Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-08-2018, 01:44 PM | #1 |
btr.life
Drives: 2022 GR86
OS Giken Super Lock LSD Install
If you were ever wondering what it takes to install a OS Giken differential, here you go This isn't so much a howto but a general guide to be used as a reference. Not a terribly difficult job but if helps to be familiar with how your car comes apart.
[ame]http://www.youtube.com/watch?v=YQbHA6zT59Y[/ame]
The Following 14 Users Say Thank You to justinco For This Useful Post: | bhmax (12-20-2018), churchx (06-08-2018), cjd (06-08-2018), Code Monkey (06-08-2018), CSG Mike (06-08-2018), Erick KY (06-08-2018), gtengr (06-09-2018), JMon85 (06-11-2018), Joesurf79 (06-08-2018), Joveen (12-11-2018), new2subaru (01-20-2019), rns294 (06-11-2018), Sportsguy83 (12-20-2018), Teseo (06-09-2018) |
06-08-2018, 02:19 PM | #2 |
Drives: 2017 BRZ w/PP
I saw this yesterday and asked the discord what exacrtly is better about this.vs the OEM? Just stronger and lighter?
06-08-2018, 02:22 PM | #3 |
Drives: Raven FR-S 6MT
You didn’t mention any gasket when you were putting the cover back on. Omission? Or is it not necessary there after?
06-08-2018, 02:32 PM | #4 | |
btr.life
Drives: 2022 GR86
https://frsport.com/dif-10590-differ...asket-fr-s-brz Now that you mention it, I think I forgot to add that to the video description.
06-08-2018, 02:36 PM | #5 | |
The OS Giken, or similar clutch type LSD, can physically lock the rear wheels together, so that you have to either lose traction with both wheels, or you don't lose traction at all, in the rear. This can have many effects, but the biggest ones are that it makes the rear more predictable, since it behaves the same every time, regardless of condition, and can stabilize the car further under braking (or destabilize the rear, if you choose to set the diff up that way, e.g. for drifting). For cars set up for grip, side effects include being able to recover spins/slides from much greater angles, and making the rear much more difficult to kick out under grip circumstances. In a car set up for drift, the LSD makes the rear end sustain rotation predictably, instead of randomly hooking one tire up and causing a push. |
The Following 15 Users Say Thank You to CSG Mike For This Useful Post: | Capt Spaulding (06-13-2018), Iceman (06-10-2018), jcw99 (01-04-2022), justinco (06-08-2018), RavioliG (01-22-2020), RFB (06-08-2018), RJasonKlein (06-08-2018), rns294 (06-11-2018), Rybot (03-14-2019), sid94 (06-08-2018), Sportsguy83 (12-20-2018), Teseo (06-09-2018), TofuJoe (12-20-2018), wparsons (01-18-2019), x808drifter (06-08-2018) |
06-08-2018, 02:42 PM | #6 | |
btr.life
Drives: 2022 GR86
I would go read this to start: http://osgiken.net/c-1280300-limited...-lock-lsd.html
06-08-2018, 02:55 PM | #7 |
Drives: 2014 GT86
CSG Mike: what should be kept in mind regarding maintenance / long mileage daily driving usage with such clutch type lsd-s? And do they last long?
06-08-2018, 04:35 PM | #8 | |
OS Giken LSDs are meant to last the life of the car. |
The Following User Says Thank You to CSG Mike For This Useful Post: | wparsons (01-18-2019) |
06-08-2018, 04:39 PM | #9 | |
Drives: FRS
The Following User Says Thank You to RFB For This Useful Post: | jcw99 (01-04-2022) |
06-08-2018, 04:41 PM | #10 | |
I run an ATS LSD on my car, and most people never realize I am running a clutch type diff when they sit in it. Using an off-the-shelf LSD is like using an off-the-shelf tune. It's probably better than nothing, but the LSD is definitely not a one-size-fits-all. Having one configured to match your car/needs will yield significantly better results. |
06-08-2018, 04:47 PM | #11 | |
Drives: FRS
06-08-2018, 04:51 PM | #12 |
¯\_(ツ)_/¯
Drives: '15 ultramarine
@CSG Mike, I wanted one, but my shop talked me out of it saying overkill for my weekend toy since I no longer track. Would a dialed in OS Giken LSD be beneficial on a weekend canyon carver? Sure sounds better.
06-08-2018, 04:52 PM | #13 |
06-08-2018, 04:53 PM | #14 | |
I would personally get a LSD before coilovers. |
The Following User Says Thank You to CSG Mike For This Useful Post: | Tokay444 (12-20-2018) |
Tags |
lsd, os giken |
Similar Threads | ||||
Review soon:OS Giken Super Lock Limited Slip Differential + Greddy differential cover | mav1178 | Engine, Exhaust, Transmission | 5 | 02-11-2021 01:20 PM |
Project Mu Lugs BNIB - Racing Floating Nut & Super Lock Nut 7 | SonnyBRZ | Canada Classifieds | 0 | 02-05-2014 10:37 PM |
Results: OS Giken SoPac Super Regional Autox Championship ... | des | Tracking / Autocross / HPDE / Drifting | 5 | 06-25-2013 11:02 PM |
Nagisa Auto D-Lock Super Low Seat Rail | poormans_LFA | Cosmetic Modification (Interior/Exterior/Lighting) | 3 | 11-06-2012 04:35 PM |
