each on Amazon.
The Following User Says Thank You to NoHaveMSG For This Useful Post: | Spuds (06-04-2022) |
06-04-2022, 12:12 AM | #1949 | |
https://www.homedepot.com/p/Lithonia...0CRI/300263606 we've used some other brands, i believe Topaz. available at city electric supply, there's a few around maryland, though the clips/brackets are a PITA to mount. https://www.topaz-usa.com/f-l8-64w-5...ar-strip-5000k can get led conversion tubes to convert the fluorescent fixtures to led(2 types, 1 just plugs in, works through the existing ballast, 2nd type gets replacement bulb holders and gets hardwired to 120v), but if you're not happy with the number/placement, it's not really worth it. general cost isn't that much less, output from those kits are moderate, but not as good as the led fixtures. done a few garages over in the last couple years-- generally shoot for at least 2-4 fixtures at about 7,000-10,000 lumens per fixture in most 2-3 car garages.
06-04-2022, 12:22 AM | #1950 | |
The Dictater
Drives: '13 Red Scion FRS
https://www.amazon.com/dp/B07PG3RLH7/ref=emc_b_5_mob_t |
06-04-2022, 12:29 AM | #1951 | |
The Dictater
06-04-2022, 12:39 AM | #1952 | |
Drives: Crapcan
You’d need all 16 at 2200lm. I was just saying something like that. Not those specifically. I did order these because I was getting a bunch for work so adding mine to the order got them at quantity discount.
06-04-2022, 01:02 AM | #1953 | |
the ones i have, the double 'tube' diffusers tend to mask scratches more, doubly-so with having two diffused tubes next to each other. it's a very soft glow. great for general purpose workshop stuff, but terrible for detailed scratch correction a single-unit mostly-clear diffuser like those topaz one's are going to provide sharper light output to better read the scratches. i use one of these on a hand truck to compare/contrast scratch correction when i'm detailing because the overhead lights are too soft, especially on the sides of the vehicle. https://www.menards.com/main/lightin...4180804&ipos=4 you can see how i set it up just to the drivers side of the car. i also take it off the hand truck and will move it under the car to reflect up, and wave it over the top of the car like a wand to check from other angles. honestly, in a lot of ways, it almost works better to have just that one 5k lumen fixture to wave around as needed than to have any of the overhead lights to do detail work.
06-04-2022, 01:09 AM | #1954 | |
The Dictater
I still do need to do the overhead lights anyway. Also, dayum, you go all out and mask off when you detail huh? I'm a bit lazier lol. Though now I'm having problems with swirls and having to go back and redo things. Tried using the thin pro pads and it hasn't worked out... |
06-04-2022, 01:22 AM | #1955 |
lol, it's a lot easier to mask everything off than to be overconfident with the buffer and then try to back-to-black all of the trim i hit. especially the area around the side mirrors.
figure i can either spend the hour or two masking everything, or will be spending the next 6 months trying to undo the white spots on the black trim. i probably spent about the same amount on either back-to-black as i do on blue tape, so the material cost is at least a wash. this way makes me look like the professional i'm not! and even better, i don't have to do anything else to it for another 2 years!
The Following User Says Thank You to soundman98 For This Useful Post: | NoHaveMSG (06-04-2022) |
06-04-2022, 01:26 AM | #1956 | |
The Dictater
The Following User Says Thank You to Spuds For This Useful Post: | soundman98 (06-04-2022) |
06-04-2022, 02:35 AM | #1957 |
The Following User Says Thank You to humfrz For This Useful Post: | soundman98 (06-04-2022) |
06-04-2022, 02:40 AM | #1958 |
06-04-2022, 07:47 AM | #1959 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
It's gout. I did have half a steak and a couple glasses of wine last weekend, so shame on me. Such a glutton.
Need to take a different treatment approach, but my doctor is a month out. Not being able to eat anything like a normal person without extreme pain and loss of mobility is really getting old. Nothing but rice, water, and medication all week. Sucks. |
The Following 4 Users Say Thank You to Sapphireho For This Useful Post: |
06-04-2022, 09:11 AM | #1960 | |
Drives: '20 BRZ tS (15/300) / '09 Scion tC
https://www.homedepot.com/p/YANSUN-8...1E26/317825202 Edit: I didn't read the hard wired part. |
The Following User Says Thank You to 2020BRZtS For This Useful Post: | Spuds (06-05-2022) |
Tags |
have you turned it off/on, i heart my boxer, i still hate you all, kiss me, maple syrup, multipass, next one is a prequel, ow my balls, special_k abandoned you, the search for more money |
Similar Threads | ||||
Random Thoughts - Part Deux [NO POLITICS] | Ultramaroon | Off-Topic Lounge [WARNING: NO POLITICS] | 84004 | 03-07-2022 11:00 AM |
OEM BRZ spark plug part number? | qqzj | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 05-26-2017 11:33 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random search on bing | sdwagonjp | Off-Topic Lounge [WARNING: NO POLITICS] | 11 | 11-19-2014 07:35 PM |
