01-20-2022, 08:27 AM | #23507 |
Drives: 2013 frs base
I hear that you can adjust the clearance by adding extra sealant.
The Following 8 Users Say Thank You to blsfrs For This Useful Post: | alex87f (01-20-2022), Dadhawk (01-20-2022), DarkPira7e (04-29-2022), Jdmjunkie (01-20-2022), MJones_RB (01-26-2022), NoHaveMSG (01-22-2022), soundman98 (01-20-2022), Ultramaroon (01-20-2022) |
01-22-2022, 04:46 PM | #23508 |
Ulli
Drives: Toyota GT86
we set the valves specifically to a tenth so that the engine runs smoothly. many think it has hydraulic valve lifters but that is wrong. The valves have to be adjusted every 60,000 km
The Following User Says Thank You to Little Samurai For This Useful Post: | Wally86 (01-22-2022) |
01-22-2022, 06:32 PM | #23509 |
Be Kind
Drives: 2020 86
The FA20 has shims??
01-23-2022, 10:19 AM | #23510 |
Track or street driving? Most of us aren't going pull our engines to adjust the valves at 40,000 miles.
01-23-2022, 01:41 PM | #23511 | |
Drives: FR-S,GTI
Damn, it's a big enough PITA just to drop the tranny every 100,000 miles to replace the TOB! |
The Following 3 Users Say Thank You to WNDSRFR For This Useful Post: |
01-26-2022, 09:47 AM | #23512 |
Drives: 86 GT
Did an autocross and gymkhana practice session today. Far more engaging than a track day - I should have started way sooner.
DIY stuff at Compelica Works
01-26-2022, 11:43 AM | #23513 |
Drives: Crapcan
Bucket shim has very little wear, especially when a roller rocker is also incorporated. You may see some minor lash changes in the first service interval, not necessarily large enough to require adjustment. Further intervals typically see very little change if any. The rocker pivot sits in a galley and is acted on by pressurized oil. It is not acting as a hydraulic lash adjuster but probably does take up some play while the engine is running.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | soundman98 (01-26-2022), Wally86 (01-26-2022) |
01-27-2022, 09:11 AM | #23514 |
My understanding is the long term problem with lash is the loss of lash due to valve recession, not an increase due to wear and tear that you might see in a push rod engine.
The Following 2 Users Say Thank You to blsfrs For This Useful Post: | NoHaveMSG (01-27-2022), Ultramaroon (01-27-2022) |
01-27-2022, 11:51 AM | #23515 |
Drives: Crapcan
In general this has been my experience. The worst is SOHC with tappet follower. Those always get out of spec and end up all over the place. Not a common in cars though, usually just air cooled motorcycles.
The Following 2 Users Say Thank You to NoHaveMSG For This Useful Post: | blsfrs (01-27-2022), Ultramaroon (01-27-2022) |
01-27-2022, 01:54 PM | #23516 |
Drives: Scion FR-S Series 10 #2462
One thing I learned about valve lash adjustment, from my GS-R days, is that getting them into spec can help you pass SMOG.
The Following 2 Users Say Thank You to MJones_RB For This Useful Post: | blsfrs (01-28-2022), soundman98 (01-27-2022) |
01-27-2022, 02:06 PM | #23517 |
Drives: Crapcan
I could see a tight valve cause issues on an emission test.
01-30-2022, 05:23 PM | #23518 |
Finally washed it! Unfortunately was a machine wash since my kid loves them (the first the car’s ever seen)but I think it turned out pretty decent. A few marks left (melted rubber streaks from the track) but I’ll clean those off later.
2022 BRZ Build 2013 FR-S Build |
01-30-2022, 06:04 PM | #23519 |
ProCrastinationConsultant
stared at it longingly while it sits in the garage. said screw it, went inside to grab the keys, and it started snowing...
The Following 7 Users Say Thank You to soundman98 For This Useful Post: | 7 skulls (02-03-2022), Busybee (01-30-2022), Jdmjunkie (01-30-2022), NoHaveMSG (01-31-2022), Stephen W. (01-30-2022), The Red One (01-31-2022), Ultramaroon (01-31-2022) |
01-31-2022, 07:28 AM | #23520 |
1st86 Driver!
Went out to the garage, looked at it's poor crushed left rear-end, and teared up a little.
I suppose I could drive it to a meet and claim I did it drifting for some street cred. (if you are reading this and don't know)
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
The Following 5 Users Say Thank You to Dadhawk For This Useful Post: | ACT86 (02-01-2022), Cephas (02-03-2022), NoHaveMSG (01-31-2022), soundman98 (01-31-2022), Ultramaroon (01-31-2022) |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
