09-16-2013, 10:20 PM | #393 | |
Drives: WRB BRZ
09-16-2013, 10:33 PM | #394 |
Drives: 2013 FRS
09-16-2013, 10:44 PM | #395 |
Drives: Whiteout 6MT FRS
So i downloaded my map, uploaded the stage1 stock airbox map, and wrote it to the ECU. Started it up and let her idle for a bit per instructions. Definitely more peppy. Launch control is nice, although set a bit too high for my liking but you can adjust it. One thing that is very noticeable is the gas-peddle feel. There seems to be a bit of a dead spot for the first 1cm or so. I almost stalled because it was that different from stock. @shiv@vishnu is this normal?
Otherwise I am very pleased so far. I have a header back exhaust so I am waiting for their OTS stage 2 map. so far just the stage one maps are available for download. |
09-16-2013, 10:48 PM | #396 |
Spline Reticulator
Drives: 2013 FR-S Whiteout
I just reset my ecu after an intake swap and have that same pedal feel so it's probably just the learning period. See how it feels with some miles on it.
Sent from my GT-I9505G using Tapatalk 4
Johnny was a chemist's son, but Johnny is no more. What he thought was H2O was H2SO4. |
09-16-2013, 10:48 PM | #397 | |
Drives: FRS
The Following User Says Thank You to Rombinhood@OpenFlash For This Useful Post: | Pooverdam (09-16-2013) |
09-16-2013, 10:48 PM | #398 |
Drives: 2012 86
@Rombinhood@OpenFlash,
Is there a rough timeframe for support of non-US cars? (Mine is ZA1J700G) Do the maps online include the fix which protects the DI seals? Thanks in advance and look forward to purchasing it (once support for my car is confirmed). Last edited by akyp; 09-17-2013 at 12:19 AM. |
09-16-2013, 10:49 PM | #399 |
Drives: FRS
09-16-2013, 10:50 PM | #400 | |
Drives: Skoda Yeti DSG diesel 4x4
Throttle delay. |
The Following User Says Thank You to sierra For This Useful Post: | Pooverdam (09-16-2013) |
09-16-2013, 10:51 PM | #401 |
That headunit though...
Drives: 2013 Subaru BRZ Limited SSM
Excited to give this a shot when 6AT comes. Keep up the great work, and can't wait to hear the user feedback!
2013 BRZ Limited SSM 6AT
Phantom ESC 1.5Dump + E85 + OFH + Q300 Eibach Pro-Kit + Michelin PSS (stock size) |
09-16-2013, 10:51 PM | #402 |
Spline Reticulator
Oo do I win a tablet? ;-)
09-16-2013, 10:52 PM | #403 |
This, happens after every reflash. Give it two drive cycles and it will work itself out. If it isn't gone after about an hour or two of driving time, then you can start worrying about the map... Maybe
The Following 3 Users Say Thank You to enwave For This Useful Post: |
09-16-2013, 10:58 PM | #404 |
This all sounds very reassuring to use. You don't need a laptop and if you stuff it up loading the new map you can go back to the stock one. I have the start button on my GTS and assume I turn the ignition on by pressing it without my foot on the clutch?
Can we save the stock map to our computer in case the tablet craps itself, for a belt and braces type reassurance? |
09-16-2013, 11:01 PM | #405 |
The Following 2 Users Say Thank You to Pooverdam For This Useful Post: | Rombinhood@OpenFlash (09-16-2013), sierra (09-16-2013) |
09-16-2013, 11:16 PM | #406 |
There was lots of talk about Ecutek not being visible to dealer inspection but it wasn't convincing. Is this obvious to a dealer ECU check, either with the modified map or the original map replaced?
Tags |
#lolwut, divinecomedy, dopeandcashcabinet, free shiv now, goddamitimissedit, golden cage, i missed the show, looks good, missed the fun, omgbbq, shiv 2016, thefatandthefurriest |
Similar Threads | ||||
Tablet on the dash ! | TRD_86 | Electronics | Audio | NAV | Infotainment | 23 | 05-16-2015 03:48 AM |
Tablet Install | ThugNasty | Electronics | Audio | NAV | Infotainment | 4 | 04-13-2013 03:15 PM |
Blutooth OBD II and a 9.7 tablet.. | Scooby South | Electronics | Audio | NAV | Infotainment | 10 | 12-16-2012 08:11 PM |
7.0 Tablet w/ Torque App | Thatruth2001 | Northwest | 26 | 11-21-2012 11:53 AM |
